Results 1 to 8 of 8
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    2006 A6 - interior color code - name
    Off the 'build sheet' in the trunk:
    paint color: LZ5D
    interior: N0K/NQ
    I am looking for the arm rest lid, and want to get the color right.
    How is the interior color called?
    What are the codes for the interior referring to?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Feb 20 2010
    Brighton, MI
    Found these interior color options for the 2006:
    Amaretto
    Beige
    Ebony
    Platinum
    Is mine "Platinum" ?
    05 Golf TDI
    Nov 19 2012
    Mankato, MN
    Post a picture and I'm pretty sure we could answer it in an instant.
    Feb 20 2010
    Brighton, MI
    I would call it 'grey'. But with the fancy names they come up with...
    05 Golf TDI
    Veteran Member Four Rings superman_006's Avatar
    Jan 14 2007
    Porsche 996 C2
    WV
    Those are interior trim codes, NOK means that you have leather seats, NQ is light grey (platinum).
    I think there is only 2 types of wood that they put in the A6 walnut (dark) and birch (lighter). If your headliner is silver it came with dark walnut if its beige its birch. The original is matched together so all the wood have a little variation if you replace once piece
    2015 Audi Q5 S-line 3.0T
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by superman_006 View Post
    Got it, thanks. Looking for 'Platinum' now.
    From the touch/feel, the armrest lid is the 'Leatherette' (Audi speak for vinyl), not 'real' leather. Or?
    05 Golf TDI
    Jan 14 2007
    Porsche 996 C2
    WV
    Its real leather... should be seats, arm rest top and the parts on the door panels, not sure ive even seen the leatherette in the a6's
    Feb 16 2012
    2006 Audi A6 4.2L Quattro Sline
    Los Angeles, Ca
    There's the sline which is has dark grey birch trim.
