Results 1 to 40 of 61
    Veteran Member Four Rings TheBlueMartin's Avatar
    Jan 06 2005
    2006 A6 3.2, 2009 Q7 4.2 Prestige, 2014 Regal GS M/T
    Ann Arbor, MI
    cluster screen swap?
    So my friend just brought his '08 A6 by that he bought this year, and its got a red large pixel screen in the gauge cluster like my old C5 had in it. My '06 C6 has the new hi-res multi color screen in it, so I think someone is wrong. Has anyone seen this swap done? I wouldn't think its possible, but I think the last owner screwed him.
    "Mastering others is strength, mastering yourself makes you fearless" Lao Tzu
    2006 A6 3.2 Avant- Black.
    2009 Q7 4.2 Prestige - Lava.
    Jan 06 2005
    Ann Arbor, MI
    Mine and every other one I've seen looks like this.
    Nov 19 2012
    Mankato, MN
    First off, he didn't get screwed (although I honestly think all of us with the stupid red screens got screwed).
    Second off I don't really know what package you had to get to get the color screen. It's as if they mixed and matched whenever they felt like it. It's really weird.
    Mine has the red screen too, I too wonder if you can swap gauge clusters for the colored one.
    Veteran Member Four Rings Dutch_A6's Avatar
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    It would be great if it was an easy swap, the red screen looks just like the one in my wife's Jetta which is kind of a bummer.
    Black 2012 A7 Prestige
    Zito ZF01 wheels
    EPL stage 2 tune
    Tinted marker lights
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    Jan 06 2005
    Ann Arbor, MI
    Quote Originally Posted by enoch861 View Post
    Did you buy your car new? I guess it could have been a premium option to get the multi color screen....but it seems odd not to have it standard. Now that I know there is more than one car out there, its not unheard of.
    Nov 19 2012
    Mankato, MN
    Quote Originally Posted by TheBlueMartin View Post
    Nope, bought it used. And all the A6's I test drove all had the stupid red screen. Not one had the multi-color screen although I wish I had the multi-color screen..
    Senior Member Three Rings Alym's Avatar
    May 08 2012
    Stirling UK
    Nov 19 2012
    Mankato, MN
    Quote Originally Posted by Alym View Post
    Thats for an upgrade from MMI Basic to MMI High. We don't have MMI Basic in the US and we also couldn't tell what cluster type he had. If it was color or red. So that doesn't really help us.
    May 08 2012
    Stirling UK
    I thought he changed his cluster in it!?
    Resident Curry Muncher!
    Veteran Member Four Rings superman_006's Avatar
    Jan 14 2007
    Porsche 996 C2
    WV
    The a6 contains a red monochrome center screen if yours is a 2005 with or without nav. In 2006 it came the red screen if there was no navigation system untill 2009 which is when they stopped producing the basic 2G and the Basic Plus 2G MMI (well al the 2G). Plus is the same as the basic except it has rear door speakers and an amp. If you have Nav... you have the technogy package which has High 2G MMI which has the color screen (except 2005).
    Ive never heard of anyone trying to swap in a color for the red. Idk if its a plug and play or not
    2015 Audi Q5 S-line 3.0T
    Nov 19 2012
    Mankato, MN
    I don't think he did. He did remove it though.
    Our question is, what happens when you switch clusters? Is it a straight swap? Or do we also have to do some programming?
    Nov 19 2012
    Mankato, MN
    Quote Originally Posted by superman_006 View Post
    The US is different from UK or ROW. We all got MMI 2G High no matter what as far as I know. We don't have MMI Basic and if we do, I've never seen it.
    The thing is, its as if they randomly switched between color and red screens in their liking. Doesn't matter if you got Nav or not.
    Jan 14 2007
    Porsche 996 C2
    WV
    The color monitor requires MMI high, a new front controller and a radio, and dealer level software... and you have to have the correct part number for the cluster for mph/v6 or whatever you have
    Nov 19 2012
    Mankato, MN
    For the US (OP is in Michigan, and I'm in Minnesota), since we already have MMI high (All US A6's have MMI high), we don't need a new MMI system. We'd just need to find the right cluster but what would happen after that? Would it be a straight swap? And if it is, what kind of programming is needed?
    Established Member Two Rings cebo0650's Avatar
    Jun 09 2010
    Waterloo, ON
    It's certainly possible to swap the cluster. I have an 06 with NAV, and it already had the color screen but I swapped my cluster because I imported the car into Canada and the miles were bugging me.
    I bought a used cluster from Europe and had a dealer do the swap. You could technically do the physical swap yourself, but you'll need to take it to the dealer for the final step of coding and removing component protection. I also don't see why there would be an issue of swapping in a color screen cluster in place of the red screen one. Again, it will be a matter of re-coding and removing component protection.
    '06 A6 C6 Avant, Technology, Premium and Cold Weather packages, 18"s, Power Tailgate
    Nov 19 2012
    Mankato, MN
    Quote Originally Posted by cebo0650 View Post
    Thats good news.
    Can you recode the miles?
    Jan 14 2007
    Porsche 996 C2
    WV
    Idk, I just read where someone done it on a A4 and he first bought the wrong cluster (v6 instead of i4) and finally once he got the correct one he had to have the dealer program it. I" think" the programming is for the immobilizer which is built into the cluster. The color and red once seem to have the same information on it, maybe someone could swap out the screen itself, didnt see where anyone had done that yet though.
    May 08 2012
    Stirling UK
    I wonder if it's possible to buy a 2nd hand unit and just swap over the screen's!? Without having to change all the rest. Just un-solder the screen's and swap.. keeping your original mileage/rev counter/etc...
    Nov 19 2012
    Mankato, MN
    Doubt it. The color screen has a different layout.
    May 08 2012
    Stirling UK
    Without seeing the back of it I guess it's a guessing game... Screen might have a different layout but connections may be the same?
    Jan 06 2005
    Ann Arbor, MI
    His is a 2008 with factory Nav and Premium packages. I'm starting to think someone swapped out the cluster...or at least the LCD screen. He did buy it from a car lot, so who knows when/how/who did something to it.
    Jun 09 2010
    Waterloo, ON
    Thats good news.
    Yes, but the dealer won't do it for you. You'll need a piece of software called VAG-Commander and the cable that comes with it. It can be found on eBay and it not expensive.
    Jan 14 2007
    Porsche 996 C2
    WV
    You can only do the milege corrector once (with Vag-com) and it has to be forward and you have to start will less than 100K on it
    Nov 19 2012
    Mankato, MN
    Most clusters always come with less than 100k anyway.
    This sounds like a good project to take on.. Used clusters seem pretty inexpensive. The only thing is to get a dealer to program it.
    I wish someone had actually tried it to see the outcome.
    Jan 14 2007
    Porsche 996 C2
    WV
    im kinda intrested to see what happens if u would enter 999,999 for your miles then drive a mile to see if it zeros out from a roll over. No interested enough to do on mine
    Jul 17 2011
    Sin City, USA
    I have the red screen in my 09 and frankly dont see the advantage of going with a color screen if the information displayed is the same. Too much time, hassle and money to get color. Just my .02
    '09 C6.5 A6
    Veteran Member Three Rings MainlandMig's Avatar
    Apr 06 2010
    Atlantic City Metro Area
    the way i see it
    object 1 .. monochrome center LCD screen DIS
    object 2 ... more pixel color LCD screen DIS
    object 3 ... the whole cluster display which includes everything speedo dials etc
    swapping/removing just the DIS would likely need soldering but then what about the signal?
    something is generating the refined display signal.. something is generating the different color/shading of the open car door image...
    swapping out just the better DIS is like getting an HD TV but if the channel is not broadcasted in HD u get standard picture
    IF u got that to work .. u would still only get monochrome red color and no detailed shading ...just more pixels ...
    this reminds me about the park assist module... some cars were equipped with the module able to display vehicle image but they were coded to not utilize that feature ...but one could open it up with VCDS... maybe JUST MAYBE that can happen here ... likely a big stretch
    my guess is there is a improved DIS module somewhere ...maybe it is built into the cluster..maybe somewhere in dash
    looks like we need to look up cluster part #s and see where the change takes place and the differences of the two are.. see if it looks any different in back and if it has identical connections/plugs
    2011 A6 (C6/4F) 3.0 SC Q Prestige | Brilliant Black | Amaretto/Black Leather Walnut Trim | Side Assist
    APR Stage 2 | USP Motorsports Intake | ST Coilovers | StopTech Slotted w Hawk HPS | H&R F&R Sway Bars| B8S4 19 Tri-Spokes/Peelers
    Tints 50% FD, 35% RD, 20% C-pillar & Rear | Under Seat Drawers | 3M Glossy Black Side Markers
    Senior Member Three Rings Jimingle10's Avatar
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    I want more info my 05 has the red screen. I have the nav package with 2g high.
    If i buy a cluster with under 100K it can be rolled forward to my current mileage 150K?
    Nov 19 2012
    Mankato, MN
    According to the info we have so far, yes.
    Sent from my SGH-T889 using Tapatalk 4 Beta
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    theres 2 on ebay right now for pretty cheap...how do you tell if its a color DIS
    here are the ebay item #s
    230960961403
    231015134668
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    I have a 09 and have the red screen because I don't have navi. I think the models that have navi comes coloured.
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    Quote Originally Posted by ichi d View Post
    mine is the exception...i have the 2005 with navi but I dont think the color DIS was offered for 05
    Jun 09 2010
    Waterloo, ON
    Quote Originally Posted by Jimingle10 View Post
    230960961403
    231015134668
    Do you see how 230960961403 has sliver trim around the screen and the other does not? If you see the silver trim around the screen that's a color one.
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    im tempted to put an offer on the one if its color screen like you say. Looks like he can roll the mileage for you. If it's plug and play its just a trip to dealer for CP....
    Nov 19 2012
    Mankato, MN
    If you do decide to do it, please let us know know it goes!
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    bump.. just ordered this
    http://www.ebay.com/itm/110860470129
    mileage is under 100k. Gonna look around for info on how to roll mileage forward
    Senior Member Two Rings Cobra357's Avatar
    Sep 13 2011
    VW Jetta
    Brooklyn
    It can work but you need to get a color screen cluster and program the gateway unit by the glove box.
    ALL MOTOR 3.2...................
    Senior Member Three Rings SindreVjohnsen's Avatar
    Dec 21 2014
    Norway
    Well I got the color one in cluster, but the red shit in the mid -.- and that my gentlemen SUCKS....And cost about 1500 dollars to swap :((
    -Artic White Avant, 2.7 quattro
    - Audi A6 Avant , Shadow Line , ABT kit. (sold)
    Senior Member Three Rings skylinrcr01's Avatar
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Sorry to revive an old thread from the dead, but if someone for some reason has pictures of the backs of both display types, can you post them? I want to see how different they are. My monochrome LCD is really starting to bug me.
    http://i.imgur.com/KPi8p89.jpg
    2004 Mercedes E55 AMG
    2005 A6 Quattro 3.2 (Sold)
    2005 BMW K1200S
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    I have the color cluster at home I never used it. Ended up buying a C7. Its for sale if you want it. 96k on it
