You need to take out the gear-shift leather surrounding, together with the position indicator. Then take out the front ash-tray and its bottom section - there are two screws to take out. Under the centre arm-rest, in the CD compartment / drink-cup holder, take out the rubber bottom layer and unscrew the screw you find there. Then pull out the rear center vent and take out the large screw holding the center arm-rest. Pull it out a bit.
Then unsnap the sides of the entire centre console and put them aside. There may be some more screws elsewhere, which I can't remember. But you need to lift the rear part first, just a few inches, and then you can take out the front part of the console. Remember to unclip all the electrical connectors - parking brake, gear selector indicator, MMI controls, start/stop button if you have it.
Here is a link that has good pics.... You have to scroll way down to the last post
http://forums.audiworld.com/showthread.php?t=2832795
