Results 1 to 9 of 9
    Dec 04 2005
    chicago
    help with n80 purge valve part number
    So I would like to replace my purge valve on my 08 3.2l a5. I took out the valve, It has part number 06h906517 on it. Does any one know if its the same as the 06E906517 version? I cant find any info when I search for the H version that is currently in my car... they also look identical. Any help would be appreciated. Thanks!
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    06H906517 is not a valid part number. Either you're missing a letter on the end, or it does indeed say 06E906517.
    Shoot me an email if you can't figure it out and I can look it up when I"m in the office.
    Feb 09 2015
    I know this is an old thread but i have to replace the same part on an 09 3.2L A5. I have a picture of the part, the markings say " VW AG 06H 906 517 G ". Where can i find the hoses that connect to it also? One of them is really mashed where the connector clamps on and looks like i will destroy it once i try to remove it.
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Is there enough spare hose to cut the mashed end off and pull the hose up?
    https://www.germanautosupply.com/sto...ent-valve.html
    http://www.aliexpress.com/item/For-B...356340045.html
    May be worth asking one of the above or just buying from your local VAG dealership.
    Veteran Member Three Rings NuVega's Avatar
    Feb 06 2010
    Las Vegas, NV
    Sorry to bump an old thread, but I have a 09 A5 3.2L and was wondering what are the symptoms that you may have a bad purge valve? I think mine is on it's way out.
    Instagram: donomoko
    - 2014 S5 3.0T Prestige - : Plain ole S5 w/ a few cosmetic mods...
    Nov 16 2013
    Southeast
    When you first start the car the idle will be all over the place for about 20 seconds before it steadies.
    Veteran Member Four Rings ak_siberian's Avatar
    Jan 30 2015
    992C4S, T2 Touareg V8, Porsche Macan S, & Gehl turbo bobcat;
    20 miles NW Fairbanks, Alaska
    Has it thrown any codes? Could be your PCV (or oil separator) a more likely cause (in addition to the hose issue of course). What's your mileage?
    siberian
    The best long distance runners eat raw meat, run naked and sleep in the snow
    Feb 06 2010
    Las Vegas, NV
    Quote Originally Posted by ak_siberian View Post
    siberian
    No codes or CEL, but RPM would idle sometimes at 900-1000 at a stop light, started this past Saturday, happened once again on Sunday, then today nothing, idle would be normal. I'm up there, 180K miles.
    Instagram: donomoko
    Jan 30 2015
    This might help:
    http://www.audizine.com/forum/showth...80-purge-valve
    Keep us posted
    siberian
