Radiator fan isn't working but the the car isn't overheating. The fans used to work all the time even when the car was idling at start up. I replaced the coolant temperature sensor that is between the engine block and the firewall not now the fans don't work at all. I rev the car high for a few minutes and the fans don't turn on.
I got a coolant leak on the the thermostat and it started spraying all over the engine bay.
I idle the car and i rev it high but the fans do not engage, unless i turn the ac on. Is there something wrong with the fans or is this normal? Which sensor engages the fans?
I am afraid the fans not working created a pressure point that caused a crack on the thermostat.
