Results 1 to 8 of 8
    Active Member Two Rings waqeezee's Avatar
    Jul 15 2013
    Volkswagen Bora
    London, UK
    B6 Brake Warning Light
    Hi y'all... I wonder if anyone else has experienced this problem:
    Recently I've started getting a brake warning light flash in my dashboard & 3 beeps (which sound the same to the one you hear when your fuel is low) every time I turn left in my B6... unless I go very slowly.
    Any ideas what could cause this apart from low brake fluid levels...?
    The warning light is similar to this...
    Feb 13 2004
    Silicon Valley, CA
    IIRC from my B6, that is brake pads are worn
    Kevin - Moderator, Audizine
    Veteran Member Four Rings krew53's Avatar
    2023 RS6 - 2013 B8.5 S4 - 2003 B6 1.8BT quattro
    Simi Valley, CA
    Also check your brake fluid if you are just getting the beeping and flashing light
    Jul 15 2013
    Volkswagen Bora
    London, UK
    Thanks for the response guys... much appreciated.
    Jun 08 2007
    Orlando, Fl
    Brake pad wear indicator telling you that you need new pads.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Jul 15 2013
    Volkswagen Bora
    London, UK
    Quote Originally Posted by A4Dit View Post
    Would that be front pads or rear pads... or all of them...? Brakes actually seem to work fine.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by waqeezee View Post
    Only the front pads have wear sensors. Take a close look at the front inside pads. The're the only ones with the "sensor". The sensor is simply a wire loop embedded in the brake pad. Once the pads wear down enough to sever the wire loop the brake pad wear indicator comes on.
    Jul 15 2013
    Volkswagen Bora
    London, UK
    Something weird has happened... or maybe it isn't weird... I dunno. But I topped up my engine oil & now the brake warning doesn't come up anymore... nor does it beep. Hmmm.
