Results 1 to 13 of 13
    Veteran Member Four Rings audi_nightrider's Avatar
    Oct 08 2009
    12 more rings
    Northridge, CA
    Headlight issue - not a typical dipped headlight thread
    I apologize if a similar thread has been discussed and solved before.
    So problem is I can't quiet figure out whether it's the bulb or the ballast is going out. I'm hoping that its def. not the ballast....
    It's the passenger headlight that is giving me trouble, it turns on but will turn off within 5 minutes. It will turn back on again if I turn the light switch on and off but it'll turn off again within 5 mins. Another thing that might help is that the temp color is different than the driver side. Instead of the factory stock 4300k temp, it is more white and I can say its about 6000k.
    Any help is appreciated, want to resolve this asap as I don't want to deal with fix it ticket.
    P.S. its a 2010 Audi Q5 Premium Plus and S-line if it matters(I know it doesnt lol)
    TIA!
    Silver 02 Audi A4 1.8T Q MT
    '11 2.0T Audi A5 Premium Plus quattro...Auto GONE
    C7 S7 ESTORIL BLUE 4.0 TT Prestige GONE =(
    Veteran Member Three Rings Dcass08's Avatar
    Jul 21 2011
    Rochester NH
    I think the higher you go temp wise the more blue it gets. Have you tried swapping left and right to see if the problem moves?
    Oct 08 2009
    12 more rings
    Northridge, CA
    Actually haven't tried anything yet. Def. gonna try that tonight.
    just wanted to get some feedback in case someone experienced the same issue/problem before.
    Oct 08 2009
    12 more rings
    Northridge, CA
    Well....haven't done anything due to the fact that I read somewhere that the automatic lever is easy to break. And I need to have a vag-com to change the bulb?
    Don't want to remove anything yet before I make sure that it's easy to swap the bulbs myself without the possibility to mess up anything...mechanically or electronically.
    taking it to the dealer is an option but I know it's gonna cost me about 2-3 times more.
    TIA!
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    Quote Originally Posted by audi_nightrider View Post
    TIA!
    You do not need VCDS (vag-com)
    Not D3S xenon already halogen bulb but very similarly replacement
    http://www.carcarekiosk.com/video/20...ights/highbeam
    Senior Member Two Rings migsan's Avatar
    Mar 16 2007
    Audi Q5 2.0 TDi 170 hp
    Portugal
    For the description I will tell thats a bulb problem.
    You should swap the bulbs and see if the problem goes to the other headlight.
    Q5 2.0 TDi 170hp Quattro (MY09) Bi-Xenon, MMI 3G+, Front & Rear Parking Sensors, Full Leather & electrical seats, Folding mirrors, Heated front seats
    Mods:S-Line Flat-Bottom SW, S-Line Gear knob, Debagde, Interior light by Leds, S-Line Rear, Front & Sides, Blackline Grill, Tinted window, S-line Headliner interior in black colour, 20x9 ET33 OEM Q7 Wheels, License Plate OEM Leds, Black Mate rear badge & Windows surround
    Oct 08 2009
    12 more rings
    Northridge, CA
    can't quiet figure out how to remove the d3s bulb -_-
    do you just pull it straight out or there's a clip holding it in place? sorry tried searching but can't find anything
    Oct 10 2010
    Sarajevo, BiH
    Video from post #5 and this
    Jul 13 2013
    Atlanta
    If the side that is creating issues is color shifting in such a new car, I would suspect a failing bulb. Generally a HID Bulb (D1S, D2S, etc) that colors shifts prematurely is a failing bulb. That being said, a ballast should not be shutting off the bulb (unless it senses a major issue, such as a D2S in a D3S/D4S socket). There may be a connection issue within. If you want to confirm it, you will need to swap ballasts side to side. A simple rule with HID systems...if the problem stays, it's the bulb. If the problem follows it's the ballasts.
    Audi uses a D3S bulb, which is mercury free. If you want to increase output, I would look into a D2S bulb (you can notch the bulb to fit a D3S projector), however you may need to modify the bulb holder. I recently picked up a 2014 Q5 TDI and I am about to pull the headlights and do a clear lens swap, convert to a D2S (Osram 66240 SVS) and Denso Ballasts.
    Oct 08 2009
    12 more rings
    Northridge, CA
    ^^ good to know, thanks for the inof. I'm pretty happy how bright the the D3s are as it is. Don't need anything brighter than that.
    I ended up just getting a set of D3s 6000k to match the LEDs at a reputable local shop
    Couldn't be happier how much whiter and slightly brighter they look from the OEM lights.
    Link of the bulbs:
    Clicky Click
    Mar 16 2007
    Portugal
    Quote Originally Posted by 2000UZJ View Post
    Please share more info about this mod when done.
    Mar 16 2007
    Portugal
    The new lamps solve your issue?
    Oct 08 2009
    12 more rings
    Northridge, CA
    ^^ Yessir, both lights are working perfectly fine.
    I guess the problem I described was just a symptom of a failing lamp and not the ballast.
