Results 1 to 25 of 25
    Established Member Two Rings dgladden's Avatar
    Oct 24 2012
    North Charleston, SC
    Immobilizer light flashing and no starting
    Ok so I drove my car to work today, parked it and went inside. Nothing unusual at all. I come out of work and go to star my car and it cranks and runs for a second or two. I realize the immobilizer light is flashing orange at me. I got a ride home to get my computer and other keys and come back. The spare doesn’t work and neither does the little plastic one. (Forget it technical term) I scanned the car and got the fowling codes listed below. Now I am at home and my car sits at work. What is my next step from here? I have done some searching but haven’t had to much luck. Any help would be amazing. Thanks.
    VCDS-Lite Version: Release 1.2
    Thursday, 11 July 2013, 14:51:21:18607
    Control Module Part Number: 8E0 909 518 F
    Component and/or Version: 1.8L R4/5VT G 0003
    Software Coding: 0016501
    Work Shop Code: WSC 78901
    VCID: 3319D460122D
    1 Fault Found:
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 008 - Implausible Signal
    Thursday, 11 July 2013, 14:52:17:18607
    Control Module Part Number: 8E0 920 950 H
    Component and/or Version: KOMBI+WEGFAHRS. RB4 D26
    Software Coding: 02200
    Work Shop Code: WSC 07318
    VCID: 2E2FC514F90F
    Additional Info: WAUJC68EX2A205141 AUZ6Z0A0346910
    1 Fault Found:
    01128 - Immobilizer Pickup Coil (D2)
    35-00 - -
    2002 B6 A4 MT- K&N air filter, APR Snub Mount, Unitronic 1+, 710N, VCDS Lite
    Jan 25 2006
    A4 2.0T
    MD
    Have you installed any electronics in your car recently like an RNS-E or anything of that sort?
    Oct 24 2012
    A new battery a week ago.
    Oct 24 2012
    Would recoding the keys help? If so how do I get the pin number?
    Veteran Member Four Rings elewsader's Avatar
    Mar 24 2006
    2003 A4 1.8T Avant MTQ, 2001 Audi S4 Sedan
    Central, IL
    Quote Originally Posted by dgladden View Post
    look up member "imnuts" he's got a very well documented procedure in his signature.
    but immobilizer coil may need replacement, did you check ross-tech yet? http://wiki.ross-tech.com/wiki/index.php/01128
    *little plastic key is your valet key.
    Ed
    why say lot word when few word do trick.
    Oct 24 2012
    This is what Ross-Teck says:
    Possible Symptoms
    • Immobilizer Warning Light flashing
    • Immobilizer active (Engine shuts OFF after 2-3 Seconds)
    Possible Causes
    • Wiring and/or Connector(s) from/to Immobilizer Pickup Coil (D2) faulty
    • Immobilizer Pickup Coil (D2) faulty
    • Immobilzier Control Module faulty
    Possible Solutions
    • Check Wiring and/or Connector(s) from/to Immobilizer Pickup Coil (D2)
    • Check/Replace Immobilizer Pickup Coil (D2)
    o Check Measuring Value Blocks (MVB)
    Special Notes
    • Pickup Coils for Immobilizer 2 and 3 Systems should read ~23.5 Ohms.
    Has anyone on ever replaced a pickup coil, or are there any write ups on how to replace it?
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    I've read of others having a problem with the pickup coil. Given the fault code, I'd guess that is the problem as I think a bad key pair returns a different fault code. You could try repairing the keys with the immobilizer, but I don't think that will work if the coil is bad. I'd grab a multimeter and check the resistance, or do it with VCDS if possible. It looks like the coil may be part of the ignition switch, if that's the case, here's a DIY
    Oct 24 2012
    Sep 16 2010
    Central Wash
    You shouldnt even need to re-pair the keys/immo after replacing the pickup coil I don't think. But if you do:
    https://sites.google.com/site/imnuts/
    Oct 24 2012
    Ok I just replaced the ignition switch. That didn't help. Any ideas on where to go from here?
    Oct 24 2012
    I just called my local stealership and they told me I need to order a complete new switch with the barrel and the new pickup coil plus one new key for 260. The said I can't just by the pickup coil. Does anyone know if this is true or not?
    Aug 12 2009
    Dirty Jerz
    I think the coil is only available as part of the ignition switch, but you may be able to separate the switch and coil and install the new coil on the old switch. Also, if you were getting a new key, you'd need a new door and trunk lock that matched, unless it was coming setup for your VIN, in that case, I think you can order the switch without a key from what I could find.
    Oct 24 2012
    I guess it's VIN matched they said it will take 3-5 days to get it in from Monday. But my biggest convern is will this fix my problem? Could this be a ECU problem. It's just so wierd that it came out of nowhere.
    Sep 16 2010
    Central Wash
    It's not ECU, it's the pickup coil and pretty sure it's separate from the ign switch, but comes WITH the switch?..never looked it up individually. But yes, the IGN switch is ordered by vin# cut to the key you already have.
    Oct 24 2012
    Ok so I just replaced the pickup coil. I am still getting the same problem. Any ideas? I am clueless right now.
    Oct 24 2012
    So I just did an full auto scan. Man this is frustrating. This thing is my only car. Any help would be greatly appreciated.
    Wednesday, 17 July 2013, 16:48:13:18607
    Chassis Type: 8E - Audi A4 B6
    Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56 ,57,65,67,69,75,76,77
    Address 01: Engine Labels: Redir Fail!
    Controller: 8E0 909 518 F
    Component: 1.8L R4/5VT G 0003
    Coding: 0016501
    Shop #: WSC 78901
    VCID: 3319D460122D
    1 Fault Found:
    Readiness: 0110 1101
    Address 03: ABS Brakes Labels: 8E0-614-517.LBL
    Controller: 8E0 614 517
    Component: ABS/ESP front 1726
    Coding: 04275
    Shop #: WSC 06435
    VCID: E5BDFA386C79
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-00 - -
    Address 08: Auto HVAC Labels: 8E0-820-043.LBL
    Controller: 8E0 820 043 F
    Component: A4 Klimaautomat 0712
    Coding: 00000
    Shop #: WSC 63351
    VCID: 243B273CA7C3
    4 Faults Found:
    01274 - Air Flow Flap Positioning Motor (V71)
    41-10 - Blocked or No Voltage - Intermittent
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    30-10 - Open or Short to Plus - Intermittent
    01206 - Signal for Duration of Ignition Off Time
    27-00 - Implausible Signal
    00474 - Control Module for Immobilizer
    49-00 - No Communications
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
    Controller: 8E0 907 279 E
    Component: int. Lastmodul USA 0305
    Coding: 00003
    Shop #: WSC 63351
    VCID: 341BD77C1723
    1 Fault Found:
    Address 15: Airbags Labels: 8E0-959-655-84.LBL
    Controller: 8E0 959 655 A
    Component: Airbag 8.4E 4000
    Coding: 0010607
    Shop #: WSC 63351
    VCID: 351DEA781C59
    No fault code found.
    Address 16: Steering wheel Labels: 8E0-953-549.LBL
    Controller: 8E0 953 549 L
    Component: Lenksáulenmodul 0308
    Coding: 00041
    Shop #: WSC 63351
    VCID: 3C0BFF5C3F73
    1 Fault Found:
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
    Controller: 8E0 920 950 H
    Component: KOMBI+WEGFAHRS. RB4 D26
    Coding: 02200
    Shop #: WSC 07318
    VCID: 2E2FC514F90F
    1 Fault Found:
    35-00 - -
    Address 45: Inter. Monitor Labels: 8E0-951-177.LBL
    Controller: 8E0 951 177
    Component: Innenraumueberw. 0504
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBA98C008A9D
    1 Fault Found:
    01463 - Alarm triggered by Sensor for anti-theft alarm System
    43-00 - Closed
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
    Controller: 8E0 959 433 T
    Component: Komfortgerát T5B 0617
    Coding: 11788
    Shop #: WSC 63351
    VCID: 42F781A45D97
    7 Faults Found:
    01134 - Alarm Horn (H12)
    01616 - Signal Wire to Interior Monitor
    49-10 - No Communications - Intermittent
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01574 - Alarm triggered by Door Contact Switch; Right Rear
    35-00 - -
    Address 56: Radio Labels: 8E0-035-1xx-56.LBL
    Controller: 8E0 035 195 A
    Component: symphony II NP2 0007
    Coding: 00001
    Shop #: WSC 00000
    VCID: 253D3A38ACF9
    1 Fault Found:
    00879 - Connection to Speaker Front Right
    36-10 - Open Circuit - Intermittent
    End --------------------------------------------------------------------------------------------------
    Aug 12 2009
    Dirty Jerz
    Coding: 00000
    Shop #: WSC 63351
    VCID: 243B273CA7C3
    4 Faults Found:
    Coding: 00041
    Shop #: WSC 63351
    VCID: 3C0BFF5C3F73
    1 Fault Found:
    If I had to guess, based on other codes stored for the immobilizer and possible solutions, this is where I'd look.
    Oct 02 2006
    Wadsworth,OH
    Did you try recoding your keys? My car will sometimes crank, start for 2 seconds then shut off. I'll have to do this 1-3 times then usually it starts and runs no problem. As of late my immobilizer light has been flashing at me while idling and some times while driving.
    Only happens sometimes and I haven't put much effort into figuring it out. I might try and have the keys reprogrammed and see if it makes a difference.
    Jason
    Oct 24 2012
    I haven't tried that yet because I am not getting ant codes that say the keys are the problem. I just pulled my ECU out and I am mailing it off tomorrow to have the immoblizer disabled.
    Sep 16 2010
    Central Wash
    Dude--- the KEY (chip contained inside) is one of the main parts of the immobilizer. But, more likely it's the pickup coil on the ign switch. Personally I would have done the Immo defeat at the cluster- there's a certain way to do it at the ECU to not get a flashing IMMO light with the annoying beep. The hierarchy of the Immo goes: Key to Ign switch to Cluster and finally the ECU gets the OK from the cluster.
    If the defeat isn't done right the cluster still wont get an OK from the ign switch and you'll be annoyed. It'll work, but it'll be annoying.
    Oct 24 2012
    I have already installed an new pickup coil. And that didn't help at all. How do I do the defeat at the cluster?
    Sep 16 2010
    Central Wash
    Just send it to someone (Tom / Mpower ) to edit the EEprom. I really don't see the benefit of doing it at the ECU (unless it's part of a tune/ package) when it's so much easier to do it at the cluster.
    Tom (or half a dozen other guys here) can do it, Pm him, ( user name ' Mpower ' ):
    http://www.speedosolutions.com/
    I'd offer to do it, but the 'adapter' cable I used to use to connect right to the cluster went bad a long time ago, and since then I lost all my info on what the Immo address / values are supposed to be in the eeprom.
    Oct 24 2012
    Ok so I got my ECU back and the car runs now but like you said rollerton its annoying. My hazards are just going off. Is there any way I can turn the alarm hazards off via rosstech. I really don’t want to have to mail off any more parts I can’t afford to have any more down time with the car.
    Oct 24 2012
    Well if anyone cares I found a solution for my problem. I have a 2013 MS3 in my driveway now if anyone is interested in my A4 make an offer as is.
    Veteran Member Four Rings gmudan's Avatar
    May 03 2009
    A4%20B6/B8
    Arizona
    LOL that is the best reply i have ever read.
