Results 1 to 24 of 24
    Veteran Member Four Rings doowopaudi's Avatar
    Aug 10 2011
    North Whittier
    Adaptive Brake Lights vag mod
    Has anyone seen what the adaptive brake lights do? I tried having someone capture my brake lights after driving by really fast and braking, but there isn't anything different happening and I know that the vag mod has been enabled.
    ::2010 A4 Premium+ Quattro::6SMT::Meteor Gray Pearl Effect::35% 3M tint all around::Vag mods::debadged::RS4 replica grille w/ fog grilles::LED interior lights and lic. plate lights::ST Coilovers::19x9 OEM A5 Peelers::245/35/19 Achilles ATR Sport::Underseat Storage Bins::Zubehor Diffuser::Door Handle storage bins::LED reverse Lights::
    Former: 2008 A4 S-line::2007 Mazdaspeed3::1991 VW Cabriolet
    Established Member Two Rings rfootball7's Avatar
    Sep 10 2010
    Bugatti Veyron SS
    I have them enabled on my 2013 A4. When you make a panic stop, the brake lights flash super fast like a strobe. This is only activated when you brake hard enough that the ABS kicks in.
    www.MotorAnnex.com
    For The Automotive Obsessed.
    2013 A4 Premium Plus | Brilliant Black | 6-Speed | Sport Package | Navigation | Advanced Key
    Mar 26 2012
    Charlotte, NC
    Do you need to have LED brake lights or regular ones on my 2009 will work ?
    Aug 10 2011
    North Whittier
    Quote Originally Posted by SDF1 View Post
    Good question. I have LEDs, so I wonder if it works with those.
    Sep 10 2010
    Bugatti Veyron SS
    This mod will only work on a car with LED's. To test his safely, have someone watch you accelerate to about 60-70 mph, and stand on te brakes for a full panic stop. The whole test should only take about 7-8 seconds.
    www.MotorAnnex.com
    Veteran Member Three Rings BarEaterB8's Avatar
    Nov 13 2011
    2009 B8 A4 - 1985 Porsche 911 - 2016 BMW M2
    I did this mod too and was wondering what it looked like. Anyone have a video?
    Aug 04 2010
    Queenz/Westchester
    You have to pull the e-brake and hold for 3 sec. It will bring the car to a full stop.
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    Quote Originally Posted by shonseb View Post
    If I have an emergency, I doubt I'll remember that. 3 seconds is an eternity during an emergency.
    '11 S-Line A4 Avant
    '98.5 A4 2.8Q sedan retired after 14 years of service
    Aug 04 2010
    Queenz/Westchester
    It will start to brake immediately, but it will release if you don't hold it down (or actually keep it pulled up). The lights will flash after the car has fully stopped to warn drivers behind you. Obviously you can hit your brakes first, then pull the e-brake also.
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    So the lights only flash when used with the ebrake? I can't imagine ever doing that, unless there's a catastrophic failure of the braking system (in which case I'll probably be more concerned about the poo in my pants than blinking my lights at other motorists).
    '11 S-Line A4 Avant
    Sep 10 2010
    Bugatti Veyron SS
    I dont believe this. I had a friend follow me, and i literally slammed on the brakes 100% going around 60mph and the adaptive brake lights came on.
    www.MotorAnnex.com
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    Quote Originally Posted by rfootball7 View Post
    This works on just about any audi since the b7's, including non-led tail light cars.
    i had them enabled on both my b7 a4 and b7 s4
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Sep 10 2010
    Bugatti Veyron SS
    Hmm. I couldnt get this to work on my 2010 A4 non-LED.
    www.MotorAnnex.com
    Aug 04 2010
    Queenz/Westchester
    Re: Adaptive Brake Lights vag mod
    You can believe me or not, but for others who are having trouble seeing it in action this is the way you can do it. I had trouble so I did it this way and it works. I never said you couldn't do it the normal way, but in the past others have had problems getting it to work so this method was suggested and it does work. It even works on the b8.5's that have the radar in the front to avoid collisions. I vag com'd another guys s4 and afterwards we went for some spirited driving. While accelerating if he got too close to the guy in front of him, his car would brake hard for a split second and his hazards and LEDs flashed.
    Sent from my Nexus 4 using Tapatalk 2
    Mar 26 2009
    SLC, UT
    i have that on my 09 prestige and it has almost killed me while changing lanes on the highway so i disabled it
    if you change lanes and are within 5 -7 ft of his bumper while lane changing it will panic apply brakes. it has to be the most unsettling feeling ever having a car brake and you not initiate it
    '21 SQ5
    Dec 02 2012
    TX
    Does anyone have video of this in action on a non-LED car? I enabled it on my Avant but would like to know what it looks like.
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    Quote Originally Posted by Speebs View Post
    You mean like this one?
    '11 S-Line A4 Avant
    Dec 02 2012
    TX
    Quote Originally Posted by dscline View Post
    I couldn't tell if those were LEDs or not, I assumed not since that video is not from North America. If that's what they look like, then great!
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    They don't LOOK like LEDs to me.
    '11 S-Line A4 Avant
    Dec 02 2012
    TX
    Yeah you're right- I watched the video 3 or 4 times but for some reason wasn't thinking clearly. They definitely look like the regular lights.
    Aug 06 2012
    Parker, CO
    I have this activated on my '13 allroad and have not been able to get them to activate on a panic/emergency stop. Like someone said earlier with the e-brake...... I can't see myself doing that in an emergency stop.
    Vehicles: '16 VW Touareg, '13 allroad. '06 VW Touareg
    Jan 22 2016
    Audi TT and Touareg
    Orlando, FL
    I LOVE THIS! :) I want it on my S4... heh
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    i think we can do this through carista
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Veteran Member Three Rings B44's Avatar
    Oct 27 2014
    Epic
