Results 1 to 40 of 43
    Jun 18 2012
    B8.5 navigation way off..calibrate?
    So over the past two weeks my navigation seems to not be able pinpoint my location, it thinks I am located 1/2 mile from where I am or off roading. I have rebooted via 3 finger salute several times no avail. Don't think there are any solar flares either.
    Anyone have any ideas what could be going on or how to reset/calibrate?
    Veteran Member Four Rings jauri's Avatar
    Sep 20 2012
    Sagaponack
    ive been having problems as well. it thinks my car is always going sideways... whats the 3 finger salute?
    "i [am] fluent in 14 different ebonic dialects." -over9000-
    "I'm Gnna fuck the shit out of dolphin." -aka5-
    Jun 18 2012
    Yeah that happened to me tonight as well. The 3 finger salute is just a way to reboot the MMI while it is running...menu + center button + top right
    Feb 25 2013
    MI
    Strange...are you by any chance using the 3G connection? Wonder if it uses cellular triangulation to help out the GPS. Also, is your compass correct (although not sure rearview mirror compass is connected in anyway).
    My understanding is nav systems cross reference GPS data with map data to pinpoint your exact position and then use dead reckoning. So there's a distinct difference between not being able to initially locate you, and just having the car float off sideways while driving. It should get a better reference with the map data if you're driving somewhere with lots of turns. I suppose it could really suck in the boonies, just GPS with these commercial grade receivers is pretty bad.
    May 19 2013
    Stockton, ca
    I have also had this happen to me. It literally showed me driving through a field.. I was on the freeway so be the time I came to my destination.. I was a full town away the opposite direction according to my nav. It later reset and came back to normal ever since. I do have the 3G tmobile chip running if that matters. 2013 model prestige.
    Feb 25 2013
    MI
    Weird...if the error builds up that bad then it sounds like a problem with the GPS, either receiver or antenna. You haven't done a metallic tint or anything? Messed with the fusebox or cars electronics?
    Jun 18 2012
    I have ceramic tint, and recently put a ptel sim in..
    Jul 18 2013
    United States
    I just started having the same problem. When I start the car, nav has me in the wrong place, and then has me moving in the wrong direction. Compass on nav is also 180 degrees off (but rearview compass is correct). Tried the three-finger salute, with no luck. No tint or electronic mods. Any self-help that might fix it, or do I have to get in to the dealer?
    Veteran Member Four Rings RickFLS4's Avatar
    Sep 21 2012
    2012 Audi Q5
    Palm Beach County, FL
    Quote Originally Posted by Gotchaa View Post
    I recently added a ptel SIM too but have not seen this issue (yet).
    2015 BMW M4
    Past: 2013 S4, 2011 A6 3.0T (accident victim), 2008 Lexus LS-460, 1998 Lexus GS-300, 1994 Lexus ES-300, various GM/Ford/Chrysler cars prior to 1994
    Feb 25 2013
    MI
    One idea is to try and poke around the MMI hidden menu, and maybe try to reset some GPS settings? But a dealer visit might be order.
    Jun 12 2013
    Phoenix, AZ
    I get this issue 4 or 5 times a week! Here's a picture of me driving through a lake
    I posted in a few places with no solution. Planning to check it out with the dealer at my 5k service next month
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    I would visit the dealer. The antenna might be flaking out.
    Something that used to work was to drive in a figure eight a few times at low speed (just creep along). This sometimes moves things back into alignment.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Feb 08 2013
    2017 Corvette Z06; 2007 Ford F-150; 2004 Honda RC51
    Sammamish, WA
    I had the same problem just this past weekend. Driving up I-5 to I-90, the carat was well off the freeway and turned slightly. I tried an MMI reset twice with no help but after about 15-20 minutes it snapped back to the correct location. Haven't noticed it since but will definitely be watching for it as it seems that others are seeing it as well. Does Audi/Google push updates to our cars? If so, maybe we got a bad one?
    Mike
    2013 Premium +, Monsoon Gray, S tronic, sport diff, B&O, 19" RS4 reps, black on black interior, carbon inlays
    Mods planned: seeing doctor tomorrow about a lead foot prosthetic
    May 28 2013
    detroit
    This happened to me when I traveled to Toronto. the car is a US car. I chalked it up to it being about 4 stories below ground in a parking garage overnight. It was totally incorrect, and I reset the system 3 times. eventually it figured itself out, and hasn't happened again.
    Feb 25 2013
    MI
    Quote Originally Posted by dparm View Post
    +1 on antenna.
    Established Member Two Rings webvictim's Avatar
    Jan 07 2013
    San Jose, CA
    I was on my way to work the other day and noticed that the navigation thought I was driving a full 400 feet to the left of where I actually was - good job it wasn't right or I'd have plunged into the marshes. I think I've seen this once before but it seems to rectify itself quickly. I've also had the same issue on my phone before.
    Veteran Member Four Rings helix139's Avatar
    Apr 21 2010
    Florida
    Quote Originally Posted by drob23 View Post
    the hidden menu is not something you want to poke around in and reset settings
    2011 S4 Premium Plus 6MT, Sepang Blue Pearl, Black Silk Nappa, Sport Diff, B&O, B8.5 MMI 3G+ Nav, Ti Pkg
    APR Stage 2+ Stock/93/100/Valet, Eurocode Alu Kreuz, Eurocode USS Sways + End Links, Eurocode Meisterwerk SSK, Roc Euro Intake, Apikol Rear Diff Mount, Fast Intentions Exhaust, Escort 9500xi, Laser Interceptor, P3 Vent Gauge, VCDS
    Feb 08 2013
    Sammamish, WA
    Quote Originally Posted by helix139 View Post
    Word! Don't play around in there unless you absolutely know what you want to change, why you should change it, and the expected/intended result. I would definitely not "poke around...and maybe try to reset some GPS settings".
    Jun 18 2012
    The hidden menu is for real men, I go green daily.
    Jun 18 2012
    Quote Originally Posted by mcoomer View Post
    There were a few interesting settings there, but nothing to calibrate. It has been fine since I rebooted the MMI and toggled a few items. I am chalking it up to solar flares.
    Sep 05 2013
    Nebraska
    My GPS shows that my car was hundreds of miles away heading in a completely different direction. I was able to move the cursor to the same county where I am located but still 20+ miles from my actual location! The directional indicator in the mirror is accurate but definately not on the GPS screen or on the dash cluster
    Veteran Member Three Rings MarcWinkman's Avatar
    Jun 21 2013
    DE
    My car started doing this as well yesterday. I'll have to keep an eye on it over the next couple of days to see if it rectifies itself.
    Jun 21 2013
    DE
    Oddly after my five mile coffee run this morning, my navigation appears to be back to normal. Strange.
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    It's North Korea, they figure if they mess with our gps driving directions we will never get to work and thus can't remain the evil empire!
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Active Member Two Rings Soulsaman's Avatar
    Nov 15 2012
    New York, NY
    What mine has done twice, is tell me go around the the block over and over. Is that a Google maps screw up or the MMI?
    2013 S4 Prestiege S-tronic / Brilliant Black / 19" Peelers w Summer Tires / Black Nappa Leather interior / B&O Sound System / Sport Differential / Adaptive Damping Suspension / Carbon Atlas Inlays / Rear Side Air Bags / 3M Clear bra / Opti-Coat 2.0 / Supercharged Badges
    Jun 12 2013
    Phoenix, AZ
    Finally took my car in for the 5k mile service and asked them to fix this - I see this at least a couple of times a week. As expected, the dealer couldn't do anything because it wasn't doing this at the time I took it in - the pictures of my GPS showing me in the middle of the lake wasn't enough proof I guess. They mentioned it might not have had enough satellites to get a good location - not too many trees here in AZ to obstruct the satellites for my full 26 mile drive home from work! They want me to look up how many satellites I'm locked too next time it happens. Anyone else with the issue may want to do the same - hit route, scroll to the top, select, scroll to the top - shows # of satellites.
    Feb 03 2014
    Nor Cal Bay Area
    Has anyone been able to get this issue addressed yet? I just dropped mine off at the dealer last night. 2013 S4. I've only had the car for a few weeks and have had the same issues regularly since I picked it up....nav shows me driving over buildings, in the bay, in the mountains, etc. Then suddenly it's fine for a little while. The satellite lock was at 0 all day yesterday, but it was still tracking me properly. When I got to the dealer, they scanned it and it came back with no faults. So they will be doing further scanning to try to diagnose the problem. He said that they would have a tech in my car and a tech in a good car drive around together and do comparison scans to try to isolate the issue.
    Sep 21 2012
    2012 Audi Q5
    I had it happen a couple of times but never brought it in for service because it went away after I parked overnight and started the car again in the morning.
    2015 BMW M4
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    This started happening to me, I was headed to SF and showed me crossing the bay and straight to the Pacific. I didn't know that S means submarine
    Has anyone found a solution to this? As usual, dealer is clueless...
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    Quote Originally Posted by RWD2quattro View Post
    This is a known hardware flaw. You need your 5F module replaced with redesigned hardware. I had this issue last year and it's all fixed now.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Apr 05 2012
    Earth
    Oh this is good info. I've had the problem off and on with my 2013. The dealer just shrugs their shoulders and says it works fine for them. I'll try mentioning this next time. Is there any kind of documentation I can tell them to look up?
    Sep 05 2012
    Mine does this for a few minutes after pulling out of an underground parking garage. Figured that's normal.
    2013 S4 Premium Package (Canada; like US Prestige) / Phantom Black Pearl ext / Nappa Black&Magma int / B&O, Nav, S-tronic DSG, Sport Diff, Michelin Pilot Sport 4 S wrapped around scuffed up 19" potato peelers / 3M See-through brassiere // GIAC/AWE Stage 2 + TCU tune - CTSTurbo Intake // Winter mode: 18" Nokian Hakkapaleno? R2 on RTX Ingolstadt gunmetal wheels (B7 RS4 knockoffs)
    Feb 03 2014
    Nor Cal Bay Area
    On mine, the dealer finally ended up changing the antenna and that fixed the problem. Also, when crossing the bay to and from SF on the new span, mine still shows me in the water because I have not updated the maps. System doesn't recognize the new bridge.
    2013 B8.5 S4 Prestige | Glacier White Metallic | DSG | 19" Peelers | Black leather/alcantara | Sport Diff | B&O | AWE Exhaust w/Resonated DPs | AWE S-Flo Intake | Sun Tek Clear Bra
    Veteran Member Four Rings Pilfer's Avatar
    Dec 13 2012
    To the Bay Area
    Quote Originally Posted by Musubi View Post
    I have Audi connect and Google maps still shows me in the bay on the new bay bridge span. I guess it should update periodically through google maps or do I need it to be done at Audi?
    996
    Model Y
    Dec 29 2011
    The Bay
    Quote Originally Posted by superswiss View Post
    Awesome, thanks for the info. I'll ping dealer again during my 25K visit.
    Sep 05 2013
    Nebraska
    5F module... Does it have a different name? Not getting many hits on Google about it
    Jan 07 2013
    The 5F module is the main MMI module. Contains the CPU and everything. It's basically a whole new MMI. The GPS signal issue is caused by the MMIs close proximity to the AC and faulty insulation between them. Following is the info from my invoice. It's a widespread issue affecting all models with the 3G+ MMI, including early 2015s. You can open a case with AoA if your dealer can't help you. AoA knows all about the issue.
    Oct 02 2013
    Redstone, CO
    Ok, I give up. I've heard of this hidden menu many times. Is accessed only by VAG-COM? What's useful in there?
    Also, seems like half the posters on this board are from the Bay Area yet our Regional section is dead and we have no meet ups. WTF? As you were....
    2014 S4 Estoril Blue, Black Opt, 19" Rotor, Side Assist, Carbon Inlay, B&O Sound, MMI/NAV, Rear Camera, Advanced Key, Supercharged badges, H&R OE, Track+ Spacers, 10/15mm, otherwise stock.
    Dec 29 2011
    The Bay
    Awesome, thanks for this info. I will show this to my SA.
    Apr 24 2014
    Chicagoland
    Quote Originally Posted by levigarrett View Post
    Not sure if you serious but here it is:
    Search for "audi hidden menu" (it's also green) and you'll find out what's useful. You will need VAGCOM to enable it. GL
