Results 1 to 17 of 17
    Jul 29 2012
    orlando florida
    Audi A4 with a V8 4.2 swap
    Hey guys I had my b7 a4 for 3 months now and looking for more power. I thought about doing a full build on the 2.0t. plan B. is to do a 4.2 engine swap. what find between plan a and plan b is with plan A is limitless with building. still expensive but risk with breakage. Plan B is rght of the back 300+hp and extremely expansive to upgrade such as supercharging etc. I need some feed back....your thoughts
    Veteran Member Four Rings eyesolution's Avatar
    Sep 23 2012
    Atlanta
    Buy an rs4
    Veteran Member Four Rings jeffrey146's Avatar
    Feb 19 2012
    04 S4 nogaro avant MTQ, 2013 CT200H F sport, 93 EG hatch
    Draper, Utah
    Personally I wouldn't. Buy something that already has that motor in it or something. As usual you would need to do at least the motor/trans/ecu. You would be looking at at least 6k minimum without any labor. Personally I love the 4.2 there isn't a late year audi motor I would swap it with. Also, be aware of the timing chain issues that motor can have. Sure, it certainly isnt as big of an issue as people want to pretend it is. However, I would probably buy a higher millage motor and do all that stuff on it. I still would just buy an S4 or RS. Think about all the other things an S4 has that you want. I mean, the seats? A4 seats just kind of suck.
    CHECK OUT MY BUILD THREAD!!!
    Noggy S4 Avant MT B6
    OZ superleggera 3, Pilot SS , 034 (Trio, adjustable uppers, Zero gap snub, rear sway with endlinks) APR full exhaust with drilled cats, H&R Coilovers, Red rear diff mount, JHM (NO2,Center diff, rear LSD and stage 4 kevlar clutch with LWFW)
    ...BBK coming soon
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    If you want to swap, drop a 2.7T into your B7. Pretty straightforward swap and more power than the 4.2. If you want the 4.2, just buy an S4.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Senior Member Three Rings A4Quattro > all's Avatar
    Sep 23 2008
    Wisconsin
    Quote Originally Posted by LINDW4LL View Post
    +1
    2004 A4 Quattro
    1.8t 6 Speed Manual
    Established Member Two Rings basemntboy's Avatar
    Jun 26 2011
    2004 Audi A4 Quattro 3.0 6mt stock for now...
    Painesville, Ohio
    Quote Originally Posted by A4Quattro > all View Post
    +1
    +2 If you're set on swapping a 2.7 would be the coolest and easiest to modify. I don't know that a whole lot of people would be interested in a 4.2 b7 a4. A 2.7t b7 will have half this forum punching each others dicks to be the first in line haha. Like was already mentioned there are many other features gained than just the motor by going the S4 route. Also re-saleability would be much much better.
    Veteran Member Four Rings jsandor91's Avatar
    Jun 10 2011
    dead hookers
    South Jersey
    go k0r k04 or frankenturbo... much less then a engine swap and 300+ crank horsepower with a 2.0t
    or buy a different car.
    Quartz Grey B7 A4 Quattro 6MT
    Maestro + Epy Tuned / GTX2867r / S3's / Spintech Non-Resonated 3 Inch Exhaust / Cold Side Synapse DV / TR18 + 2.5" Piping / Hpfp S1 Pump
    Bi-Xenon retrofit + Fly's leds / ST Coils + Rsb / 18x9.5 Miro 111's
    Dat Der Build Thread
    Coming Soon: Boost Manager +, Drakes Performance Stage V Clutch
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Right off the bat. That is the expressing you are looking for.
    Want a v8, sell the car get an s4/rs4. The amount of money you spend in combination with the amount of time will far outweigh the benefits. Not to mention selling the car will be tough.
    Also the 2.0t has way more options for upgrades than the 4.2. Many more options
    Jul 29 2012
    orlando florida
    Good points guys..... I hear that a lot about going 2.7. if I decided to do a 2.7 will I need to change my tranny? My 2.0t is a 6 speed. I get it about needing the ecu but what about my b7 cluster. will I have to use a standalone for this swap?
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by fury583867 View Post
    B5 S4 ECUs don't have immobilizers. So I don't think the cluster would be an issue. And you can use your transmission I believe.
    -Hayden
    Veteran Member Four Rings ericpaulyoung's Avatar
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    No way, the 4.2 swap is super easy. The best part is since your b7 a4 ECU is already tuned to run boost, you can build the 4.2 for turbocharging no problem. Something everybody forgets to mention is that the 4.2 is an 8 cylinder, and your ECU is setup for 4 cylinders. At first you are like "so what", but then you realize that because of the firing order you can just split the coil leads for cylinders 1, 2, 3, 4 of you four banger and feed cylinders [1,5] [2,6] [3,7] [4,8]! You don't even have to change the harness, just put a Y in each of the capacitor wires.
    If you look around a bit and are patient you can get a 4.2 out of a wrecked car for around $2k, so figure in selling your OEM 2.0FSI for at least $1500, and you will be at only $500 plus the build parts for making the 4.2 a turbocharged engine.
    - Eric
    Epy
    Dec 10 2011
    CLT | MKE
    But 4.2s blow up under boost!! 034s STK would be tits on a 4.2 though.
    -Hayden
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    True. OP, you should at least count on new connecting rods and a new set of rings in this build.
    - Eric
    Epy
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by ericpaulyoung View Post
    - Eric
    WHAT? Are you just trying to troll with this post?
    - Clint
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Clint, you need to take a college course on humor.
    Of course I am totally serious, but you have to remember to use high quality copper Y connectors.
    Eric
    Epy
    Oct 29 2005
    10speed
    San Francisco, CA
    Eric
    you bastid!
    - Clint
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Or something with a high Tin content if you have good insulation on the wires. Tin won't help if the wires are older and the sheath is starting to crack :/
    Epy
