Originally Posted by
a4udios
Your paint will get damaged after removing the plastidip. How long has the plastidip been on the car?
Its been on for about six months. Finally got it all off, without damaging the paint. For those that go through this, here is my recommendations based on my experience:
- Spray thick the first time. Plastidip isn't like paint where you layer it. Spray about six inches away and lay it on thick with smooth sweeping strokes.
- To remove large areas of thin plastidip, spray over it with thick layers of new plastidip and let it dry. Then take off a little down to the paint, and roll then edge so the top and bottom layers are lifted together. Then you can start peeling.
- For crevices and tough areas, your best bet is a power washer. 2000 psi (rent it from home depot) with a wide nozzle works best. This pressure is fine for factory paint but if you have aftermarket paint it may strip it so keep this in mind.
- For really tough patches and delicate places, some gasoline on a paper towel works best. This is better at removing it than goof off. Either pour some gas on the area and let it sit for a minute, or dab some on a paper towel. This will wipe it right off.
