Results 1 to 24 of 24
    Established Member Three Rings ToXicXxX's Avatar
    Jun 14 2013
    2009 A4
    Calgary, Alberta, Canada
    Can you paint an intercooler
    I recently received my intercooler and im thinking the plain metal look is a bit borring, especially since you can see it from the front end of the car. I am wondering is there any way I can paint it red (was thinking Rustoleum high heat engine paint)? Im guessing you can't spray the core, but I thought I'd ask.
    Jun 10 2010
    Who cares?
    Paint it yellow.
    Jun 14 2013
    2009 A4
    Who cares?
    Paint it yellow.
    Im just curious if I will hurt the core by spraying it?
    Senior Member Three Rings A4F3V3R's Avatar
    Sep 15 2010
    Québec, Canada
    No it wont hurt anything except the eyes.
    '98 A4 on basic mods
    FMIC - Neuspeed chip - Test pipe - cone filter + custom heatshield
    Veteran Member Four Rings revolution337's Avatar
    Apr 03 2009
    4.2 A4, 82 Vanagon, Mk7 Sportwagen
    Pennsylvania
    Quote Originally Posted by A4F3V3R View Post
    zinggg!
    Life is too short to drive ugly cars.
    Senior Member Two Rings TJN0923's Avatar
    Aug 21 2010
    1994 jeep wrangler
    Shippensburg, PA
    ^ LOL
    2000 1.8TQM E-Codes, 8000K DDM Tuning HIDs, APR 93, B7 RS4 Reps, Neuspeed Race Springs, 710N, Full Custom Exhaust, Aluminum Mirrors, etc...
    My intro thread: http://www.audizine.com/forum/showth...rogress-thread
    Established Member Two Rings chris the man's Avatar
    Jul 01 2013
    bicycle
    COLORADO
    a while back. ETS or extreme turbo systems showed a test that painting your core (as long as you did not clog fins) only increased IAT's by a small 3%. i can not find the article again but i know for a fact.
    ALL of my IC's have been painted stealth black. you can paint the entire core, some even powder coat. it will not effect performance very much at all if done correct.
    rattle can isnt bad, but you better seal it.
    notice how APS does here
    http://www.airpowersystems.com/wrx/a...dr725_fmic.htm
    Jun 14 2013
    2009 A4
    How does a nice red FMIC hurt compared to the hideous flashy aluminium one lol. Was also considering black, to match everything else (black out lights, black rims).
    Now the other question... Can you dye or paint the silicone couplers?
    Veteran Member Three Rings Halfrican's Avatar
    Oct 25 2012
    United States
    Paint your windshield while you're at it.
    I got my first job at 16 hoping to save money...then I bought my first Audi.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    I've painted a few of mine with Eastwood radiator paint. (Black)
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    painting the intercooler WILL NOT, and i repeat WILL NOT hurt performance as long as you port & polish your fuel injectors or run double meth. Happy motoring
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Veteran Member Four Rings terraflata's Avatar
    Sep 14 2008
    '97 Audi 1.8TQM '97 Acura Integra 2002 Dodge Durango
    Chambly, Quebec, Canada
    Quote Originally Posted by GrapeBandit View Post
    Damn internet. I cant tell if this is sarcasm or not.
    My .02. Painting it will reduce the cooling effect of the intercooler, nothing to back it up, just what logic dictates. I imagine the effects will be minimal, but I am going polished + anodized. I know what you mean by the plain look of an aluminum intercooler.
    MontrealAudiClub
    Sep 14 2008
    Straight off Garretts site
    "Q. I want my car to remain a sleeper/stealth. Can I paint or anodize my intercooler so it is not easily visible?
    A. Yes! It is not uncommon at all for an intercooler and endtanks to be anodized black to keep attention away from the car and help it maintain a sleeper appearance. A very light coat of paint on the core and endtanks is also another option, usually much cheaper and easier than anodizing, with a negligible performance loss."
    MontrealAudiClub
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    I think its pretty sw33t
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Established Member Two Rings TheChenga's Avatar
    Jul 12 2012
    Australia
    You buy special intercooler paint that dosen't affect cooling or air flow.
    Nov 03 2011
    All Over!
    I would personally leave it black.
    1986 Type 85 Audi 90 quattro
    Senior Member Three Rings andrew.k's Avatar
    Sep 08 2011
    Pickering ON
    Intercooler's should be either black or left aluminum. That red intercooler looks foolish..
    SQ5, PORSCHE MACAN S
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Quote Originally Posted by andrew.k View Post
    This
    /thread
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Apr 22 2007
    Riverbank, Ca
    Painted my FMIC black, Ran 20psi through it just fine out of a GT28R. But I just misted it black, not a thick coat.
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    If you want it black just spend the extra money to have it anodized which will increase the performance of the core along with making the aluminum harder. Normal paint is going to chip over time and end up looking really ugly.
    Senior Member Two Rings M-Dub's Avatar
    Aug 27 2011
    2008 Subaru STi hatch
    Raleigh, NC
    you can but your only hurting it by making it keep the unwanted heat inside the system.
    Bagged and Bolted Wagon of Terror!
    Nov 08 2010
    Upstate New York
    If you're gonna paint it at all, paint it with black radiator paint. Thats all there is to it.
    - B8 S4, Stage 2+
    - B6 S4, not stock
    Apr 01 2011
    B5 on jack stands
    charlotte
    Grill paint here
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Penna.
    Cerakote makes thermal transfer coatings...
    Air Cure
    Oven Cure
