Results 1 to 10 of 10
    Senior Member Two Rings Dufferin's Avatar
    Jun 18 2012
    Intense Uzzi & M9
    Gardena, CA
    Oem S4 Rear sway bar bushings - Mission Imposible
    I bought a rear S4 sway bar to upgrade my A4 and the bushings are missing. And apparently Audi does not sell the bushings separately. Anybody have any OEM bushings lying around? I am at a dead end nobody has these, unbelievable!
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    I would speak to one of your local installers. They may have some stock ones lying around that were taken off another S4 that went with aftermarket bars. I bet Eurocode would have some, or would hang to a pair next time they do a USS upgrade.
    Mar 01 2006
    2021 X7 M50i, 2021 911 Carrera S
    Melrose, MA
    Measure the bar and check Summit Racing
    2020 M4 Convertible 6MT - Alpine White - Sakir Orange - JB1
    2019 X3 M40i - Dark Graphite Metallic
    2010 S4 - 6MT - Phantom Black - Black/Black Alcantara - Nav - Sports Diff - G.I.A.C. Stage 2 - AWE S-Flo Intake - 034 Transmission Mount Insert - JHM Crank Pulley - CR-15 Strut Tower Brace – Sachs XTend Clutch
    Jun 18 2012
    Intense Uzzi & M9
    Gardena, CA
    Great Lead! Went on Summit Racing and found the universal bushings by Energy Suspension. Got the specs from ES website and made some measurements and found the perfect match!
    The Part No is 9.5108.
    I ordered a set and will report back on how it fits.
    Thanks a million!
    Jun 18 2012
    Intense Uzzi & M9
    Gardena, CA
    Dec 11 2010
    Inland Empire, CA
    Jun 18 2012
    Intense Uzzi & M9
    Gardena, CA
    Finally got the bushings and they fit perfectly. Not so Mission Impossibru after all. LOL
    Mar 01 2006
    Melrose, MA
    Excellent. Did you add some grease to the inside of the bushing where it contacts the bar?
    Mar 26 2010
    US
    Quote Originally Posted by Ray Khan View Post
    This to prevent squeeks
    BMW M3 Competition X-drive
    Jun 18 2012
    Intense Uzzi & M9
    Gardena, CA
    Yes the energy suspension kit comes with the grease. You can actually see some excess grease on the second pix.
    Thanks again Ray for the tip!
