No. You need to buy an actual sending unit, get oil pressure reading somehow, get 12 v for the red wire, ground the black wire to the chassis, run the purple wire to the sending unit (read the description for this sending unit on 42DD. You hook it up to the G terminal), and I would personally leave the green wire alone. I cut the dimmer wires off on my VEI dual gauges.
Take out your stock oil pressure sensor and out this fitting in it's place.
http://store.42draftdesigns.com/VDO-...ptor_p_94.html
Then place the stock oil pressure sensor on one end of the open t fitting, and the oil pressure sending unit below on the other.
http://store.42draftdesigns.com/150P...10x1_p_89.html
