Results 1 to 15 of 15
    Veteran Member Three Rings B7OrangeA4's Avatar
    Nov 27 2012
    South Jersey
    Just got a oil change and car starts shaking violently
    So I just got an oil change today at a local shop and not even 5 miles later I start having problems. I have a boost gauge and was reading terrible boost barely going over 8 at WOT. I came to a dead stop at a red light and the engine started knocking and the whole car starts shaking violently. i popped the hood and saw the coolant level was way over the max level. I checked all my fluids Sunday and everything was between appropriate levels. I had the car towed back to the shop and im calling the guy first thing in the morning.
    Senior Member Three Rings turbowop's Avatar
    Dec 01 2012
    '91 Mitsu GVR4
    Yakima, WA, PNW
    Did you check the oil level after the shaking fiasco?
    -Mark
    '91 Mitsu GVR4 #1051 / 425awhp / 11.90@121mph / tuning and wrenching by me / full weight @ 3280lbs
    '08 Audi A4 2.0t 6mt Quattro / Ibis white / convenience & premium package / APR 2+ flash / APR exhaust / APR HPFP / 034 test pipe / CTS FMIC / Stasis street sport coilovers / RS4 rear swaybar / Thor undertray / Podi boost gauge / BFI snub /
    Thule ski rack / tint / paint matched reflectors / 19" Hartmann R8's on Conti DW summers / 17" stock split-5's on Dunlop Graspic winters
    Aug 16 2008
    2009 Dodge Ram 1500 SLT Big Horn
    IL
    Check the oil level... That'd have been the first thing I would have done after the engine cycled the new oil. You never know when those crazy fucks will forget to tighten the oil pan bolt, and it pops out, along with all of your oil..
    Dec 01 2012
    '91 Mitsu GVR4
    Yakima, WA, PNW
    It's possible they didn't even remember to refill the thing with oil as well. This is why I do my own work.
    -Mark
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Quote Originally Posted by audis4ko3 View Post
    oil does a lot of cooling for an engine....you most likely didn't get an oil change but rather an oil drain. That sucks man, hope that you end up getting a new engine out of it!
    Mar 31 2012
    Savannah. GA. USA. TO. ON. CAN
    Quote Originally Posted by teamdaraptor View Post
    Check the oil level... when those crazy &*%$# will forget to tighten the oil pan bolt, and it pops out, along with all of your oil..
    You meant to say oil drain plug?
    //S POWER
    Senior Member Two Rings TsmithA4's Avatar
    Nov 13 2012
    Santa Monica, Ca.
    Maybe ignition coils
    2007 A4 2.0T | VAG COM | 034 SD Mounts
    Jun 27 2011
    Was this "Local Shop" Jiffy Lube by chance?
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Aug 16 2008
    IL
    Quote Originally Posted by //S POWER View Post
    //S POWER
    Hmm.. yes. Good catch.
    Veteran Member Four Rings LoKisSpYdR's Avatar
    Jun 26 2012
    Brilliant Red B7 A4 2.0T Titanium quattro Tip - 2015 Q7 PP
    Reading, PA Area
    Update OP?
    B6 A4 1.8T Dolphin Gray qM
    4L Q7 3.0T Glacier White PP
    Oct 04 2012
    North Hollywood, CA
    hahahaha!!! those oil changes hurt your car instead xD
    Quote Originally Posted by TsmithA4 View Post
    could be...had one coilpack go bad and check engine light comes on and the car feels loss of power and vibratess a lot and feels like it will turn off O:
    and a month later another one died on me....(different one) BUT it felt worse than when first coil went out...so hopefully...
    Veteran Member Four Rings eyesolution's Avatar
    Sep 23 2012
    Atlanta
    Mine is a bit different. Right after an oil change the car shakes like if it were missing oil. And it stays like that after a couple starts even after the day of the oil change. Eventually it goes away. Is this normal? Shouldn't it be a smooth idle once you fore up the car after the oil change. I understand you might have to let the oil "settle" but doesn't seem normal. It became normal to me since it goes away after about a day.
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Quote Originally Posted by eyesolution View Post
    Definitely not normal
    Sep 23 2012
    Atlanta
    I'll make a video to show what I am talking about. It's quite violent.
    Nov 27 2012
    South Jersey
    Turns out a clamp was loose and caused a boost leak
