Results 1 to 32 of 32
    Oct 12 2011
    WA
    Transmission is out, good time for rear main seal replacement?
    I figure it wouldn't hurt but mine isn't currently in bad shape. While the transmission is out, would you recommend changing it anyways or leave it if it's fine?
    thanks!
    01 Nogaro 605, AMD tuned with custom no-mod list signature.
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    I'm of the school of thought that if there's nothing wrong with it (no leaks or damage), then leave it. It would suck to replace it and have it not seal perfectly and then have a leak where before there was none (having to pull the engine again always blows).
    Account Terminated Two Rings
    Jun 10 2013
    california
    do it!
    if you plan to keep the car for a while, i would do it now.
    the part is super cheap, its the labor that costs an arm and leg.
    if you have the trans out, its the best time to do that.
    my wifes bmw is leaking out the rear main seal and the shop quoted us just for labor 9-10hrs @$120/hr.
    Jun 10 2013
    california
    Quote Originally Posted by Fourplay View Post
    if you do everything right, it shouldnt leak.
    use any sealants or whatever it asks for, and torque everything down,ect.
    Feb 21 2011
    WA
    Quote Originally Posted by 17708 View Post
    That would be the general thought process but we're dealing with the 2.7T here..
    I did a lot of looking when I had mine out and decided against it.. If it isn't leaking now then you only have to worry about natural failure. If it is leaking now, you have to worry about natural failure on the new one AND properly installing it.
    Either way you're looking at doing the labor some day. This is just one of those times I agree with the "if it aint broke, don't fix it" crowd.
    May 01 2010
    Atlanta
    The fewer things you mess with on a B5, the better off you are. Regardless of what is "supposed" to happen, Murphy's Law is king with these cars. Hence the let it be if it's not an issue (except obvious preventative maintenance).
    Quote Originally Posted by waB5S4 View Post
    If it isn't leaking now then you only have to worry about natural failure. If it is leaking now, you have to worry about natural failure on the new one AND properly installing it. Either way you're looking at doing the labor some day.
    This.
    Feb 07 2008
    The boonies, near Seattle
    I faced the same decision about 4 years ago when I did ko4's. I chose not to replace the rear main seal, and I don't regret the decision. Mine has yet to leak.
    -dre
    Senior Member Three Rings Sscott09's Avatar
    Sep 01 2009
    9mm, GTFO
    I did mine, hope it holds up!
    2000 Laser Red S4
    2.7T currently receiving RPM rods, ev14 1000cc and SRM RS6/K24 Hybrids.
    May 16 2008
    South Texas
    Although I'm a big proponent of "Do it while your there" seals are a different story. i don't like to replace a non leaking seal as there's a chance you can screw up the install and there is a chance that the seal could be defective from the factory (a rash of main seals for the 1.8t/1.9tdi were manufactured with a weak spring years back). Many people preemptively replaced the RMS with a clutch job only to find they had to do it again after the RMS started leaking.
    Veteran Member Three Rings Matt Danger's Avatar
    Jun 04 2007
    B5 S4
    ROC NY
    If it's not leaking don't fuck with it.
    770r B5S4 home built & tuned
    Sep 23 2007
    I have my engine out right now and I chose to replace it. I made sure to use a screw driver to gently get the lip to seal against the motor and not face out.
    Wasn't too difficult and hopefully it will be fine (knock on wood).
    Veteran Member Four Rings ilyafil's Avatar
    Nov 03 2011
    Bay Area , CA
    I ALWAYS replace the seal...but that's just me...
    EDIT: But I have a lift...
    "Basically the B7 is the girl you bring home to mom, and the B5 is her slutty sister."
    For Sale: Neuspeed Sport Springs
    Jun 10 2013
    california
    looks like the OP is getting 50/50 answers.
    i would look at it and if it looks real worn or feels brittle at all, replace.
    if it still looks and feels fine, keep it on.
    Aug 13 2008
    Indiana
    do it!
    You're obviously still learning these cars. There are more documented rear main seal failures from replacing then there are from natural failure. And technically you should do the whole rear plate like Audi sells it. That is not a super cheap part lol.
    -Nic
    Established Member Two Rings inzunzar's Avatar
    Oct 09 2010
    El Paso, TX 79906
    I replaced mine when I had my engine out, it was not leaking and I regret it, had to take the transmission down two more times, don't mess with it....
    Veteran Member Three Rings 1illA6's Avatar
    Aug 20 2012
    Arizona.
    ^ same! Was not leaking, replaced it while its out, 300 miles in it's leaking & it's getting all over the clutch. I'll be doing it again next week.
    Veteran Member Four Rings Sole_'s Avatar
    Oct 29 2009
    I'm about to finish my K04 install also replaced the clutch. Did not touch that rear main seal.
    Imola<3
    Veteran Member Three Rings Halfbreed's Avatar
    May 13 2010
    Jax, FL
    +1. Most accurate statement I have read on here in a while.
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    I read through so many damn rear main seal threads when my engine was out. I ended up replacing mine.
    Hope its on there correctly. 189 miles and nothing yet. Lets hope it stays that way. While I believe in the "if its not broke don't fix it" I think a seal in a place like that should be replaced, imagine if you don't replace it and it starts leaking...You didn't even try.
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Aug 13 2008
    Indiana
    Quote Originally Posted by 01audia4 View Post
    I'd be even more pissed if it had started leaking because I did it haha.
    -Nic
    Senior Member Three Rings Delmed83's Avatar
    Feb 19 2013
    EPL did my K04 upgrade back in January. Back then when they were working on it, I knew very little about the car. So I didn't even think of it while they had the engine out. A few weeks after getting my car back, I came across some RMS threads. I then said to myself....why didn't EPL recommend to replace it while everything was apart? I then realized that they agree with the school of thought....if it's not leaking, leave it alone.
    It's 6 months later and still fine.
    I vote to leave it alone.
    Black 2013 B8.5 A4
    Previous rides:
    Silver 2001.5 B5 S4 - EPL Stage 3
    Black 2001 B5 A4 - Dahlback Stage 2
    Black 2006 B7 A4 S-Line APR Stage 2+
    Dolphin Gray B7 S4
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    Quote Originally Posted by Scotty@Advanced View Post
    I'm the same way.. Main seals and cam seals etc I never touch unless they're leaking
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
    Jan 31 2008
    Quote Originally Posted by somebody5788 View Post
    Well mile marker 189 of my K04 install I have a HUGE oil leak. I feel like it is too excessive to be the rear main. Maybe oil pan or upper(both looked fine when engine was out)
    Who here had a leaky rear main? How bad was it..>I really hope I don't have to pull my engine again.
    Oct 12 2011
    WA
    thanks for the responses guys!
    Aug 20 2012
    Arizona.
    Mines currently leaking:( its bad enough to be getting all over the clutch.
    Drips crazy. Not so sure about pulling the engine way to much work, trans will be getting pulled w/in the next much easier & takes what an 1hr tops?
    Senior Member Three Rings Tyler S4's Avatar
    Aug 24 2011
    1998 Jeep Grand Cherokee 5.9 Limited
    Westminster, Colorado
    Re: Transmission is out, good time for rear main seal replacement?
    Who here had a leaky rear main? How bad was it..&gt;I really hope I don't have to pull my engine again.
    You obviously did NOT knock on wood lol. 16 hours ago you were saying you were good. That's a bummer man. Excessive oil doesn't really sound like a rear main to me. But I'm not really sure.
    2011 Ibis White S4 Prestige 6MT - APR Goodies | Roc Euro
    2001.5 Santorin S4 6MT - 034 | Darintake | EPL | ST | JHM | SSAC | VMR - Sold
    Jan 31 2008
    Quote Originally Posted by 1illA6 View Post
    I don't know about an hour tops..I've herd its almost easier to pull the motor as a whole. Plus you'll be able to see what you are doing. Ill pull it again when I get back from vacation.
    Quote Originally Posted by Tyler S4 View Post
    Obviously not..16 hours ago it was not leaking, guess it started today. Now I don't know if I am more pissed cause I replaced it and it leaks, or if I would have just left it alone and leaks. I retract my previous statement. IM ANGRY.
    Seem like quite a heavy leak though, I almost feel too heavy to be the RMS but the oil is dripping right by the service holes on the trans/engine.
    Maybe an upper oil pan gasket i'm thinking? How can I really tell. I had it up on a lift we sprayed it down but still couldn't see where it was coming from. Almost looks like by the starter. Could it be leaking out of the RMS and being spit out the starter?
    May 01 2010
    Atlanta
    LOL nope.
    Some of the engine to tranny bolts are almost impossible to access with the coolant hard line on the rear of the engine in place (plus oil/vacuum/wiring lines in the way as well). I would budget 4 out and 4 in.
    Jul 28 2008
    01.5 S4, 09 Touareg, 88 Cabriolet 16vT
    Pittsburgh PA
    wow, i was a don't read and post, but then read it... sucks. So yeah, i just had a 1/2 shift collar go, JHM rebuild and here we are... check the rear main seal, looks fine, put it back. I'm with these guys... seals, don't mess with unless you are prepared for the nightmare (sorry OP)... same with our S4's fuel filters... those fitting corrode on and you are smoked when you are just trying to do maintenance.
    Latest mod - JHM rebuild kit :swoll:
    May 01 2010
    Atlanta
    Quote Originally Posted by fshowcars View Post
    Yep, I've cracked the feed line to the fuel filter from the fuel pump that goes between the tank and the body. Huge PITA to fix. All because the lines corroded on and it took enough force to break it free that the line broke.
    Aug 20 2012
    Arizona.
    LOL nope.
    I guess I should have made it more clear, it'll take me an hour:)
    Plus the allens at the bottom of the trans are gone, so all that's left are the 16s.
    Rear of the subframe comes down, trans slides onto a tranny jack & it's out.
    Does help to
    Have a lift I suppose.
    But yeah 4hrs then sounds about right.
    Senior Member Two Rings King_S4's Avatar
    Dec 30 2010
    2001.5 casa white S4 Stg3, 06 VW Touareg V8
    Ajax
    Quote Originally Posted by Matt Danger View Post
    This. Why go looking for trouble?
