Results 1 to 8 of 8
    Apr 07 2006
    Aussie in Singapore
    Just bought some 2nd hand RS5 8pot BBK but need help
    As you can see a lot of rust has built up on the rotor hub and this to me is not good enough.. Any advice to clean this up? anything else besides having them re sprayed?
    Thanks in advance
    Rob
    Street - RS3 FL Sedan Daytona Grey APR stage 1+ | APR TCU | Wagner IC | IE intake | Forge turbo inlet
    Track - EVO X RS JDM | HKS Stroker kit | OS valves Cosworth cams | BorgWarner EFR8374 turbo 2.0bar | direct port meth inj. | AST 5300 3way & 16kg springs | 18x11” A050 M | carbon doors | Chromoly subframes | roll cage | Motec M150 | ceramic hubs | 2,920lbs
    Apr 17 2004
    Socal
    wire wheel or wire brush, high temp paint.
    Feb 08 2013
    2017 Corvette Z06; 2007 Ford F-150; 2004 Honda RC51
    Sammamish, WA
    Yeah, not too difficult to deal with. Wire wheel or brush, degrease, and leave it bare or paint it.
    2013 Premium +, Monsoon Gray, S tronic, sport diff, B&O, 19" RS4 reps, black on black interior, carbon inlays
    Mods planned: seeing doctor tomorrow about a lead foot prosthetic
    Apr 04 2012
    MSP
    MSW = Most Soft Wheel.
    Had a set of those identical wheels in 20's but all silver and after bending two got rid of them... watch out for any pot holes these things are like warm butter.
    Apr 07 2006
    Aussie in Singapore
    lol - they are not my rims :)
    Buying the brakes off this guy...
    Apr 07 2006
    Aussie in Singapore
    I have another question,
    If the rotor new is 365mmx34mm then what would be the minimum you can run this rotor thickness (If I was to shave/lathe them)?
    Can't find anywhere and hoping braking experts can chime in..
    Cheers
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    cleaned my with wire wheel brush thingy. looks like new....just dont brush too much around the holes etc as it is soft metal.
    at the same time i cleaned (redrilled the cooling holes with slightly smaller drill)...
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Veteran Member Four Rings apexit1's Avatar
    Jun 04 2010
    northern nj
    I think it's 30mm when they recommend replacing them.
