Results 1 to 34 of 34
    Established Member Two Rings Capt Scuzzy's Avatar
    May 21 2011
    2002 S4/1973 Camaro
    Northern California
    Will this adapter work? (Apple 30pin to Lightning)
    My car has the OEM iPod integration and I picked up the iPad mini a few days ago which has Apple's new connector. Will the adapter above allow me to play my tunes through my RNSE with my iPad?
    I'm curious if anyone as successfully done this as I couldn't find anything on the topic.
    If I didn't search well enough please link me to the thread with the answer!
    Jake
    Current: 2008 A4 2.0T True S-line 6mt Quattro
    Past: 2002 B5 S4 6mt
    Jul 19 2011
    Northern Minneapolis, MN
    99% sure no. I dont think the RNSE has the software to read it. That cable probably would allow you to if it did though.
    May 21 2011
    2002 S4/1973 Camaro
    Northern California
    Crap:/ I guess I'll just put In the AUX since I coded my RNSE for it a few weeks ago lol
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    really corey?
    i thought it would almost for sure work. the whole point of the adapter is to convert the 8 pin to a 30 pin signal...
    May 21 2011
    2002 S4/1973 Camaro
    Northern California
    I thought it would work too. A couple of months ago I tried a 30pin to micro USB to use my galaxy but it didn't work. I thought it was because it was only made to read IOS not android
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Buy it and try it. I bet theyre only a few bucks on ebay.
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    ... 30 pin to micro USB??? yeah that would never work b/c 30pin is only for ios devices. i'm not sure what purose that cord word serve, unless your phone was jailbroken then i'm sure you could transfer files across it...
    i'm willing to bet you could buy it at the apple store walk to your car try it if it doesn't work take it right back and they'll probably let you return it. if not, i bet a place like best buy has a knockoff brand that u could buy and use and best buy will definitely take it back
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 14 2011
    12 Taco, 13 Ex, 16 Civic EX, 15 JKUR
    there are variations of that little beast. None support video, some support audio, most support data.
    Make sure you get one that states it will support audio and give it a go. I have one which lets me plug my iphone 5 into a 30 pin cable that goes to my head unit...at the head unit the cable splits into a usb and a 3.5 mm audio plug. I can play tunes and control my ipod functionality from my head unit. But no video.....
    Video works when my wife plugs here iphone 4 into the 30 pin cable connected to my head unit.
    Nice....lightning connector reduces functionality....nice upgrade apple. I do not like the new adapter (yet).
    2007 2.0T Q 6MT, S-Line, Ti Package, BB
    Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Redstuff Front & Akebono Rear | Podi Stepper Boost Gauge | Recaro's | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
    Jul 19 2011
    Quote Originally Posted by drumnjuny View Post
    really corey?
    Yeah, but we have a ton of these at work since people all had iPhone 4 & 4s's and all have 5's now so that we can use old chargers and what not and the 5's dont work in any dock station around the shop. We end up just plugging in a charger (30pin converted to 8pin) next to it and then using an analog 3.5mm male/male jack.
    I just figured our cars would be the same.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    oh damn that is disappointing. yeah i have never used the adapter but have almost bought it a few times for my ipod adapter
    May 21 2011
    2002 S4/1973 Camaro
    Northern California
    Re: Will this adapter work? (Apple 30pin to Lightning)
    It was a female 30pin to male micro usb so I plug my android into my oem ipod dock in my glove box, but it didn't work unfortunatel.
    The adapters that support audio might just be the one to try
    Sent From Above
    Aug 16 2008
    2009 Dodge Ram 1500 SLT Big Horn
    IL
    I've got the integrated ipod dock as well in the glove box. I have a new gen nano, with the lightning connector, bought that little guy, but I'm not having an issue with that.. I'm having an issue with the factory headunit not being able to select the ipod dock in the glovebox.. :/
    May 21 2011
    2002 S4/1973 Camaro
    Northern California
    So you confirmed that it will play the music from your ipod with the adapter pictured above? Did you havr to get one that specifically supports audio?
    Sent from my SAMSUNG-SGH-I717 using Tapatalk 4 Beta
    Veteran Member Four Rings MNAudi101's Avatar
    Aug 18 2011
    Stuff
    Minnesota
    works for me, I got the 30 pin to lighting adaptor from apple for 29.99 and did it with my oem ipod hook up and it works just fine
    200k daily tank
    My Build Thread
    "Like a fat chick in Yoga Pants...Mad stretch "
    Veteran Member Four Rings JPT's Avatar
    Oct 11 2010
    '05 Kawasaki Ninja ZX12R
    Long Island/NY
    I also have the 30 pin to lightning adapter in my car (Factory installed ipod adapter and RSNE). Works great for my iPad 4 and iPhone 5. Search my threads for my setup with pictures (I think if you search my name with "pandora") it will eventually come up as a thread I created.
    I have the voltage adapter pushed into the glove box holder (so it charges iPhone 4+) - 30 pin female to make extender (basically a cable that allows me to have my phone in my cup holder - 30 pin to lighting adapter.
    I used my same setup with a newer loner. Song names and album names showed up on the gps screen.
    May 17 2007
    B7 QG avant
    Salt Lake City/ Park City
    I use that cord on my Dice system to convert the 30pin to the lighting and it works perfectly, I'm not sure if it would transfer to the RNS-E (because I don't have one :( ) but it works perfectly on mine to give me full integration.
    - Colin
    Jan 29 2007
    08 S4 00 S4
    MD
    The 30 pin to lightning adapter works fine on the factory iPod dock. The problem is the factory iPod dock sucks.
    08 S4- Stock SOLD
    May 21 2011
    2002 S4/1973 Camaro
    Northern California
    Even the cheap eBay ones? like:
    Link
    Jan 29 2007
    08 S4 00 S4
    MD
    Generic ones are hit or miss from the reviews I've seen on amazon. I'd spend the 30 bucks for the Apple one and be done with it.
    08 S4- Stock SOLD
    Established Member Two Rings parki3n's Avatar
    Nov 03 2008
    Norwalk, CT
    I got a cheap one online and it didn't work for my Dension unit. I ponied up for the $30 Apple one and it worked like a charm.
    I hear the newer third party ones work better, but if you happen to get one of the ones that first came out with the iPhone 5 they didn't have the required authentication chip and many third party products didn't recognized them. Basically they got you power throughput but no data could be read, so they were only good for charging.
    2006 A4 Avant 2.0T Tip | Dolphin Gray | Stock | Sport + Premium Package | Quattro
    May 21 2011
    2002 S4/1973 Camaro
    Northern California
    Hmm I would rather just nut up and buy the adapter from apple instead of waste my time. Or install the aux port to use any device.
    Senior Member Three Rings pDubs's Avatar
    Jan 12 2012
    2005 Kawasaki ZX6R, 1973 Honda CB350F
    Fairfax, VA
    Quote Originally Posted by cab509 View Post
    Do you have symphony 2 or 2+?
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by Capt Scuzzy View Post
    If you don't want to spend the money on a fully integrated system, just do the AUX route. Trying to get usability out of the factory iPod dock is not worth investing even the 30 dollars.
    08 S4- Stock SOLD
    May 21 2011
    2002 S4/1973 Camaro
    Northern California
    Hmm.. You have a good point. My intent with the cheap eBay adapter was to find an inexpensive workaround to listen to the music on my iPad. I'm glad I inquired about this before pulling the trigger on a junk adapter.
    Oct 11 2010
    Long Island/NY
    Quote Originally Posted by mholme View Post
    Why isn't it? how do you change tracks via AUX? How do you charge while listening?
    I love my factory ipod adapter. Yeah, it would be nice to get the track names on my RSNE. But it is great to be able to charge and listen to music with only 1 cable.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by JPT View Post
    With the AUX, you have control through the iPod and can see and search music with minimal money invested. It doesn't charge without an additional cable. That's the compromise.
    If you are happy with the factory iPod dock and your factory sound system, then you really should look into a Dension iPod interface. You get track names, search, playlists, genres, artists, you name it, right through the thumb wheel and can see it in the cluster. And it charges your device. No compromises, you just have to commit to the the price.
    08 S4- Stock SOLD
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    I know this is an old thread but I've been researching this subject and came across something useful.
    This item is a 30 pin ipod female to 3.5mm aux male adapter:
    edit: item doesn't work. The CD player does not recognize that anything is plugged in.
    states it is not compatible. However, if you read the reviews 2 owners of 2008 Audi A4 say it DOES work, 1 2009 VW owner says it also works (probably same interface). Buy at your own risk. I'll report back when I get mine and test it.
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
    Mar 29 2012
    MD
    my lighting adapter works just fine. Totally worth the $$
    Apr 23 2011
    Sac Area, CA
    Quote Originally Posted by ericw. View Post
    http://www.amazon.com/gp/product/B00...uct_refresh_T1
    fyi this item doesn't seem to work. CD player does not recognize that anything is connected to the ipod port.
    IG @lolzhax
    //AGILITYDRIVES.US
    Established Member Two Rings redcon1's Avatar
    Oct 22 2009
    '99.5 GTI VR6, '13 Touareg Sport V6/FSI
    South Central PA
    Thread bump.... My factory ipod dock doesn't recognize the old Ipod mini I bought for music only. It used to work with my daughter's iphone4 and another ipod Mini back in the day.
    Any ideas why the mini is not recognized through the dock now? Can I check if it is enabled via VAGcom? Man this is frustrating as hell.
    Dave
    2013 Touareg Sport V6 FSI
    2000 BMW Z3 2.3
    Deactivated Four Rings
    Aug 30 2013
    2014 Toyota Highlander Limited, 1999 Mercury Grand Marquis GS-HPP
    Panama City Beach, FL
    Try another ipod mini or iphone to verify they work. If they do, then the problem is your mini. If none of them work, either the head unit isn't working with the ipod or the cable is bad.
    Oct 22 2009
    South Central PA
    Hmm.. I know the ipod mini plays music through the headphones and a plug-in speaker. So I'm gonna rule that out.
    I may try to pop out the dock, to check the cable. Maybe it could have gotten unplugged?
    Dave
    2000 BMW Z3 2.3
    Aug 30 2013
    Quote Originally Posted by redcon1 View Post
    Does the factory dock get audio from the 30 pin connector? If so, then the headphone output working or not working isn't related. But yes, the cable could be disconnected.
    Senior Member Three Rings vtwinjunkie's Avatar
    Aug 10 2013
    Various motorcycles
    NOVA
    I bought a cheap one off ebay and it did not work....only charges the phone but no audio (however from the glovebox port it doesnt charge or carry audio)..
    The same connector from apple works fine charges as well as audio (however In the audi there is only audio from the glovebox port)...I use it every day.
