Location, Gilbert Arizona (so hot!), The car:- 1998 2.8 30v, FWD Auto Avant.
The problem:- It has started breaking down while he is out and about, so I have stopped him driving it. The engine cuts out, but at the same time power to the a.c. fan seems to go as well, along with the aux fan on the condenser/radiator. The rev' counter stops working and the ABS light comes on with 3 beeps. If you crank the car it will start up again, but takes a bit of time to do so. Sometimes the rev counter will stop working and the ABS light will come on, but the a.c. and engine continue to work... for a while.
So it would appear to me that some major power source is being lost or turned off!? I thought perhaps the ECU might be at fault? Or it's loosing power? So I removed the plastic cover to get to the ECU, and that this is bloody hot!! I can hardly touch the thing. Should these ECU's get that hot? It cools down if you turn the car off..
The problem does seem heat related, 'cos, if we leave it in the garage overnight, and take it out into the heat, it will run for longer, then if it's parked outside for 3/4 hours!
I'm not getting any ECL's either...
I don't have VAGcom, but I have a hand held scanner, which when plugged into the OBDII port loses coms with the ECU when the engine stalls! But the power/ignition is still on!?
Does this sound like a ECU (ECM) issue? Or do I have a power line dropping out somewhere? Perhaps a relay supplying power to the ECU? But which relay? And where would that little bastard live within the car
And the other problem is my 17 year old son is now driving around in my 4.2 V8 C5!! And enjoying it a bit too much!!
Any ideas?? Anyone else ever seen this problem?? Any help or suggestions would be wonderful..
Thanks guys,
Paul
