So I was installing the new rods with pistons in my block today and did a few searches for torque specs on the APR bolts that come with the IE rods. I know what the Bentley manual says but I am assuming that spec is for OEM rod bolts so I wanted to double check if that spec also applies to the ARP bolts. In several places I found a spec of 50ft-lbs but some places specified 26 or 28 ft-lbs of torque. Pretty much all versions instructed to do it three times to the same torque spec. The problem is the different torque numbers different places specify. Someone also asked the same question on IE's facebook page and they responded with "two cycles to 50 ft-lbs and the third cycle to 55. So I decided to follow that and guess what? Two of my bolts overstretched and actually tore in two pieces. Even though the other bolts didn't break/tear I am afraid that they are overstretched and way too thin. I ordered 12 new ARP bolts from IE and I am guessing the 26ft-lbs spec is the right one given the results I've see with the 50ft-lbs spec. 26 just felt way too little but it's a fairly fine pitch so I guess it makes sense. What has everyone used so far?
