Results 1 to 33 of 33
    Veteran Member Three Rings Dr Chill's Avatar
    Oct 04 2011
    South FL
    C7 S6-Getting 20x10 et35 rims. Go with 255/35 or 275/35 square setup?
    I really want Continental ExtremeContact DW tires and they come 255/35 (backordered) or 275/35 (in stock). On a 10" rim, the 255 seems stretched. Should I have any rubbing issues with the 275's? I realize with the 275's the speedometer will be off by about 2-3 mph and I'm ok with that.
    Wheels will be AG M510 20 x 10 ET35.
    Current- 2018 S6, 2018 AMG GT-C Roadster, 2008 997.1 Turbo Coupe, 2023 Lucid Air Touring
    May 04 2010
    2013 Audi S6, 2014 Audi Q5 TDI, 2015 GSW TDI 6-spd
    Duluth GA
    The 255 section width tire most definitely will be stretched on a 10" wide rim. FWIW, all the 10" rim setups I've seen posted all run stretched tires. The ET35 offset pushes the rim out 4mm more than my setup (yours will be 29mm outward compared to stock) and the rim will stick out past the fender slightly. Based on this I think a 275/35 will rub sometimes. Can the folks at Avant Garde give you fitment advice?
    Robert Cheng
    2014 Q5 TDI, Phantom Black, S-Line, B&O, Nav, Side Assist
    2013 S6, Estoril Blue, B&O, LED, cold weather, comfort seats, rear shade, BBS CH-R 20x9 ET25, Stasis 25.4mm RSB, Alu-Kreuz
    2010 S4, 6-spd, Meteor Gray, Prestige, Sport Diff, Strat shifter, H&R Rear Sway -- SOLD
    2000 S4, 6-spd, AWE stg3, lots of other stuff -- SOLD
    Veteran Member Three Rings TheChef's Avatar
    Aug 30 2010
    Houston TX
    Amy particular reason for the Conti? Michelin comes out with the new PSA S3 in July 1
    That will blow it away.
    I would suggest do the M510 in 9" width not
    10" and go 255s. And go michelins.
    #ProjectS7 2013 & 2014 SEMA Feature car w/ HRE
    Glacier White. Quilted. Innovation. Carbon. LED. Big Red Brembos.
    Partner's: HRE Performance Wheels. Audi. APR. H&R. Michelin. TiKore. EVOKlass. Eurowise. Mothers.
    Oct 04 2011
    South FL
    Re: C7 S6-Getting 20x10 et35 rims. Go with 255/35 or 275/35 square setup?
    10=more concave
    Continental EC DW=excellent performance and treadlife for $100 Less per tire than Michelin PSS.
    Aug 30 2010
    Houston TX
    I would stick with the 9. Not the 10.
    That said I would hope a Conti AS tire cost 100 less than a PSS! That said, I suggested the PSAS3 that comes on July 1
    Active Member Two Rings RettlerT's Avatar
    Sep 21 2012
    Oregon
    For decades the only tires I would use were Michelins. A couple of years ago I switched form PS AS to PS AS Plus on both my car and my wife's. They were so bad that I doubt if I ever use Michelin again. Both sets were toast at 10-12 K and rode like rocks. I've switched to Continental EC DWs and so far am very happy. They ride nicer and certainly handle better than the Mich. AS tires.
    Veteran Member Four Rings JOS4AUDI's Avatar
    Jul 09 2008
    2008 RS4, 2012 S4, 2013 Allroad
    So Cal
    Go with the 10" M510 especially on the 6 platform. 9" is weak, plus not available 8.5" is only other option. 255 will provide a mild stretch nothing major. 275 will rub IMO. Also wheels will not stick out past fenders up front, and in the rear sit flush. With 255 no rubbing issues ive been running these for months. 20x10 et 35 255/35/20 here are some angles.
    Current Audi's: 2008 RS4 Avus, 2012 S4, 2013 Allroad
    Past Audi's: 2013 A6, 2011 Q5 SLINE 3.2, 2006 S4 SPRINT BLUE, 2001 TT 225, 2006 B7 A4 SLINE, 2008 A4 CAB, 2011 A4 SPORT
    Senior Member Three Rings ///M Traitor's Avatar
    Feb 05 2013
    I will never understand the "stretched" look.
    Established Member Two Rings spoiledkid's Avatar
    Oct 02 2006
    13 S6, 13 Q5 3.0t
    Valencia, CA
    I'm running a set of AG Wheels as well with a 20x10 et35 setup and my michelin PSS 2s barely rub in the rear and the fronts are sitting fine for now. Personally I think I need a different offset in order to take advantage of a wider tire setup.
    13 S6 Phantom Pearl Black, B&O, Cold Weather, Rear Sunshades, Innovation - Vagcom, AWE Tuning exhaust, APR tune and lowered.
    13 Q5 Premium Plus 3.0T, Scuba Blue Metallic, S Line, Sport Interior, B&O - Vag-Com, Roc-Euro Intake, Alu Kreuz, UR FSB, GIAC stage 2 tune, Awe-Tuning pulley, SQ5 4 piston 380mm brakes, SQ5 quad exhaust and APR cooling system for S4 (SQ5 conversion)
    Sold: 12 A6 prestige, 06 S4
    Jul 09 2008
    So Cal
    Quote Originally Posted by ///M Traitor View Post
    That's because your too awesome for life!!!!!
    Oct 04 2011
    South FL
    Quote Originally Posted by spoiledkid View Post
    What size tires are you running? As stated, the only other 20" offered in this wheel that could work is 8.5" wide which isn't a consideration for me.
    BTW, The Extreme Contact DW is not an all season tire.
    Oct 04 2011
    South FL
    The Michelin PS A/S 3 does sound like a nice tire though. I think I'm gonna wait until July.
    http://www.michelinman.com/tire-sele...ails#techspecs
    Veteran Member Four Rings CreoSTi's Avatar
    Feb 22 2004
    West L.A.
    I was originally thinking of going with 20"x10" wheels, but I think I'm going with 20"x9.5" instead and run 265/35/20...
    -Mike-
    2022 Tesla Model 3 Performance & 2023 SQ5
    Past: 2001 S4, 2011 S4, 2014 S6, 2018 S4, & 2021 TT
    CrossCountry Mortgage
    Instagram: creoucla
    Aug 30 2010
    Houston TX
    Quote Originally Posted by Dr Chill View Post
    Good call. I have the PSAS3 coming for my A4 also in 245/45/17 as well. This will be Michelin's A/S response for its Benchmark PSS when your car has summer UHP tire needs, which my S7 does....and those are coming to me in 265/30/21 also.
    Oct 02 2006
    13 S6, 13 Q5 3.0t
    Valencia, CA
    I'm running a 255/35/20
    Senior Member Two Rings Tracee's Avatar
    Feb 15 2009
    2013 S6, 2013 S5, 485 BHP B6 A4
    OC, Cali
    You may want to stop by AG and test fit the wheels. With the size of our front brakes, low offset is pretty difficult.
    All you guys are driving a chick car
    Oct 04 2011
    South FL
    Good idea, I'll just spin over to their place in Santa Fe Springs CA on the way home from Miami tomorrow.
    Feb 15 2009
    OC, Cali
    Airplane may be a more efficient way of travel...my apologies. If you would like I can see if JOS4AUDI would like to bolt one of his up to my car to test fitment.
    Aug 30 2010
    Houston TX
    This brings up a good topic though. Offset. What is the lowest offset people are running that clears the brakes? I know the stock 19" S7 wheel is ET32.
    I know on the H&R A7 running 21" rotors with a 265/30/21 tire those are ET45 and H&R added an 18mm spacer for an effective offset of ET27, however the A7 brakes are not nearly as large.
    As of now I am planning on ET30 on a forged 21x9 with 265/30/21 PSS.
    Need to get behind my wheel and find an effective way to measure caliper clearance with my current ET32 offset on stock 19" wheels.
    Oct 04 2011
    South FL
    When the offset is low, it really comes down to wheel/spoke design and the only way to tell is with test fitment. I wouldn't waste your time with painstaking measurements.
    Aug 30 2010
    Houston TX
    I will just speak to a few of the companies I am considering. I know the have made a wheel or two for S6 or S7 - see what they used.
    Veteran Member Four Rings MileMan402's Avatar
    Mar 14 2012
    PHL | BOS | SEA
    Quote Originally Posted by JOS4AUDI View Post
    Necro-bump
    The 255's above look so much more stretched than in this picture below...
    2014 S6 - SOLD
    2016 Focus RS - SOLD
    2012 Wrangler Unlimited
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Just for reference, here is a fender shot of a 20x9.5 ET39 with a 265/35/20 Michelin PSS....
    From the rear looking forwards....
    IMO, 20x10 at a 35mm offset is a tad too aggressive. You may get away with it with 255s due to stretch, but I would actually go with a 275/30/20 tire, and a higher offset. A 255 on a 10" wheel is not optimal and if you are going to spend the $$$$ on aftermarket, why do what is less than optimal?
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Veteran Member Three Rings $lick's Avatar
    Nov 06 2009
    2013 Audi S6 Lexus IS300 Turbo
    Chii
    this thread is super old. OP prop already made his purchase. ET35 on a 20x10 is going to stick out of the fender. using this offset calculator http://www.1010tires.com/Tools/Wheel-Offset-Calculator# that would be like putting on 30mm spacers on the OEM wheels. Most people are running 15-20mm spacers and just 1 guy (that i saw) was running 25mm in the rear... put he wasnt super low
    -Mike
    2013 S6
    APR Tuned / Lowered / 20x10 Rohana RF2 / Custom Dual K&N Intake
    2003 Lexus IS300T
    2008 A4 2.0t Quattro Avant APR Stage 2+ $old
    Instagram: TwinTurbo_Mike
    Nov 06 2009
    Chii
    I confirmed with "fitment specialist" from authorized dealer... It should have a nice flush fitment
    -Mike
    2013 S6
    2003 Lexus IS300T
    Nov 06 2009
    Chii
    Quote Originally Posted by pandi View Post
    and it will clear the brakes?
    they told me it will fit the car. i think sometimes it depends on the construction of the wheel and since the RF2's have more of a concave design they will clear the brakes
    -Mike
    2013 S6
    2003 Lexus IS300T
    Nov 06 2009
    Chii
    On the contrary. More concave design will be less likely to clear the brakes.
    well, i guess i will double check with them since it wont hurt... but they did tell me the 20x10 +45 will fit. they even steered me away from +35 offset because they didnt think it would fit right, but im guessing that has more to do with the fender than the brakes
    -Mike
    2013 S6
    2003 Lexus IS300T
    Nov 06 2009
    Chii
    yes, you should double check. I just went through this, trust me. And I think S6express has 20x10 et 35 and his looks great IMO.
    what size/offset did you have issues with?
    -Mike
    2013 S6
    2003 Lexus IS300T
    Nov 06 2009
    Chii
    Keep in mind that width and offset are not the only factors to be considered. The design of the wheel plays a major part in the fitment. The S6 brakes are huge, and more concave wheels don't clear the brakes. This is why if you look at the S6's here with aftermarket wheels, you don't see a lot of wheels with the deep dish look. I was also told this by several vendors when I went through this process.
    I would recommend 20x9.5 et 35-39. Of course it all depends on the look you are trying to achieve.
    just got off the phone with rohana and they said the +45 does not clear the brakes :(....... well, thank you for warning me about this and helping me avoid a big headache
    the guy i spoke to pointed me to the +33 offset, but i think might stick out too much or rub since im a little lower than most S6's. I have it lowered by vagcom and lowering link. he showed me pics of another S6 (diff wheel, same size 20x10+33)
    i want that concave look, but maybe i need to go with a staggered wheel setup and go 9"wide in the front and 10 in the rear... or go with 20x10+33 all around and get the fenders rolled/ massaged. thoughts?
    -Mike
    2013 S6
    2003 Lexus IS300T
    Apr 15 2012
    AriZona
    ^^ My car is not lowered so I better let the others help you on that one.
    Mar 14 2012
    PHL | BOS | SEA
    Lol $lick, you went to town on the quoted posts.
    I bumped this because for my own knowledge, not to help the OP. I'm debating getting some 20x10" AG wheels, and I would prefer to use my barely worn pzeros rather than spend another $1300 on PSSs at the moment. I hate stretch and the earlier posts looks no bueno IMO, but the one I posted looks reasonable.
    2014 S6 - SOLD
    Feb 11 2013
    C7 S6
    North San Diego
    i don't think there's that much to roll on the fender, it seemed pretty flat when I looked at it. only option would be to flare them out a little.
    maybe you can find a local s7 member who has a set of wheels you can test fit.
    edit: fronts can be rolled, the rears are flat.
    JOEY | '10.5 STi | '13 S6
    Cete | EuroCode | HRE | AWE | Deval | BFI | 034 Motorsports
    Established Member Two Rings BB c7's Avatar
    Jan 23 2016
    Chicago
    Hi i like ur set up. It is very nice. Is your car lowered? If so what did u use ? Any rubbing ?
