Results 1 to 29 of 29
    Established Member Two Rings RustyBucket's Avatar
    May 07 2013
    Eastern Canada
    Oll Filter Comparison: Fram (USA) vs. Mann
    So, when doing my oil change this week, I initially looked at the Fram filter because I read that they were often made in Germany and identical to the Mann Filters. The one I picked up at Canadian tire this past week wasn't. It was made in the USA and looked different than the Mann filter. I bought a Mann filter from the local VW dealer for only $2 more than the Fram.
    Since I had both in my posession, I decided to do a side-by side comparison...
    (My gf called me nutty for doing this)
    As you can see, the Fram is a more complex design with rubber and plastic end caps. The construction of the filter was also of good quality.
    There does not appear to be much difference in the thickness of the filter media between the two filters.
    Both filters came with the internal housing gasket
    The Mann filter came with a new crush washer for the drain plug
    The Fram filter came with a second gasket for the outside of the filter housing
    Given what I've seen from these side by side, is the poor reputation that Fram has deserved?
    Might the plastic inner ring cause sealing issues and result in oil getting past the filter?
    Granted, this comparison does also not go into the effectiveness of the filter media between the two nor does it answer any real-world questions of longevity.
    Thoughts?
    Wahnsinn Durch Technik!!
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Fram is totally fine for these cartridge filters... i ran them my last 2 oil changes. And I actually like how they had plastic end caps.
    However mine did not look like that one, no red inner ring and were made in China, just like many other OE parts.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    I think by eye it look good. I never tried anything else than Mann or Meyle for my VW and Audi. I think the oil filter quality is important, but i only know what i've read. I hope some people with knowledge can prove why the FRAM is worst that other. I would like to see some numbers as well.
    PS: dont worry about you GF, you're not alone in this.
    Do you have the Canadian tire part number, i'll check at mine in QC to see if they have it.
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    odd... we probably have about 2,000 2.0t Mann filters in the warehouse and I don't understand why it comes with a crush washer for the drain plug as OEM drain plugs/crush washers are all one piece and cannot be separated. The picture below shows a magnetic drain plug which comes with 10 washers that are removable.
    Senior Member Two Rings CharlesP2009's Avatar
    Sep 22 2012
    2009 Audi A4, 2009 BMW 335i Convertible
    The Copper State
    I've used the Fram PS-7010 and after 5,000 miles the thing collapsed down into the shape of a corset or hour glass. My OEM filters never do that after 5,000 miles so I'll be sticking with the Mann Filter. They're only about a dollar more on Amazon so I think the Mann is worth it.
    May 07 2013
    Eastern Canada
    Quote Originally Posted by Mister W View Post
    The Fram filter I got was CH-9911... $12.99
    Quote Originally Posted by CharlesP2009 View Post
    Aha... real-world experience!
    This is exactly the kind of thing I was wondering. You can only do so much with a visual side-by side comparison.
    It's a different part number though... How long ago was that?
    Senior Member Three Rings Jhad's Avatar
    Aug 03 2012
    '11 Touareg
    SEPA
    I have used the fram for my last 3 oil changes (easier to pick up at a local store), and i have not experienced any deformation. I do my oil changes between 3-5k miles.
    Veteran Member Three Rings clemsongt's Avatar
    Mar 09 2009
    05.5 A4 2.0TMT RIP: 88 MX6 GT
    Irmo, SC
    In the past, the FRAM filter PN CH-9911 was manufactured in Germany and looked exactly like the MANN filter. They recently (past 6-8 months) changed manufacturers and design. The PN is still the same but it looks like what you showed in your picture. I always ran FRAM filters (German version) with no collapsing or issues. I ran one of the new design and did not have any issues.
    I have run 1 MANN branded filter and it did not do well. It collapsed like a straw when drinking a thick milkshake. I don't know if it was the filter or if it was due to the PCV system I am running as I changed both at the same time.
    Disclaimer: In no way shape or form is the comment above representative of an automotive expert. It is merely the understanding and/or opinion of an automotive enthusiast, and as such, the knowledge he/she possesses may or may not actually be the truth.
    Senior Member Three Rings typeslone's Avatar
    May 09 2011
    06 A4Q 2.0T, 91 GTI VR6 Drag car
    North Jersey
    Quote Originally Posted by Hugh@EuropaParts View Post
    The original one is meant to be cut off and replaced. I think the original one from the assembly line is a tad bit smaller so there is no chance of it falling off during the assembly process, and so a tech can't forget to install one. All the drain plugs I have in stock here all have the ring that can't be separated without cutting it off.
    Some of the newer vag cars actually use a true crush style washer now instead the of the flat crush washer that the older cars used. Part N-013-815-7, it is round and has some sort off sealing goop in it that comes out when it gets crushed.
    91 GTI VR6 - all motor madness 12.62@106mph and dropping.....
    06 A4Q 2.0T - Revo Stg2/APR HPFP/034 HFC/TT Downpipe/EuropaParts Exhaust/Eibach Springs/Bilstein Sport dampers/RS4 Rear Swaybar/Fluidampr/RS4 engine mounts
    10 WRX hatchback - Torqued performance Stg1/Perrin/Whiteline/Enkei BR7/The wifes daily is faster than mine!
    Caste Systems Performance
    Lugtronic
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    FWIW my OEM/dealer filter had the whole "sucked up" issue too, I bought one on ebay, it's no different and Fram is available at any Canadian Tire... and there is plenty of info on bobistheoilguy forums discussing the CH9911 filter.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    I haven't used the Fram, but just from the picture, it looks like a better product. It looks like an equal amount of parties have had issue with either one. Go with the Fram, since it's cheaper and easier to find locally! Just because not OEM, doesn't mean crap. I know there are those out there that feel that way. But it's selective. For instance, I bet you those same people don't use OEM oil. Lol.
    And don't worry. My wife thinks I'm weird every time I'm taking pictures of something random I'm doing for a DIY I post or something. But it's fun. If you can learn something, and teach others something, worth the weird looks.
    2021 Audi S4, P34 Intake
    May 07 2013
    Eastern Canada
    Quote Originally Posted by clemsongt View Post
    From hearing about the "sucked in" issue happening on both OEM and Fram filters, I wonder if it might be something to do with the installation of the filter?
    I noticed when putting mine in that the housing with the filter didn't slide in really easily - there was some resistance. If the filter is subject to mechanical pressure from the ends while there is oil flowing through it, maybe it causes the centre to be pulled inward?
    And as far as the non-OEM oil goes, I put Shell Rotella T6 in for this change, which is not VW certified, but everyone who's used it gives it good reviews.
    Sep 22 2012
    The Copper State
    Yeah, Audizine LOVES Rotella T6 though no one really has a qualitative reason. Just butt dynos and "it feels better" or "seems quieter". I'll give it a shot sometime but thus far I've had the lowest oil consumption with Mag 1. Motul went quickly. Pennzoil lasted longer than Motul but not as long as Mag 1. Sometime I'll probably spring for oil analysis reports on various oils as well.
    Veteran Member Four Rings LoKisSpYdR's Avatar
    Jun 26 2012
    Brilliant Red B7 A4 2.0T Titanium quattro Tip - 2015 Q7 PP
    Reading, PA Area
    I agree that my car is a bit quieter and feels like it has more low end power, but I also saw a drop in consumption. Before I started using T6, I used Castrol Synthetic as per AoA's recommendation, and was burning 1+qts every 5k. Now I am consuming 1/2 qt or so, and that's with my PCV venting to my downpipe.
    B6 A4 1.8T Dolphin Gray qM
    4L Q7 3.0T Glacier White PP
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Head over to the bobistheoilguy forums, plenty more info than, "It feelz gud"
    There's tons of used oil analysis reports from users who sent it to Blackstone labs after various oil changes... it has an excellent ZDDP package and does not sheer down at high heats and stress. And the best part... it's 29-35 bucks at various stores like Walmart and NAPA and the likes.
    Oct 29 2005
    10speed
    San Francisco, CA
    There have been objective reviews from multiple places that prove its great stuff... It's also cheap
    - Clint
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    Can you provide a reference or link for these "objective reviews" please? So far I haven't seen any credible scientific evidence that shows much difference between any of the premium synthetic oil brands. As CharlesP2009 states its mostly anecdotal butt dyno commentary none of which is very persuasive.
    Jul 19 2011
    Northern Minneapolis, MN
    Lots of race teams and race engine builders only use Fram. I've been using fram for years also and it has never given me an issue. My truck is close to 300000miles, at least 100000 of those were at well over double the HP rating from stock and it hasnt missed a beat and still has low blowby and no sludge.
    May 07 2013
    Eastern Canada
    Quote Originally Posted by Brillo View Post
    Well, this iss no direct link, but does point you in the direction...
    Quote Originally Posted by Jay-Bee View Post
    The big issue for our FSI engines is the cam follower: Rotella contains higher levels of zinc which helps reduce wear on high pressure metal-on metal situations. It's also a known issue for older cars that use flat-tappet cams. The zinc content is one of my big motivators to go with Rotella.
    Sep 22 2012
    The Copper State
    Quote Originally Posted by RustyBucket View Post
    Meanwhile the higher concentration of Zinc dialkyldithiophosphates might be killing your catalytic converters.
    Oh wait, I forgot, most 'ziners like to cut out their cats and pollute the air.
    Senior Member Three Rings MedicCarter's Avatar
    Nov 26 2012
    70 Chevelle SS clone
    Sacramento
    I just put in a fram we will see if my oil pressure issue is fixed. The filter I changed was thinner than when I put it in so we will see I had a bosh but I have always had fram in my other cars. I have my butt dyno ready and my fingers crossed besides I just changed to NGK7 plugs and want to see if those do anything from my 6's.
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Twice now i've said to go to the bobistheoilguy forums, plenty of info there, i'm not gonna search for an exact link, if you doubt it then that's your job to do the research lol.
    Sep 30 2009
    Indiana
    Jay-Bee: I've been all through BITOG forums. While there is some useful information there it is replete with opinion and anecdote. As one example, the opinions on Royal Purple vary all over the place - some swear by it and others will never use it. I run a tribology laboratory and understand lubrication theory quite well, so I look for bona fide scientific evidence for differences in performance between brands of oil, filters, etc. Very little exists that I am able to find - on BITOG or anywhere else. I stand to be corrected on this point, and therefore asked for references. Regardless, the point can be made that some premium brands contain more ZDDP. It could reasonably be expected that they might perform slightly better in extreme metal-to-metal conditions. One such condition could be the hpfp cam follower wear issue that we are all familiar with, but there is no scientific study that high ZDDP oils are decidedly better relative to cam follower wear. We also know that the balance of zinc and phosphorous is important so just pouring a ZDDP additive into your oil is perhaps unwise. More is not always better. It is known that the wrong concentration of Zn and P can adversely affect wear and degrade the performance of the catalytic converter. Due to the later reason our wonderful government has pushed for lower levels of Zn and P, and many oil companies have complied. They have rebalanced the wear additive package to compensate so it's no longer just a matter of the Zn and P concentration in any particular brand of oil. The only point I was trying to make is to watch out for anecdotal stories and butt dyno testimony and look for scientifically credible evidence.
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    That part number is from a K&N oil filter, not Fram
    http://www.knfilters.com/search/prod...x?prod=PS-7010
    Veteran Member Three Rings wding2000's Avatar
    Jul 04 2015
    08 A4 Quattro Avant; 16 Golf MK7
    Use only Mann, Mahle, or Hengst OE filters, or genuine Audi if you want to spend money.
    08 a4 2.0t quattro avant | eng bwt 200hp | tip 6-spd zf 6hp19a | akebono ceramic | andros 18x8 et35 cb72.2 72-57 centric rings | pirelli p0as+ 235/40r18 | hu xtrons px5 mtce_gs_3.40 android 8 | rev d dv
    Jun 27 2011
    I got a filter at the dealer two weeks ago and it was branded MANN along the top. Mann is OEM.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jul 04 2015
    Yeah, they just mark up the price. Get OE filters - the best quality at lower prices.
    Active Member Four Rings waiapasi2006's Avatar
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    I think I have a k&n filter in there right now. I'll see what it looks like when I do my oil change.
    Waiapasi2006
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Not everyone will have issues but quite the many people hade had issues with fram (also made for mobil 1 filters) do yourself a favor and avoid them at all costs . I might be annoying by posting something about them every time it comes up but I'm doing anyone who comes up on this thread a favor. I have no idea who manufactures the k&n ones but my only recommendation is to go with Mann. I buy them at bulk from GAP or ECS with oil pan crush washers bolts and oil.
    Sent from my SAMSUNG-SM-G925A using Tapatalk
