Results 1 to 6 of 6
Thread: P1136 code
    Veteran Member Three Rings auh's Avatar
    Sep 20 2010
    2001 Honda CBR600F4i
    Highland Park, IL
    P1136 code
    What are some common causes for this code? Started throwing it about 5 weeks ago. Changed the vacuum lines on the front, checked my fuel injectors, not sure what to check next.
    The Car
    1998.5 A4 1.8TQMS: stainless steel brake lines, S5 style projectors w/5k HIDs, 2.5in catback, 710n, K04, FMIC, chip, EFK; SOON TO HAVE LIST: tp, snub
    The Bike
    2001 Honda F4i: currently in a lot of pieces as I put it back together this winter
    Veteran Member Four Rings RallyeBourne's Avatar
    Sep 10 2013
    San Diego County, CA
    Quote Originally Posted by auh View Post
    Bumping this up. I got the p1136 today.
    Sep 20 2010
    Highland Park, IL
    I swapped out my ICM and everything started working fine again. Are you missing at all?
    The Car
    The Bike
    Sep 10 2013
    Not sure. Not badly enough to trigger a fault code, but I don't have a vag cable yet to log the minor ones. The ICM and all coil packs were replaced by previous owner about 14 months ago. (He gave me all service records).
    I'm almost positive there is a leak somewhere. 14year old car on original hoses. :eek:
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    When asking for a code solutions, its generally nice to put up its meaning, ergo..
    17544/P1136/004406 - Fuel Trim: Bank 1 (Add): System too Lean
    Possible Solutions
    Check Mass Air Flow (MAF) Sensor
    Check Fuel Pressure Regulator
    Check Fuel Pump
    Check Intake/Exhaust System for Leaks
    Check Secondary Air Injection for Leaks
    Check Vacuum Lines for Leaks
    Special Notes
    Fuel Trim Info
    When this fault is stored and external vacuum leaks are not found, less obvious problems may be present:
    Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
    Check Brake Booster and Hoses
    Check Electric Vacuum Pump ( If Applicable )
    Check Crankcase Ventilation System for faulty components. When the PCV or Crankcase Ventilation System is faulty, vacuum is typically present under the oil cap and misfire faults are common.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Sep 10 2013
    Quote Originally Posted by Avant Nate View Post
    Possible Solutions
    Check Fuel Pump
    Special Notes
    Fuel Trim Info
    I didn't have all that information. But I'm pretty sure you just seriously helped me solve my issue. So thank you. And I will try to be more thorough in the future.
