Results 1 to 18 of 18
    Nov 11 2010
    Rochester, MN
    Those rusty eccentric bolts in the rear
    I spoke to the highly regarded Alignment shop today, and he told me that if the rear eccentric bolts are rusted solid, that they would either not be able to align the rear(if that's even needed) or would have to order the bolts in and then replace them.
    So my plan is to order new bolts this week and replace them myself before I even take it to them. Do you guys agree with this plan, or should I just hope that the rears are already in alignment and bring new bolts along just in case they need to move them. The eccentric bolts did look incredibly rusted when I was down there replacing stuff.
    I'm planning on giving them a PB Blaster enema. Is it safe to use mapp gas on those bolts, or are the bushings too close?
    The car does seem to be the slightest bit out of alignment after replacing the suspension last weekend.
    19" B8 S5 Peelers
    Apr 07 2011
    Just take your wheel off and test it for yourself. Throw a ratchet on there and loosen it up, if it loosens just bring it to them and when they tell you it needs new bolts you call bull shit. Either way your going to be getting an alignment so it won't hurt to loosen them and tighten them back.
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    I just replaced those a few weeks ago. One eventually broke free and I didn't need to replace the bolt. The other was seized into the bushing and I couldn't get it free after a lot of effort. Ended up having to pull the entire control arm out, pressing the bushing out and replacing it. You won't know what you're in for until you take a look.
    DG '02 A4 1.8TQM
    My Build Thread
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Exactly. Often it's corroded and frozen to the bushing... so you can turn it but it's just twisting the bushing. If this happens it is no easy task to remove, you basically need to remove it and drill out the old bolt, then press out or hammer out the bushing, and then replace. The bushings aren't expensive but this procedure is a serious PITA.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Nov 11 2010
    Rochester, MN
    So, what you guys are saying is that even if the nut breaks free and is able to spin, the actual bolt itself can be seized into the bushing? And let me guess, there's not enough room to hammer the bolt out the other side, is there?
    19" B8 S5 Peelers
    Veteran Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    The rear toe bolt hits the gas tank if you try to remove it, so to remove the toe bolt you have to completely drop the subframe. Mine is stuck and I can't figure out a good way to fix it. The camber bolt will likely be a bit easier to remove since there is a lot more room to get at it.
    Oct 23 2010
    2004 Atlas Gray A4 Avant
    Cranberry TWP, PA
    Galvinic corrosion FTL... I did mine about 2 weeks ago as part of an ongoing suspension/driveline overhaul on my Avant. The upper (camber) eccentrics were completely seized to the bushing sleeves and had to be cut out with a sawzall and replaced with fresh hardware. The lower (toe) eccentrics were stuck at first, but a generous application of Kriol oil and a 3 foot breaker bar worked them loose, eventually. Rotating them a few times got me to the point that they could be pulled and have a tap run on them to clean up the threads, before reinstalling them (with antiseize on the shank). BTW, subframe removal helps for doing this :p
    Subframe out
    Rear upper arms cut out (the inner non-adjustable bolts needed the body nut re-welded, too)
    Fresh bushings
    All back together
    And, yes, this is a pretty horrible procedure to do.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    The bolt that attaches the upper control arm to the subframe has a hidden nut. The nut is pressed into the subframe. Often this nut becomes loose and then you can not remove bolt. This becomes a problem if you have to replac the control arm due to the eccentric bolt breaking of frozen in the bushing.
    I removed my subframe and welded the upper control arm nut to the subframe so it will not come off. I thought I created a thread about it and posted photos but I can not seem to find it via searching.
    EDIT:
    Found my post. It was on another forum and a year older than I thought (was looking in the 2011 timeframe)
    http://www.euroaddiction.net/forum/b...html#post79812
    -Doug
    Oct 23 2010
    Cranberry TWP, PA
    Yeah, your thread on the subframe removal and hidden nut working itself loose issue is what convinced me to just drop the whole subframe instead of messing with that crap while it was in the car.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Steve Bassen View Post
    Cool! Glad to hear it was informative and helped you
    -Doug
    Mar 15 2010
    Bothell
    Any chance there is a possibility of lowering the subframe just slightly to replace the toe bolts on the rear, or does it need to come out completely to be able to get the bolt out and the new one in?
    Costco 92 Octane Gas - MANN Air Filter - 235/35/19 Tires w/ 36 PSI (cold) Tire Pressure - Grey Plastic Valve Stem Caps - 0° Front Toe - Rotella T6 5W-40 - 2 OEM B6 Keys - 18x8" Spare - Coin & Pen Filled Center Console - Rain-X on all 8 windows & Napa Cold Temp Washer Fluid - Bosch Wiper Blades (Valeo wipers suck big time!) - S4 Trunk Latch - Craftsman Tire Pump w/ Automatic PSI Shutoff - Belly Pan Delete (Weight Savings) - 3D Printed Rear Warning Triangle latch - 174,000 Miles & Counting
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    It is possible to get to those out with just lowering the subframe. But you may have to drop the rear exhaust mounts at the mufflers and watch your brake lines (ebrake and fluid lines). And you will need to remove the rear shock bolt to allow it to drop far enough.
    Sent from my SCH-I545
    Daniel J
    @gtg_drives
    Senior Member Two Rings JPC1.8t's Avatar
    Apr 06 2009
    03 A4 1.8TQM 97 Arctic Cat ZRT 800
    Would it be bad/dangerous to forego welding the hidden nut and instead replacing it with a standard nut and possibly a lock washer?
    I don't know the exact purpose for it being pressed in, maybe diagnosticator can chime in, I suspect it's just for ease when making repairs at the dealer?
    I pulled my subframe to replace all my rear alignment bolts and my pressed nuts are toast.
    Also.. Is there a way to recondition or replace the horseshoe thing that holds the abs sensor wire and also contains the eccentric washer for adjusting the camber?
    Junior Member Two Rings
    Oct 23 2021
    MI
    EDIT: Found my post. It was on another forum and a year older than I thought (was looking in the 2011 timeframe)
    Sry to resurrect...but hoping for feedback specifically on re-installing the rear subframe, from those that have removed it.
    dougyfresh - do you recall any major issues re-installing the rear subframe? Any problems getting a *good* alignment done afterwards? Any other insights you remember...from 10 years ago..(!).
    SlickFix (if you're still around): anything you remember about your work? Did you end up dropping the rear subframe? Any insights or things to avoid?
    Thanks in advance to all.
    And for anyone else stumbling on this :
    press/recessed nut: N91036002 / N-910-360-02
    Direct link to the internet archive of dougyfresh's quoted original thread [ euroaddiction site is perhaps long gone.. ]
    https://web.archive.org/web/20130603...html#post79812
    Veteran Member Three Rings Dr.B6Banter's Avatar
    Sep 26 2017
    B6 A4 1.8T, B8.5 SQ5
    NB, Canada
    Quote Originally Posted by easyAudi View Post
    In trying to replace my rear control arm bushings and subframe bushings with poly for the track, I'm going through this same process this winter and running into the same findings described above. I should have everything back together in a month or 2 so I'll report back if I have any issues with getting a good alignment.
    I know for certain that the front subframe has alignment points to the chassis in the wheel wells where you can use a VAG tool to confirm everything is in line but not sure if there is such a thing for the rear subframe.
    B6 A4 1.8T Nottro 02X 6spd Conversion | GTRS | IE Forged Rods | Suspension/ Subframe Poly Bushings | 18z BBK Front & Back
    B8.5 SQ5 3.0t | JHM 207mm Crank Pulley | IE Dual Pulley Tune & ZF8 TCU Tune | CTS Test Pipes, Downpipes & HX | AWE Touring Exhaust
    Veteran Member Three Rings codemode's Avatar
    Sep 01 2019
    EU
    Unfortunately there aren’t any alignment points for the rear. Don’t know why they did that.
    A4 B6 1.8T Manual FWD 2002
    Painted lowers, USP front
    18'' RS4 ET 35 Replicas
    Oct 23 2021
    MI
    Quote Originally Posted by Dr.B6Banter View Post
    ...I should have everything back together in a month or 2 so I'll report back if I have any issues with getting a good alignment.
    one install tip - tighten and seat this press-nut before final subframe installation. (I'm assuming you're getting new press-nuts. sadly, only available from audi)
    Tighten the bolt to make sure this fully sets in place. Mine tightened down fine, but a closer look and they weren't properly seated and started crushing the lip of the press-nut mounting hole. I would have never seen it if I first bolted up the subframe.
    Thanks for adding to this, and let us know what you learn w/the alignment. Finished my rear subframe a while back, but I haven't done an alignment yet, as I'm finishing front control arms, shocks ,etc.
    ...the front subframe has alignment points to the chassis in the wheel wells where you can use a VAG tool to confirm everything is in line but not sure if there is such a thing for the rear subframe.
    For the front alignment holes, you can use the stock lugnut wrench/handle. ..it's a really good fit. Not perfect, but no need to buy the tool. And 2nd what codemode said - no alignment holes in the rear.
    Sep 26 2017
    NB, Canada
    Just got the rear end back together and got an alignment. I’m still trying to dechiper the alignment results but seems like they didn’t have any issues dialing it in.
    Interestingly on the front passenger side of the rear subframe, there seems to be a grommet covering a hole in the body that lines up with something that looks like an alignment tab on the subframe. A similar alignment tab exists on the rear drivers end of the subframe but no such hole in the body to aid with alignment.
