Results 1 to 8 of 8
    Sep 27 2010
    Chicago, IL
    Xenon Headlight Warning Light: Fault Codes 01535 01539
    Hi AZ'ers,
    I recently had headlight pulled for repair with the ECS Headlight Repair Kit. Upon reinstallation, I got the warning light.
    Fault Codes:
    01535 & 01539
    If this warning light means I need to have my headlights adjusted, how do I go about this or do I need to go to the dealership?
    Here is my diagnostic read out:
    Monday,26,August,2013,15:48:21:36366
    VCDS Version: Release 11.11.6 (x64)
    Data version: 20121223
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAULC68E74A176516 Mileage: 104240km/64771miles
    Address 01: Engine Labels: 06B-909-518-AMB.lbl
    Part No SW: 8E0 909 518 AK HW: 8E0 909 018 A
    Component: 1.8L R4/5VT G 0003
    Coding: 0016711
    Shop #: WSC 12848 408 452102
    VCID: 79F9038F33575CD0675
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 3429
    Coding: 04275
    Shop #: WSC 06435
    VCID: 264318F3C26903287A7
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AD
    Component: A4 Klimaautomat 1323
    Coding: 00000
    Shop #: WSC 63351
    VCID: 63C541E7F1DBB6005D9
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 F
    Component: int. Lastmodul USA 0517
    Coding: 01013
    Shop #: WSC 63351
    VCID: 3561CFBF0FCF78B0C3D
    Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
    Part No: 8E0 035 593 A
    Component: SDAR XM 0010
    VCID: 275D15F7C5631A20411
    1 Fault Found:
    02635 - Tuner Not Enabled/Activated
    35-00 - -
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 K
    Component: Airbag 8.4EP 1001
    Coding: 0010607
    Shop #: WSC 63351 000 00000
    VCID: 3F8DAD976DF3B2E0191
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0611
    Coding: 01041
    Shop #: WSC 63351
    VCID: 3E73D0933AF9BBE8127
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 P
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 01231
    Shop #: WSC 02120
    VCID: 3663C8B312C973A8CA7
    WAULC68E74A176516 AUZ6Z0C0430994
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BB
    Component: Komfortgerát T7B 1512
    Coding: 11788
    Shop #: WSC 63351
    VCID: 72EB34A33E212F8826F
    Subsystem 1 - Part No: 8E1959801
    Component: Tőrsteuer.FS BRM 0004
    Subsystem 2 - Part No: 8E1959802E
    Component: Tőrsteuer.BF BRM 0004
    Subsystem 3 - Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0004
    Subsystem 4 - Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0004
    Address 55: Xenon Range Labels: 4Z7-907-357.lbl
    Part No: 4Z7 907 357
    Component: dynamische LWR D09
    Coding: 00060
    Shop #: WSC 63351
    VCID: 0407627B14951138043
    2 Faults Found:
    01539 - Headlights Not Adjusted
    35-00 - -
    01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
    30-00 - Open or Short to Plus
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 195 H
    Component: symphony II NP2 0410
    Coding: 01200
    Shop #: WSC 00003
    VCID: 2C57EADBDC853978AC3
    End ---------------------------------------------------------------------
    Dec 05 2007
    Bulb out warning. Either you forgot to plug something back in or one of your headlight bulbs is really out.
    Sep 27 2010
    Chicago, IL
    The headlight is working, so I believe that's not the problem.
    I have the V-Checker Pro from ECS Tuning. It has the option 55 and 29 like the VAG-COM, but it doesn't work!
    http://www.ecstuning.com/Search/Site...hecker/ES9950/
    Registered User Four Rings
    Oct 27 2007
    NA
    It looks like auto-leveling sensor has some problem.
    Dec 05 2007
    That pic was not there before. He posted a pic with the bulb out warning.
    Sep 27 2010
    Chicago, IL
    True, delayed upload. I just thought the Google image wasn't doing my claim any justice. Could it be that I need to disconnect and re-connect?
    Sep 27 2010
    Chicago, IL
    So can anyone verify that the VAG-COM fixes this issue?
    I don't want to buy another Diagnostic tool that is useless.
    Sep 27 2010
    Chicago, IL
    Quote Originally Posted by tuntsfaah View Post
    FIXED
    Yup, the Ross-Tech VCDS (VAG-COM) resolved this. I found a very detailed write-up HERE
