Results 1 to 4 of 4
    Veteran Member Four Rings Audi_S4's Avatar
    Feb 20 2008
    belgium
    VR6 24v Turbo questions ...
    I know this is the 2.7TT platform but lot of guys have knowledge about the VR6 engines here and the 3.2 subforum in the A3 section isn't that crowded
    I'm in such a debate with myself here since I saw the cars Compsport in Polen made from stock R32 engines!
    11.3 @ 130mph
    10.8 @ 133mph!
    Only things these guys have are ARP rod bolts and head spacer kit ...
    Now on to me
    I have a complete turbokit from 034 Motorsport and initially my goal was 500chp but now I wanna go a bit further (+550chp) to obtain the numbers that the cars above make +-
    Precision PT5858.64 Ballbearing
    3.5 Inch downpipe
    2.5 inch intercooler piping
    Tial 38mm wastegate
    60x30x7 intercooler
    Cast manifold
    550cc EV14 injectors
    AEM 3inch air filter
    Also have this stuff that I allready bought:
    - 3 inch custom cat back
    - AEM Water/Meth kit
    - RS4 B5 MAF
    - Bosch 044 and FP34 tank
    - New chain and guides
    - ARP Rod bolts
    - ARP Main studs
    - Head studs
    - New oil pump
    - Glyco bearing main and rod
    Haven't bought a compression spacer yet
    Now what I'm brainstorming is , I bought a complete 3.2 24v engine and DSG gearbox for an extremely nice price that I couldn't refuse. It's in my garage and I was planning on taking it apart and getting it completely freshened up to get boosted , paint the block, powdercoat the valve cover, all new gaskets and seals etc etc
    Now it comes:
    New piston rings aren't cheap for these pistons and if I take the price of the head spacer + 2 gaskets + the price of new OEM piston rings I can almost buy JE drop in pistons 8.5:1 comp ratioB-ut then I'll have rod bolts, main bolts, head studs , pistons and no rods ... Sounds retarded no ? Or do you guys say save the 6-700€ for something else
    Now my buddie bought an A3 3.2 Manual and he's gonna go loco with a PT6466 and fully built to highest spec engine aiming for +700whp so he's making me crazy
    Then again if I wanna do +600chp I'll probably have to use another turbo , intercooler piping, intercooler and my 550cc injectors won't be sufficient anymore + the DSG gearbox casing is only rated at a max of 675-700nm so anything above 600chp and 700nm is waiting for it to pop
    I was also thinking of freshening up the head and putting in inconel exhaust valves and titan retainers and springs cause I'm not gonna rebuild the whole engine like it was brand new and then just put on that second hand head with 150k km just like that but the .64 housing on the turbo won't let me revv +7000rpm cause it will probably die out up top no ... ??
    A3 8P DSG 3.2 S-Line : Billstein PSS / OZ Superleggera / 034 Sway / 034 Spherical bushes
    Oct 29 2005
    10speed
    San Francisco, CA
    1. Pick a horsepower number that you want (you don't seem too sure)
    2. Build motor accordingly (get JE pistons, not headgasket spacers)
    3. Put on turbo to support goals
    You have a spare motor to build (which is the right way to do it), take the extra time and spend the extra money to make sure it's properly done
    - Clint
    Apr 18 2007
    ny
    OP, stop watching youtube videos.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    Build the motor and get supporting mods that can handle larger turbo applications so you can switch/upgrade if you arent satisifed with your first choice turbo. A little more time and money to have a engine with rods/pistons will go a long way. You have the spare motor so you dont need to rush it.
    That's my suggestion as you dont sound certain on how much power you want to push.
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
