Results 1 to 7 of 7
    Nov 21 2012
    Ohio
    Axle Nut and CV shaft Torque Spec.
    If I remember correctly the torque spec for the axle nut is 179ft/lb + 180deg, just pulling this out of my bad memory so correct me if I'm wrong. I also need the torque spec for the bolts that hold the CV shaft in... I have looked and I see blue loctite them and impact the shit out of them, not precise but if others agree that's what Ill go for...
    Also should I re-grease the inner bearings of the CV shaft. Its OEM with 190k on it, it looks okay but just wondering.
    One more question while I'm at it. I replaced my clutch slave and master and bled the crap out of them, I have pressure that builds in my clutch pedal. When I force it to the floor and let it up it comes up slowly and whines the whole time? Is this normal to a freshly bled system or is that caused by air still trapped inside one of the two.
    Nov 21 2012
    Ohio
    Bump.
    Veteran Member Four Rings ilyafil's Avatar
    Nov 03 2011
    Bay Area , CA
    I just apply oil to the axle bolts and gun them on as tight as it will go, no Loctite. The 6 smaller axle bolts are 55Nm. Not necessary to re-grease unless the boot broke. Air maybe still trapped in your clutch line.
    "Basically the B7 is the girl you bring home to mom, and the B5 is her slutty sister."
    For Sale: Neuspeed Sport Springs
    Nov 21 2012
    Ohio
    Okay cool, Ill gun the shit out of the axle bolt...
    The clutch I got bled enough to where it engages at the very top of the stroke guessing it needs bled quite a bit more. The guys at the shop say it should work its way down, but I don't see it working itself anywhere without bleeding it more, correct?
    Nov 03 2011
    Bay Area , CA
    Just bleed it some more, and see if any more air comes out. I bled mine not long ago because my clutch just stopped working all together. I bled it and it came back.
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Horrible advise.
    Axle bolt is a torque to yield bolt and I think it's 140 ft/lbs + 180 degrees. No impact can do this properly.
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    I just did my from cvs on sat. Cranked the bolt to about 140 on a tq wrench then as much as I could with a breaker bar.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
