Results 1 to 40 of 52
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Car overheating, coolant light on, but coolant res is full?!?!
    Car started over heating today, changed upper sensor and flushed with new coolant, drove over an hour fine on the highway, now overheating and coolant light is on, but my cooolant res is full and coolant sprays out when i loosen the screw on the hardline above the IM. Halp :(
    2016 S3
    Instagram- @Thisisastickup
    Established Member Two Rings RSicks's Avatar
    Jan 20 2012
    03 A4 Quattro 3.0
    Napa, CA
    How's the water pump? What codes are being thrown?
    Oct 27 2010
    Norwood, MA.
    Cant comment on either right now as im stranded. FTL.
    2016 S3
    Veteran Member Three Rings msharifi's Avatar
    Aug 13 2008
    Orange County Cali
    Did you mix 50/50 coolant and water?
    Oct 27 2010
    Norwood, MA.
    [QUOTE=msharifi;8785678]Did you mix 50/50 coolant and water?[/QUOTE
    More like 70% coolant to 30% water
    2016 S3
    Jun 27 2011
    Could be the reservoir cap isn't working. Could also be the water pump.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Aug 13 2008
    Orange County Cali
    If the cap was bad coolant would spill from the Bottom of the coolant tank. I think it wasn't mixed With correct amount of coolant and water.
    Veteran Member Four Rings elewsader's Avatar
    Mar 24 2006
    2003 A4 1.8T Avant MTQ, 2001 Audi S4 Sedan
    Central, IL
    Quote Originally Posted by msharifi View Post
    it's not necessary to have 50/50, his composition ratio should be perfectly fine for current temps; there's probably some blockage/flow issue, or failed water pump.
    Ed
    why say lot word when few word do trick.
    Jan 01 2012
    2004 A4 Avant
    CO
    Did you make sure you got all of the air bubbles out of the system? I've heard these cars can be picky and throw warning just from one of those.
    | 2004 A4 Avant | Gloss Dark Grey |
    | 2.7t K04 swap | 034 RSB | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | 6MT swap | APR S2 | APR Downpipe | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by jjvwg View Post
    Is there any way to get the bubbles out other than the bleeder screw on top of the hard line?
    2016 S3
    Jan 20 2012
    03 A4 Quattro 3.0
    Napa, CA
    I used to work at a radiator wholesale warehouse and what your describing briefly I would think is either water pump or clogged radiator. I have had customers flushing rads and the gunk loosens up and clogs it. Most of the time it's from power flushes. I wish I could give you the magic answer but something like that you will have to get dirty to find out.
    Veteran Member Three Rings POPO's Avatar
    Feb 02 2008
    2001 Chevy Tahoe, 2005 Audi A4, RIP 2003 Audi A4
    Somerset, NJ
    Not to thread jack but I have recently been experiencing the same problem, more so when I run the a/c. When I switch to heat and blast it, the temps come back down. I need to figure out what my problem is.
    2005 A4 2.0L Stroker- New South Vent Gauge|034 RSB|2.75" FMIC|GHL 2.5" Catback|PSi Concepts TD05H-20g|PSi Concepts Exhaust Manifold|Turbo XS EWG|Motoza tuned|
    RIP 2003 A4 1.8TQM
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by POPO View Post
    nono, threadjack away, hahah your describing my symptoms! On this 95 degree day I had to blast the heat to get home
    2016 S3
    Veteran Member Four Rings Tanzimur's Avatar
    Feb 21 2013
    97 Brilliant Black A4 B5 1.8T
    Warren, MI
    sounds exactly like a closed t stat not wanting to open......
    Jan 01 2012
    2004 A4 Avant
    CO
    Quote Originally Posted by Tanzimur View Post
    X2
    Nov 18 2012
    2003 Audi A4 1.8T quattro (slow), 2007 VW GTI (not as slow), and 2008 Honda CBR1000RR (fast)
    MD
    Quote Originally Posted by b6Hate4 View Post
    Bleed from the upper heater core hose
    Veteran Member Three Rings stelvio's Avatar
    Feb 13 2012
    ^ this. Make sure you bleed the system from the upper heater core beside the battery. Also thinking the T-Stat has retired..
    Dec 31 2010
    Berwyn,IL
    Are your cooling fans coming on?
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by Rausch View Post
    now that you mention it no! they are not.
    I have a new t-stat sitting at home, ill have to try and swap that out tonight.
    2016 S3
    Dec 31 2010
    Berwyn,IL
    I would look into your fans not turning on before you just put in the new t stat.
    Oct 27 2010
    Norwood, MA.
    Well, this would also explain why im not overheating on the highway.
    2016 S3
    Oct 27 2010
    Norwood, MA.
    Question for probably OG, if the lower CTS (the one that controls the fans) gets disconnected, should the fans kick on?
    2016 S3
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    According to the Mapped cooling strategy outlined below a failed lower sensor should cause the first fan to run.
    Engine Coolant Temperature (ECT)
    Sensor G62 and Engine Coolant
    Temperature (ECT) Sensor
    (On Radiator) G83
    These sensors both operate as negative
    temperature coefficient (NTC) sensors. The
    coolant temperature set points are stored in
    the Motronic Engine Control Module J220
    in the form of maps.
    The actual coolant temperature values
    are registered at two different points in
    the cooling circuit and indicated to the
    Motronic Engine Control Module J220 in
    the form of a voltage signal.
    * Coolant actual value 1 is measured at
    the cylinder head coolant outlet by
    Sensor G62 located in the upper level of
    the coolant distributor housing.
    * Coolant actual value 2 is measured at
    the radiator by Engine Coolant
    Temperature (ECT) Sensor (On Radiator)
    G83 before the radiator coolant outlet.
    Signal Utilization
    Comparison of the specified temperatures
    stored in the maps with the coolant actual
    value 1 temperature gives the pulse-width
    modulated signal for the application of
    voltage to the heating resistor in the Map
    Controlled Engine Cooling Thermostat F265.
    Comparison of the coolant actual values
    1 and 2 is the basis for activation of
    the electric Coolant Fan V7 and Coolant
    Fan -2- V177.
    Effects of Failure
    If Engine Coolant Temperature (ECT)
    Sensor G62 fails, a defined substitute value
    of 203°F (95°C) is used for coolant
    temperature control and the first fan speed
    stays activated.
    Sensor (On Radiator) G83 fails, the control
    function remains active and the first fan
    speed stays activated.
    If a certain temperature threshold is
    exceeded, the second fan speed is
    activated.
    If both sensors fail, maximum voltage is
    applied to the heating resistor in the Map
    and the second fan speed stays activated"
    Oct 27 2010
    Norwood, MA.
    OG you do too much for these forums, thank you.
    I scanned my car, although not with vag-com, and got no codes for the fan control module..I guess a course of action should be..
    -unplug lower CTS and see if either of the fans come on
    -change thermostat
    -measure voltage at the fans with my trusty fluke clamp meter....
    2016 S3
    Dec 28 2006
    Western Maryland
    If the thermostat fails to open it doesn't matter if the car is on the highway or sitting still. There will be no circulation through the radiator and the block is going to overheat. If the car is only overheating at idle or low speed but doesn't overheat on the highway that is an indication of a problem with the cooling fans and not the thermostat. If it only overheats when there is low airflow through the radiator I would look at the fans/lower CTS/fan control module first.
    Oct 27 2010
    Norwood, MA.
    Okay UPDATE with a little more info:
    - Fans come on only when I turn on heat/AC
    -I unplugged lower temp sensor and fan 1 did not come on.
    -Monitoring actual coolant temp on the HWY on the way home I saw between 173* and 193*, once i got off, and slowed down I saw temps as high as 210*
    -Before getting on the highway, the car died. Coolant temp was normal, car just shut off, but started right back up.
    -No codes related to any modules but again this has not been confirmed with vag-com.
    2016 S3
    Dec 28 2006
    Western Maryland
    Do both fans come on with the AC or only 1?
    How and where are you monitoring the coolant temperature? Your highway temps actually sound a bit low. Clicky click (Some informative stuff on mapped cooling systems). If I check the temperature on the upper hard pipe of my motor at idle it typically reads around 220°
    Oct 27 2010
    Norwood, MA.
    You know what? I take that back. I just went outside and started my car to be 100% sure the information im putting in this thread is accurate. Right now, neither fans are coming on, heat OR ac, nothing.
    Should also add while I was monitoring my highway coolant temps I had the heat running full blast.
    I was monitoring the coolant temp via the obd2 with a hand scanner that has the ability to display real time information of my maf, engine temp, Iat's ect..
    2016 S3
    Dec 28 2006
    Western Maryland
    So it sounds like your overheating is being caused by a lack of air circulation (no fans) at idle. Have you checked your fuses? Could also be a problem with the fan control relay or fan control module.
    Oct 27 2010
    Norwood, MA.
    My voltage meter right now is at work, I think I need to leave the Audi at home tomorrow and take the truck, once I get my meter I can test the continuity of my fuses. If not that, the I guess I'll just have to replace the relay and control moule, starting with the cheaper of the 2 first.
    2016 S3
    Oct 02 2006
    Wadsworth,OH
    When was the last time you bled the system? Air bubbles will cause your temp to fluctuate. Both fans should be on high at idle when the thermostat opens.
    Jason
    Oct 27 2010
    Norwood, MA.
    Jason
    Both fans are dead, not coming on (on their own). They come on and shut off at random and do not operate when i turn on the AC or when fan switch is pulled.
    1 more update. I pulled the ECU out and looked at the fan relay 219, dry as a bone. Other than water damage do these really go bad? I know anything is possible but a relay would easier then the FCM! I guess Ill just have to do them both.
    2016 S3
    Dec 28 2006
    Western Maryland
    Relay 219 in the ECM box is the ECM power control relay. The fan control relay is located underneath the dash on the drivers side. The 219 is often called the fan control relay because when it gets wet it powers up the circuit that supplies power to the fan control relay and causes the fans to run. Unfortunately my daughter currently has my notebook that has the Bentley loaded on it. I don't recall for sure which one is the fan control relay. Hopefully someone with a Bentley will chime in. If not I will have her bring the notebook by tomorrow so I can look it up for you.
    Oct 27 2010
    Norwood, MA.
    Is it fused? I checked the fuses in the door jamb and all rang out with continuity, but tomorrow I could drop the dash and continue testing if there is anything to be tested with a multimeter.
    If you could check that you would be going above and beyond O.G.... Always appreciate your efforts
    2016 S3
    Nov 12 2009
    2012 S4, 90 VW Corrado
    Louisville, KY
    Not for sure which one OG is referring to, so here's some info from the Bentley. Hope this helps.
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by CardFan View Post
    Thanks! Unfortunately what you posted is more complex than what my brain wants to comprehend at the moment hahah, Ill have to wait untill tomorrow to dive into schematics.
    2016 S3
    Aug 26 2005
    Correct. If it does not overheat on the highway, but overheats in stop and go traffic, then the rad fan is not working. Not a t-stat problem. The fan on the driver's side is the radiator cooling fan. The fan on the right side is the A/C condenser cooling fan and only runs when the A/C is in cooling or AUTO mode. If coolant overflows from the expansion tank when the cap is loosened, then there is air still trapped in the cooling system. I don't understand why so many guys have trouble purging air from the cooling system after maintenance, and repairs. I just fill the system and allow time for the coolant to slowly drain into the system may take half an hour. With the bleed port plug removed, watch for coolant to appear and rise in the hard pipe. when the coolant fills the pipe, replace the bleed port plug then top off the tank and replace the tank cap. Start the engine and increase idle speed to ~2000 RPM for two min. Turn the engine off and allow the system to cool down for 1/2 hour. Top up expansion tank, replace cap and drive car.
    Vorsprung durch Technik
    Oct 02 2006
    Wadsworth,OH
    It could also be your cooling fan sensor. If I remember correctly its located on the driver side lower radiator hose.
    Jason
    Oct 27 2010
    Norwood, MA.
    Jason
    That is correct, but when this sensor is disconnected, the rad fan should automatically come on, such is not the case.
    2016 S3
    Dec 28 2006
    Western Maryland
    I guess my memory isn't what it used to be. The B5 has a high speed and low speed fan control relay underneath the dash on the drivers side. The B6 does not. The B6 fans are controlled completely by the fan control module. There are two fuses associated with the system. there is a 5 amp control voltage fuse on the fuse panel located on the drivers side of the dash and there is a 40 amp fuse located underneath the drivers side dash that provides power to the fans. The fan control module gets activated with the ECM power control relay via the 5 amp control voltage fuse. Input is also required from the lower CTS. I don't think fuses are your problem.
    You mentioned that your fans now come on and off at random intervals. That sounds more like a frayed/broken wire than a relay control problem. Take a very close look at the connections on the fan control relay for any signs of damage. Another possibility is that the fan control relay is defective.
    Good luck!
