Originally Posted by
RicardoTG
How much gas do you have in the fuel tank? Does any gas leak out when you disconnect the inlet lines? Did you yank on any of the fuel lines during the change, potentially cracking/disconnecting one?
When I replaced my fuel pump and filter and ran the car without the back seat on, it was very clearly audible, but I only had a long (3-4 second) crank the first couple times I started her up. My bet would be on the battery.
If you have a manual, try a roll start.
Lines are fine, even if one were to be cracked or pulled off fuel would still be somewhere but there isn't. I just don't understand how the pump isn't pumping after a filter change. How would you explain this to a customer if you were to be working in a shop? Yes we changed the filter but you need this, this, and/or this now, it just doesn't add up. I would imagine the battery being the least of things to be affecting this, but I am interested in knowing how it would even relate, with it still being strong; haven't had any electrical or low voltage issues. It's very aggravating when the car was driven to the dealer to get the filter, then 20 minutes later it had a new filter on it and now it won't start. I didn't touch anything else either, just jacked it up, disconnected the lines, partially disconnected the one which still had pressure in it and let that leak out into a container, then popped the new piece back in. Oh, I also took off the gas cap, other than that I didn't fiddle with anything anywhere else. Perhaps I'll say a prayer tonight before I go to sleep and hope a miracle happens tomorrow when I turn the key.
