Page 107 of 153 FirstFirst ... 75797105106107108109117 ... LastLast
Results 4,241 to 4,280 of 6087
  1. #4241
    Mar 05 2013
    CA
    Quote Originally Posted by AvantNoir View Post
    Last week it was the dipstick tube shattering.
    Today, it was this:
    thanks for the warning. will check this out.
    did you accidentally lean on it or something?
    my dipstick tube looks pretty stale but I've already got an $8 replacement waiting to go in.
    I fear it'll be the least of my problems, and the easiest.
  2. #4242
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Quote Originally Posted by Spike00513 View Post
    Spike, I looked at it the wrong way. If you've got a replacement, get it swapped ASAP.
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
  3. #4243
    Feb 28 2017
    Flat rock Michigan
    Quote Originally Posted by Anthony k View Post
    Oh and now..... it won't start. Just cranks over and over
    Started with a shot of starting fluid
    Quote Originally Posted by Pswish View Post
    /\ Did you/can you pull Codes?
    Pull codes for sure. Starting issue may be a few things. For starters, ( See what I did there :D) it could be a crank position sensor or your coolant temp sensor at the back of the head in the plastic flange. Either of these can cause starting issues.
    Low fuel milage could be from bad 02 sensors, fouled plugs, MAF, clogged cat etc.
    Jason
    Codes as follows
    PO172
    PO117
    PO175
    PO421
    PO431
    And there was some freeze frame data from PO172
    So 172, 175, 421, 431 are catalytic codes which the previous owner told me about them being clogged. But before I drop cash on catless downpipes I want to be sure I'm going to keep this car.
    The coolant sensor is 117 correct?
    The parts guy asked if it's 2 pin or 4 pin. I said get me both.
    Should I replace the MAF too? $170 from my guy or $62 on amazon
    Also. A coworker said I should turn the key on wait 10 seconds and then try starting. So far that has been working. So his theory is that fuel pressure is bleeding down. So now I have to track that down if in fact that is the problem. But the first time I had the no start I on and off cranked it for at least 10 minutes, on and off. That should have built feel pressure to start it.
  4. #4244
    Senior Member Three Rings Pswish's Avatar
    Mar 25 2016
    2010 Suzuki VStrom 650
    Bay Area
    Codes as follows
    PO172
    PO117
    PO175
    PO421
    PO431
    Sounds like you have more than one issue. Fuel pressure bleeding down would be the fuel pump check valve in the pump or leaky injectors. Since you are running rich, this may point more to leaky injectors. Below is all the info on your codes:
    PO172
    16556/P0172 - System Too Rich, Bank 1
    Possible Symptoms
    • Irregular behavior
    Possible Causes
    • Fuel system
    • Excessive fuel pressure
    • Leaking or contaminated fuel injectors
    • Leaking fuel pressure regulator
    • Low fuel pressure or running out of fuel
    • Vapor recovery system
    • Air leaks after the MAF
    • Vacuum leaks
    • Improper seated engine oil dipstick
    • Stuck EGR valve
    • Oil overfill
    • Cam timing
    • Cylinder compression
    • Exhaust leaks before or near HO2Ss.
    PO117
    16501/P0117 - Engine Coolant Temperature Sensor (G62): Signal too Low
    Possible Symptoms
    • Difficulties with starting a cold engine.
    • Starting the engine when engine is warmish or warm, idle rpm immediately is 1200 - 3000 rpm.
    • RPM at idle is irregular.
    • With all engine temperatures seldom idle rpm will vary between 900 - 1000 rpm.
    • With engine warm (90 °C) the engine temperature suddenly drops (70 °C) and slowly comes back to 90 °C.
    • Bad acceleration during warming up.
    • Diesel: an indication is extreme long time burning time of the glow indication light.
    • Engine Overheating
    Possible Causes
    • The electrical signal coming from G62 is too low
    • Wiring and/or connections faulty (short circuit?)
    • Engine Coolant Temperature Sensor (G62) faulty
    • Mechanical problems in cooling system
    Possible Solutions
    • Check wiring and connections
    • Check / Replace Engine Coolant Temperature Sensor (G62)
    • Check cooling system and correct overheating condition if present
    Special Notes*
    • In MY 1995-2002 (?) in Europe at VW-cars the G2/G62 had the bad reputation of breaking down often. The default G2/G62 is black and all replacements are green.
    PO175
    16555/P0171 - System Too Rich, Bank 2
    Possible Symptoms
    Possible Causes
    • Fuel system
    • Vacuum leaks
    • Stuck EGR valve
    • Oil overfill
    • Cam timing
    PO421
    16805/P0421/001057 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
    Possible Causes
    • Warm Up Catalyst Bank 1 faulty
    Possible Solutions
    • Check Warm Up Catalyst Bank 1
    • Set Readiness
    • Replace Warm Up Catalyst Bank 1
    Special Notes*
    • When found on the following, there may be a firmware update:
    • 2000 - 2001 Passat with ATQ engine, see TSB 01-07-07 (TPI 2010372)
    • 2000 - 2001 A4 or A6 with ATQ engine, see TSB 26-08-07 (TPI 2013086)
    • 2001 Allroad with APB engine, see TSB 01-08-20 (TPI 2005579)
    • 2001 A4 or A6 with APB engine, see TSB 01-08-34 (TPI 2012357)
    PO431
    16815/P0431/001073 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
    Possible Causes
    • Warm Up Catalyst Bank 2 faulty
    Possible Solutions
    • Check Warm Up Catalyst Bank 2
    • Set Readiness
    • Replace Warm Up Catalyst Bank 2
    Special Notes*
    Citation credit to http://wiki.ross-tech.com
    Early 04 1.8T Dolphin Grey A4 (planning on selling), 165k miles and counting, often in bay area traffic, LED lows & HIDs fogs, ECS Snub mount, Electric systems specialist, Photographer, 2018 Q5 on order.
  5. #4245
    Feb 28 2017
    Flat rock Michigan
    I don't have a funky idle. Not that I've ever noticed. Never "dieseled". Acceleration is good. Even though the variable intake runner thing is broken
    I found injectors for $45 each. I'll replace them.
    Any idea on why I run out of gas at 1/4 tank?
  6. #4246
    Mar 25 2016
    Bay Area
    It takes more work for the fuel pump to grab fuel below 1/4 tank so if your pump is failing, that would be a likely symptom. You should get a fuel pressure tester before throwing parts at it or you may end up chasing rabbits.
  7. #4247
    Feb 28 2017
    Flat rock Michigan
    I have fuel pressure gauges
    Just nothing to adapt to the Audi fuel rail
    I fill it up now, every 100 miles or about every other day.
  8. #4248
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    Kentucky
    You can pick up a tester for 20 bucks at Autozone, or an affiliate in your area, which as the adapter for the shrader valve on the fuel rail.
    2015 Daytona Grey Audi S4 | DSG
    2013 Ibis White Audi A4 | Tip
    2006 Brilliant Black A4 Titanium | 6 speed
  9. #4249
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    What year is your A4? Is it a Quattro? If so, this may be your issue with running out of gas at 1/4 tank: Clicky click®
  10. #4250
    Aug 19 2013
    minnesota
    OG is like Inspector Poirot of cars, maybe a bit Columbo mixed in.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
  11. #4251
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    Today I f'ed up by pouring a bucket of water directly on to the car.
    Paint is f'ed
    Gasket went inwards and drips water sometimes
    Also mein logo came off
    "Beep beeeep bloop boop" - R2D2
  12. #4252
    Mar 25 2016
    Bay Area
    Quote Originally Posted by Willënskraft View Post
    Does it have a part number on it? Mine was a casualty of dealership maintenance.
  13. #4253
    Oct 14 2011
    Norcross, GA
    Yes it's 06C 108 940, but thinking about gluing it back on.
  14. #4254
    Mar 27 2014
    06 Grand cherokee, b6 a4
    Philadelphia
    Seems like my j plug is leaking Wouldn't be so bad if it wasn't 15 degrees out.
  15. #4255
    Jan 02 2017
    Ontario, Canada
    Paint is f'ed
    How on earth did that happen?
  16. #4256
    Oct 14 2011
    Norcross, GA
    Quote Originally Posted by Chemmie View Post
    Was washing my car and just when I was about to rinse the soap off. The faucet broke. I did have a bucket of clean water left so I thought strategically by pouring the water on the roof first. That way the water can cover the majority of the body. Unfortunately, that was a serious error.
    It turns out the nut on the faucet cracked and broke in half. I turned off the main water valve to repair for now.
  17. #4257
    Jan 02 2017
    Ontario, Canada
    [ten char]
  18. #4258
    Oct 14 2011
    Norcross, GA
    [ten char]
    Me too buddy me too
  19. #4259
    Mar 09 2017
    Colorado Springs/Colorado/USA
    Ugh! Brand new AC compressor blew the rear seal after only 20 minutes of being installed! Cost me the $150 recharge - now I'm paranoid AND broke!
  20. #4260
    Aug 19 2013
    minnesota
    Quote Originally Posted by ClimbCO View Post
    I suspect there is something else wrong or the rebuild was bad. Don't overcharge the system and make sure you're proportioning valve is good to go. Also, was this system properly evacuated and was the desiccant bottle replaced? What's the status of the pag oil in the system?
  21. #4261
    Mar 09 2017
    A shop charged the system and said it was probably defective. As for the oil, I know it had about 4oz or 150ml when I installed the compressor - I've called 4 dealerships asking about the amount of oil and they all tell me something different. Nothing was replaced other than the compressor.
  22. #4262
    Mar 05 2013
    CA
    TY, will do
    I heard the way it's set up, it's always spinning.
    Maybe you will track down a shorter bypass belt to install, so you can drive without it in the meantime?
    Well if it's charged, hopefully has the right kind of and amount of PAG oil, and is new, then that'd suck for it to have issues.
    Quote Originally Posted by jacobsen View Post
    See this guy might now. I don't even know what a proportioning valve. I know there is a conical mesh filter thing, by the cabin air filter.
    I've heard mixed opinions on whether to replace the desiccant bottle (it's called evaporator I think) but maybe it's cheap and could use it after so many miles?
    Paint is f'ed
    ??? how?
    I thought cars were designed to withstand water. And they drive in the rain.
    could temperature change cause it, if it was in direct sunlight and the paint felt hot?
  23. #4263
    Mar 09 2017
    Yeah - not sure about the proportioning valve either, but the mesh tube is the orifice tube - it collects all the metal debris from the compressor. None of that was changed. I do have a belt that is on which bypasses the compressor, but it's getting really warm here...hahaha - gotta fix it soon.
  24. #4264
    Aug 19 2013
    minnesota
    Yes by proportioning valve I mean orfice tube. If you did not replace the desk can bottle may I ask how long it was disconnected and exposed to the elements? The trouble is it's a one-time use item, you have a very limited amount of time to hook up your AC system as soon as you open the desiccant bottle and install it. If you did not replace it it may have collected moisture and that may have froze inside your AC system. But if the entire procedure was done correctly then I suspect there may be something wrong with the pump remanufacture. What brand of pump is it Denso or Bosch or Valeo?
  25. #4265
    Aug 19 2013
    minnesota
    You have to place the system under vacuum for a while to confirm there are no leaks. This can help drive out moisture from the system the longer you keep it on vacuum.
  26. #4266
    Jul 21 2013
    B6
    edited because I asked again
  27. #4267
    2003 A4 1.8TQM
    Markham, Ontario
    Finally got round to investigating / replacing the passenger side fog/DRL light (in Canada).
    Managed to get the grill off, despite one of the tabs being broken, so there was no where to put the trim tool to depress it.
    Undid the 2, rusty and corroded T25 screws to pull the assembly out. Went to untwist the bulb to remove it from the housing, and it separated at the join between the plastic and metal sections of the bulb !?!
    Looks like it had corroded away entirely. Had to clean off a ton of crud etc before removing the balance of the bulb by untwisiting it from the housing with a pair of pliers. It was only upon reassembly of the new bulb to the lamp housing that I noticed the housing has a major crack in it, which is most likely letting in water/snow/etc - this would explain the bulb corroding apart, the huge amount of crud on the housing, and why trying to get it back into the fascia opening was a little tricky, as it's "expanded" from stock ;)
    But it works (for now) - now to figure out the intermittent 'Air Bag' light (only came on during the cold snap this week) and try an source a replacement glove box latch (release finger broke off a month or so ago..)
    The joys of owning a 13yr old car with ~356,000 km on it :)
  28. #4268
    Feb 28 2017
    Flat rock Michigan
    2004
    It's Quattro
    Do I need any special tools to pull the pump?
  29. #4269
    Dec 28 2006
    Western Maryland
    2004
    It's Quattro
    Then I suspect it is your SJP as discussed in the linked thread. Some good information on removing the fuel pump in here. Clicky click®
  30. #4270
    Veteran Member Three Rings oaybar007's Avatar
    Sep 17 2006
    Ellicott City, MD
    [/QUOTE]
    Add me to the list. Went to check my oil yesterday and the logo kicked the bucket.
    Brilliant Red 2004 A4 1.8t Quattro 6spd Ultrasport
    Florett Silver 2016 S4
  31. #4271
    Junior Member Two Rings KAPPAZILLA's Avatar
    Apr 06 2015
    DFW Metroplex
    My glovebox hinges was already broken but now I can't open it to get my winning scratch off... #LifeofaB6owner
  32. #4272
    Apr 06 2015
    DFW Metroplex
    Now today to go to lunch and the car was fine but when I leave to go home I notice my car has pissed itself.... coolant all on the ground. Lucky I had some coolant in the truck from a while ago. I think it's the lower radiator hose... that's the one on the passenger side of the car.
  33. #4273
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    oil "sensor" light came on today.
  34. #4274
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by KAPPAZILLA View Post
    There is no lower radiator hose on the passenger side. Check the turbo coolant supply and return lines.
    - - - Updated - - -
    Quote Originally Posted by 5ktq View Post
    Be sure to get a hella sensor. If not you may be replacing it again in a few months.
  35. #4275
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Apply upward pressure on the bottom of the glovebox lid/door as if you are lifting it up, then with the other hand open the latch and open the lid.
    Don't lift the door away from the glovebox. What you want to do is align it properly as if it wasn't broken and then open it.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
  36. #4276
    Apr 06 2015
    DFW Metroplex
    Quote Originally Posted by eljay View Post
    Thanks
  37. #4277
    Feb 27 2017
    B6 & C6 avant. lots of VWs
    Philadelphia area, Penn
    back half of my headliner decided to take a shit on me today.
  38. #4278
    Veteran Member Four Rings egovreau's Avatar
    Sep 08 2015
    2017 Audi Q5, 1989 Jaguar XJS, 2005 Ford F-250, 2002 VW Passat Wagon
    Orting, WA
    Hop in my car, glance over at the cup holder, and the finish has bubbled up. Grrrr
    Look at the storage slot, that's doing it to. 😒
    Sent from the 7th Galaxy.
  39. #4279
    Veteran Member Three Rings 1.8Turbo4me!'s Avatar
    Jun 10 2009
    S.F, CA --> Houston, TX
    Pulled into my apartment garage and smelled burnt coolant which has me going 'uh oh'. Parked and popped hood to see smoke and brown liquid by turbo area. Then I took a peak under the car to see brown coolant which led me to check my expansion tank and voila, brown coolant!
    So at 150k, would it be a blown head gasket? And/or oil cooler? Possibly a bad turbo coolant line?
    What do you guys think?
  40. #4280
    Apr 17 2016
    kc
    Goto autozone. Rent a combustion gas tester kit. Viola.
    Been there done that. Oil cooler for me thank god.
