Results 1 to 28 of 28
    Senior Member Two Rings simplicity's Avatar
    Aug 24 2011
    SF Bay Area
    Changing power steering fluid
    Anyone have any idea how to remove the filter screen in the reservoir? I can't seem to get it out. I wanted to siphon the old fluid from the reservoir and fill with new fluid instead of pulling the hose out and possibly creating a mess/introduce air.
    2011 Brilliant Black A4 Sedan Quattro | 8 speed tiptronic | P+ | Sports Package
    APR Stage 1, EuroCode Alu Kreuz, Hotchkis F&R Sway Bar, Blesk license plate LED, Hoen Endurance fogs, Reiger Style Trunk Spoiler, RS4 Replica Grill, Podi Boost Gauge
    Dec 08 2012
    Moldova
    Yea, I would love to find out how to do that too.
    Audi A4 B8, 2.0 TDI. Retrofits: Bi-xenon. Front parking sensors with graphics. OEM Bluetooth. Servotronic - 1N3. Footwell lights. Color DIS. AMI. Audi Drive Select. EGR off. DPF off. 207BHP CAHA remap. Keyless Entry/Go. Lane change assist. B&O. Aux Heater.
    Aug 24 2011
    SF Bay Area
    bump
    Jan 03 2013
    Baltimore
    Looking to do the same. Anyone done this? Is it as simple as removing the old stuff, add new fluid, run the car, remove the fluid and repeated until it looks clean?
    Sent from my XT1096 using Tapatalk
    Mar 26 2012
    Charlotte, NC
    I use a Turkey Baster to remove the fluid from the reservoir and replace it with fresh fluid.
    I've tried to remove the screen but couldn't. I'd love to know this as well.
    May 09 2015
    usa
    I would only be able to get about half an inch of fluid if I used a turkey baster with the screen still in. I'm half tempted to just remove the screen. Heck, I managed to drive my '98 almost 200k miles without a screen, and that's on top of the 70k the previous owner put on it.
    Veteran Member Four Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    Do the b8.5s even have fluid?
    Sent from my Nexus 5 using Tapatalk
    Kyle
    2014 a4 Allroad /// Ibis, Unpainted Lowers (True AR)
    Mar 26 2012
    Charlotte, NC
    I think we have to replace the entire reservoir.
    http://www.ecstuning.com/Audi-B8_A4-...voir/ES390574/
    Aug 15 2014
    I thought it twisted locked somehow...
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    Quote Originally Posted by elscotto80 View Post
    The simplest way is to bring your car in for stage 2 oil consumption fix. All engine/accessory fluids changed for free!
    Quote Originally Posted by KFizz View Post
    Not for power steering.
    '11 S-Line A4 Avant
    '98.5 A4 2.8Q sedan retired after 14 years of service
    Jan 03 2013
    Baltimore
    Quote Originally Posted by dscline View Post
    Already had stage II complete prior to my ownership.
    May 09 2015
    usa
    I think the screen just spins. It probably pops into place, but in my limited prying I couldn't figure out how to remove it in one piece.
    Mar 26 2012
    Charlotte, NC
    Quote Originally Posted by misterpepper View Post
    Same here.
    Established Member Two Rings LTopher's Avatar
    Oct 19 2017
    2001 Jeep GC; 2011 Jeep GC
    South Carolina
    Found this thread while searching for an answer so I decided to drudge it back up. How are folks changing their power steering fluid in these cars? As mentioned above, I typically use an old turkey baster to remove old fluid and fill with fresh--turn the steering wheel a few times and repeat. Does the reservoir even need a screen?
    Another thing, what fluid is everyone using in their B8? Everything I've read points to Pentosin CHF 202, which is green. However, the current PS fluid in the car looks golden colored. Looking at the online owner's manual was no help since Audi conveniently decided not to mention it.
    Veteran Member Three Rings red4life5's Avatar
    Dec 29 2016
    2004 Audi S4 Avant
    Cleveland, OH
    I used dealer fluid; the Pentosin will work. I have a fluid extractor; I pull all I can out of the reservoir, unplug the return line. Cap off in the reservoir and plug my extractor into the line. I fill the reservoir then have someone start the car for 2 seconds and let it push all the fluid out while I put more in. You’ll see in the clear lines of the extractor the fluid turn green from the new stuff. Reconnect the line and you’re done
    2010 A4 S-Line Prestige
    2004 S4 Avant Greenwood Green
    2011 A3 K04
    2008 A3 -Sold
    2010 Audi A4 K04 -Sold
    Aug 17 2015
    California
    ^^^no risk of introducing air into the system?
    Veteran Member Four Rings rcprato's Avatar
    Jan 30 2018
    21 Jeep Grand Cherokee Overland
    Rochester, NY
    Quote Originally Posted by A4x View Post
    Since it is a recirculating system any air will get pushed to reservoir and leave the system.
    It is not like a brake system that is pushing fluid to expand the brake piston.
    You may be able to have wheels off the ground and turn steering wheel lock to lock and push fluid through the return line without engine running ?
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    works for any fluid
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Dec 29 2016
    2004 Audi S4 Avant
    Cleveland, OH
    Quote Originally Posted by rcprato View Post
    That’s what I would do to get the air out after but with the engine on. It really isn’t needed though. I’ve had no issues for 10K miles and a cross country trip with it
    2011 A3 K04
    2008 A3 -Sold
    Oct 19 2017
    South Carolina
    This works for the cooling system and for liquid cooled PCs as well.
    Which line is the return?
    Quote Originally Posted by JeriQo View Post
    works for any fluid
    Stop posting dirty pics of your significant other!
    Aug 17 2015
    California
    Quote Originally Posted by LTopher View Post
    So when bleeding the coolant system, you don't really have to worry about air getting in there?
    I don't know if the coolant constantly recirculates with the reservoir. It seems to me the fluid is just kind of sitting stagnant in the reservoir.
    Oct 19 2017
    South Carolina
    While the cooling system isn't exactly the same, the coolant does recirculate causing air to flow to the highest point in the system which is the overflow tank on these cars. When bleeding the system (burping) you would run the car for a few minutes with the overflow cap off (or radiator cap in other cars) so that the air can escape.
    Mar 30 2018
    Kentucky
    Contemplating replacing this fluid; is it necessary, if so, how often?
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    ^ Wondering the same thing. Mine has never been changed and I'm at about 90K.
    I'm as cool as a cucumber in a bowl of hot sauce.
    Mar 30 2018
    Kentucky
    Yeah, I'm at 111K never been changed.
    Though, they also told me when I bought car at 40k they had just replaced a turbo. They left out the engine part.
    Senior Member Three Rings FlyPenFly's Avatar
    Oct 29 2007
    Australian Shepherd
    San Diego, CA
    It's hydraulic fluid, might have some anti-rust and rubber conditioning additives in it that gets used up.
    2014 E350 Coupe
    2014 GLK350
    2010 A4 Premium Plus
    Established Member Two Rings JUNBUG361's Avatar
    Jan 08 2019
    1965 MUSTANG GT COUPE
    Antioch, Ca West Coast
    I remove the gravel shield remove the hose to the pump held by 2 hex bolts let the drain, remove the hose to the steering rack held by triple square bolt let drain. Purchased 2 new o rings & steering fluid from dealer
    Jan 09 2008
    SF Bay Area
    FYI for the filter... I popped it out pictures are here: https://www.audizine.com/forum/showt...1#post15034018
