Results 1 to 18 of 18
    Senior Member Three Rings BLACKS4-10's Avatar
    May 08 2010
    2011 Ford F-150 Lariat 5.0
    B8 S4 oil consumption
    My car seems to have an oil burning and/or consumption issue.Last year it went so low that the oil dash light went on to add a quart so I went to the dealer and had it changed.Now after about 4K miles after my most recent oil change.the level is just about to go past the "min" mark on dipstick after checking it.It's now at the dealer and mentioned this and they told me they would do a "consumption test" on the motor to see if and what they would have to fix.
    Has anyone had this "consumption test" done to their car?And if so what did they do to remedy the issue.
    My car has about almost 24K on it and I don't track,race or abuse this car other than driving spiritily every now and then as this is an S4.I know these cars can use up oil but is it normal to go through that much oil in that mileage span?(I always change the oil before 5K at either a dealer or Elite Motorsports).
    Thanks
    2010 S4 Brilliant Black- Black/Magma Nappa-Prestige-B&O-Carbon Atlas inlays-DSG-Nav/camera-35% Solar Gard tints-APR Exhaust-Eurocode Alu-Kruez stabilizer-Tyrolsport RCS kitEurocode Trufit intake-ECS 2-piece lightweight front and rear rotors with Akebono Euro pads=H&R rear sway bar
    Veteran Member Four Rings B8 S FOR's Avatar
    Feb 15 2011
    Pittsburgh, PA
    Did you do a hard or soft (Audi recommended) brake in? Frankly, I did a hard brake in soon as I took delivery. I drive it like I stole it..always. I have ZERO Oil consumption issues and I am at 33K. There are tons of threads on this specific topic on this forum. Search up in the box...
    AUDI 4 LIFE.........B9 S5 Cab Prestige/ Mythos Blk Met
    Gone but not forgotten:
    2015 B8.5 S5 Cab
    2011 B8 S4
    Jun 28 2012
    Hackensack, new jersey
    I have 2012 s4. This is happening to me too. Last oil change at 5000mi, it went very slow. It was at 1/4 mark on mmi at 8000 mi. After a recent oil changing at 13000 mi, it is now at 1/2 mark at only 500mi. I will have to contact my service adviser too.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Most of the few who have complained about oil consumption issues did the Audi recommended easy break in. I can remember No one who used a more aggressive or hard break in (and there is a difference between those 2) that has reported oil consumption issues. Audi does not care if your car burns oil. They set the limit for "EXCESSIVE" oil consumption so high (1 qt/1200 miles) that they will almost NEVER have to address a car with oil consumption issues. They do have procedure to test the oil consumption rate of the engines. But what's the point. Your car almost has to be spewing oil for it to consume more than a qt/1200 miles. IMHO,Pure Audi Bull $hit. I do vagely remember reading something about a faulty PVC valve or other part contibuting to oil consumption. I ask my Service Manager friend about that and he was unable to provide me with any details. Additionally, especially if you suspect oil consumption issues, GET A DIPSTICK. It is way more acurate than the MMI indicator.
    Jun 08 2005
    Lexus RX 350
    SE, PA
    If the oil consumption issue is not resolved, I would consider using a heavier viscosity oil . Especially in warmer weather.
    Jun 28 2012
    Yes I did a hard break in and I have a dipstick. It shows in both. Why it was fine before until recent oil change?
    May 08 2010
    Mentioned in my first post I DO HAVE a dipstick and the MMi is pretty accurate-at least in my car.Dealer did mention something about if it gets low B4 1200 miles which is really EXTREME but that's not my case luckily.I owned quite a few luxury cars before and never had this issue,must be the heat from the supercharger I presume.
    Quote Originally Posted by Dr GP View Post
    Dec 17 2008
    Charlotte, NC
    They've stepped up a lot on this issue lately and Audi is not the only brand having this issue. Google Lexus oil consumption sometime.
    Ol' Whitey - 1996 A4 2.8 quattro 5MT Arctic White w/ Remus
    #2 - 2008 A4 2.0T Quattro 6MT Quartz Gray - w/ AWE exhaust (1/08 - 1/11)
    #3- 2011 A4 6MT Quartz Gray - Prem Plus, B&O, Titanium - Full Gen1 AWE dual exhaust, Eurocode Everything, 3M Clearbra, Piano Black Dash Surround, MY10 rear headrests, Huper Optik, S-line Stoneguards
    #4 2014 Audi S4 6MT - Monsoon + Black optics Neuspeed exhaust, Eurocode bits
    Audi Brand & Audi Sport Specialist at Northlake
    B8 Titanium Club Member #4
    Feb 15 2011
    Pittsburgh, PA
    I somehow remember reading about Audi replacing a part on the engine somewhere that was defective to resolve this....can't seem to find where at here...it was listed somewhere in one of the threads.....
    2015 B8.5 S5 Cab
    2011 B8 S4
    Sep 30 2012
    I just ran into this issue myself today. I'm on about 10,300 miles, had the 5,000-mile oil change and that's about it. Tried to do a hard break-in, but opportunities to run WOT to redline are limited on the congested Philadelphia roads.
    Is it better to just have the oil changed, or is it okay to just add a quart and wait until I hit the 15,000 mile mark? I added oil today and have another quart in the trunk just in case...
    Jun 28 2012
    North NJ
    OP, have you crawled under your car to look for drips? I know that some here had service techs not fully tighten the drain plug over concerns about stripping the threads. If the car wasn't losing oil before the service and now suddenly is that is the first thing I would be checking
    2012 S4 Prestige - Ibis and Titanium - 6MT - MMI - B&O - Rear Parking - Advanced Key
    - Clear Bra - Vag Mods - 8500 Hardwire - Intercooler Screen - Roc-Euro Short Shifter - Eurocode Rear Sway Bar - CR-15 - Matte black rear valence - Show N Go Front Plate
    1991 Ducati 851 - 888cc High Compression Pistons - Big Valve Corsa Heads - High Flow Fuel Injectors - Open Airbox - Braided Steel Lines - Corbin Seat - Fast by Ferracci Chip and Mufflers - Carbon Fiber bits
    Hex-Can-USB in Northern NJ
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by willa1975 View Post
    It's perfectly fine to top off the oil. In fact, it's a good way to replenish the additive packs and thin out any dilution/contamination that may be present.
    Some consumption is perfectly healthy. As long as the rate of consumption remains constant, I wouldn't lose any sleep over it.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    May 08 2010
    I checked underneath and didn"t find anything at first glance.Had the dealer check for any and they said their was none when I had the oil changed.I"ll check the plug though,good idea....
    Quote Originally Posted by Schadenfreude View Post
    Senior Member Three Rings Norm_S4's Avatar
    Jul 11 2011
    Repentigny/Quebec/Canada
    Quote Originally Posted by dparm View Post
    OP as Dparm puts it its actually relatively healthy to have some consumption of oil.
    Actually our engines are made to run very hot and you would expect some to happen and its really not that harmful. I for one had a slight bit of consumption (Audi measured I think .075L for 1000Km thus about .375L per 5000Km) which according to independant and Audi mechs as being normal and that was measured at 80000km at my end of warranty.
    I also heard (but not verified) that Audi dealers might have an agreement with Oil makers over here to use like Castrol or something and that might prove to be slightly "thinner" even on a 5W rated. I'm actually right now testing imported 5W VW accepted oil from Germany just for shits and giggles as the above stated oil consumption on an engine with already 80000km is really not an issue for me.
    As for running a 5w versus a 0W in hot weather is also a good idea. If it ever gets cold (as NY can get in winter) then you switch back to 0W in that period.
    The idea is to be easy on the motor on cold start ups and all the mechanical parts. Summer is a grind so 5W is better as it resists a whole lot better and even moreso if you are hard a bit with the car.
    Just for resting your mind on this, the dealer has a way to weigh the oil but it takes a few hours each time you drop it to the dealer (how I got it measured) and its a sure way to rest all questions I think but you loose the car for half a day each time.
    New RS3 2018 Nardo Grey black optics no mods in sight. Sold:2011 S4 6MT/Sport Diff, Sprint Blue, Eurocode full ÜSS system + AluKruez, Roc-Euro Intake, SS Lines + EBC USR rotors/Red Stuff pads on 4 corners
    Apr 24 2009
    Frisco, TX
    Norm,
    Don't take this personally, but you are wrong about several key things here. I will attempt to clarify so we can all learn something here.
    0wX versus 5wX has nothing to do with it. At normal operating temperature, a 0w30 and 5w30 are the same viscosity. If you think that "oh I should only use a 0wX oil if/when it gets cold", then you are stuck in the old way of thinking about oil from 30+ years ago. Nowadays there is zero reason NOT to use a 0wX oil YEAR-ROUND...these are not air-cooled cars and thicker is not always better. The whole notion about wide viscosity spreads equating to oil shearing in service are largely gone with modern API & ACEA requirements (and the current generation of basestocks).
    As for the Castrol/Audi relationship, it's purely about money. Every big car manufacturer allies themselves with some oil company -- Castrol probably cut the biggest check to Audi. Castrol's oils are no better or worse than Mobil's, nor should you believe that only Castrol is acceptable for this car. Castrol doesn't even supply the factory fill -- their competitor Fuchs does. Hell, even the special Castrol SLX Professional, which is only available at dealers, is the same formula used for BMWs and Mercedes.
    Mar 26 2010
    US
    BMW M3 Competition X-drive
    Veteran Member Four Rings PitchS4's Avatar
    May 14 2007
    2021 SQ5 | 2019 Jeep GC Limited
    Northern VA
    There is a TSB for replacing the PVC. I think it is "Oil consumption is too high (1668201/14)" but don't quote me.
    I guess I can consider myself lucky. My car is CPO and doesn't lose a drop. Unfortunately I can't attest to how it was broken to to help others.
    Current:
    2021 SQ5
    Previous:
    2017 S3
    B8.5 SQ5
    B8 S4
    B6 S4
    B5 S4
    Mar 26 2010
    US
    Here is an interesting TSB:
    Vehicle: 2011 Audi S4
    NHTSA ID Number: 10051502
    Nature of Defect: ELECTRICAL SYSTEM: SOFTWARE
    Bulletin Number: TSB-01-12-58
    Bulletin Date: Nov 2012
    SUMMARY: AUDI: WHILE DRIVING, MAINLY SHORT DISTANCE (STOP AND GO), HIGH CRANKCASE PRESSURE CAN LEAD TO DTCS P113700 AND P113900 CODES. CRANKCASE PRESSURE CAN BE LOWERED WITH NEW ECM (ENGINE CONTROL MODULE) SOFTWARE LEVEL AFTER CHANGING CRANKCASE PRESSURE VALVE TO IMPROVE AND ELIMINATE MENTIONED DTC CODES. MODELS 2010-2012 S4, S5, 2009-2011 A6 (C6), 2011-2012 Q7, 2012 A6, A7. *PE
    Vehicle Make Model Model Year(s)
    AUDI A6 2009-2012
    AUDI A7 2012
    AUDI C6 2009-2012
    AUDI Q7 2011-2012
    AUDI S4 2010-2012
    AUDI S5 2010-2012
