I was planning to replace the manual transmission fluid and the rear differential fluid for my B7 A4 2.0T. From reading various forum posts, I gathered the following info:
G052911A2 - Transmission Oil - about 3.5 liters http://www.jimellisaudiparts.com/pro...-052911A2.html
G052145S2 - Rear Differential Oil - about 1.5 liters http://www.jimellisaudiparts.com/pro...-052145S2.html
Are these accurate? When I asked the guy at GAP, he said that the transmission fluid was instead G055532A2. I have an email into him to ask if the spec changed and if that's still GL-4, since my understanding is that the MT requires GL-4, whereas the rear diff uses GL-5.
When I look up G055532A2, it looks like it's for newer A4s and A5s than mine. http://www.jimellisaudiparts.com/pro...-055532A2.html
Is there also a separate front diff reservoir from the transmission? There are some threads on some forums that say yes, whereas other say that the front diff and center diff are included in the manual transmission.
Thanks for your help.
