Results 1 to 3 of 3
    Active Member One Ring Himzy's Avatar
    Apr 17 2012
    United Kingdom
    Intake Manifold Flap Position Sensor (Bank 1)
    2008 Audi A4 B8 2.0 TDI
    1 Fault Found:
    7859 - Intake Manifold Flap Position Sensor (Bank 1)
    P2015 00 [039] - Implausible Signal
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 155209 km
    Date: 2012.12.20
    Time: 14:53:50
    I have herd about this problem on this forum and then I had the same problem.
    After calling Audi and realizing that this would cost money that I could put to better use, I decided to tackle the problem myself.
    The main problem is that the arm controlling the flap starts to jam hence the fault reading.
    1. I took of the motor (which is located differently depending on your engine, mine was on the right hand side of the
    intake manifold, side furthest from front of car).
    2. There is 3 torx screws and a small easy to loose spring holding it on.
    3. Once off open up the motor it self carefully, once again torx screws and spray a small amount of part cleaner.
    4. Then put the motor back together and spray part cleaner on the entire motor including the arm on the motor.
    5. Spray part cleaner the arm on the intake manifold as this will remove all the dirt causing the motor to jam.
    6. Then spray the arms on the motor and intake manifold with WD40.
    7. Finally Put the motor and back on to the intake manifold, starting with the small spring.
    I did this on my car, only took 20 minutes and no more fault code
    Saved me a heap of cash and hopefully does the same
    Sorry no photos was extremely busy at the garage that day did this in between fixing cars
    Veteran Member Four Rings auditd0rk's Avatar
    Feb 02 2012
    Colorado Springs
    Thanks for sharing!
    Sorry for the dumb question, but would these steps apply to the TFSI engine, too?
    2012 A4 Quattro, Monsoon Grey | CTS K04, HFC | APR K04 v3 Tune | AWE Exhaust | Eurocode FMIC, Alu Kreuz, Sway Bars | Bilstein PSS10 | SPC UCAs | Apikol Rear Diff Mount | 034 Transmission Mount Insert, End-links | StopTech ST-60 BBK | S4 rear brakes | CR-15 brace
    Apr 17 2012
    United Kingdom
    You can do the same however it is in a different location and in certain cases the flap comes off with the motor.
    In which case you can spray part cleaner on the flap however after spraying the WD40 you must make sure to wipe the flap down as any excess can cause problems
    Hope this helps
