Results 1 to 6 of 6
    Nov 21 2012
    Philadelphia, PA
    Tool to remove a wheel's center cap?
    Putting a coat hanger through the hole and pulling didn't work for me. They're pretty stuck on there and bent the hanger back each time. I tried prying from the lug nuts, but they're not actually attached to the nuts themselves, and I thought I might snap one of the edges off.
    I'm trying to clean the brake dust off of them.
    Current: 2016 A3 w/ Black Optics
    Sold: 2013 S4 with AWE intake and resonated exhaust.
    Jan 12 2013
    Jupiter, Florida
    The little tool is in your trunk.
    Qwik Rick
    2017 Audi Q7 w/APR DP tune, RocEuro,
    Sold
    2010 S4 w/Revo Stage 1+ tune & USP intake, cold front, lw crank pulley, JHM rotors
    12.44 @ 113.56 @ PBIR 1/4 (stage 1)
    12.203 @ 114.28 PBIR 1/4 (stage 1+) 13 Jan 2016
    Established Member Two Rings soulman978's Avatar
    Mar 11 2004
    CT and RI
    Yup. Remove the spare and the plastic cover to reveal the jack and the tools and it will be there. It's a silver circle with a small hook on the end. Takes 2 seconds to pop them off.
    2012 S4 Prestige|DSG|Brilliant Black|Nappa|Sport Diff|Carbon Atlas|Carbon Supercharged Badges|AWE Exhaust Resonated
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    I'm assuming if you failed to remove them through the appropriate hole with a coat hanger than the tool in the trunk may not work either. I've also tried using a nail, bending the last few centimeters with a pair of pliers to a right angle, and that worked fine. Coat hanger may be a little too easily bent.
    Nov 17 2012
    Guernsey
    Borrowed this pic.
    and this is the other type for lug covers
    Current
    Audi R8 V10+ DSG in Ibis White, blk lthr interior - Tubi Style exhaust
    Audi SQ5 in Glacier White
    My YouTube Channel
    Nov 21 2012
    Philadelphia, PA
    Thanks. The tool in the trunk worked perfectly!
