Originally Posted by
Gromit
David or Greg at Eurocode have thoughts?
Personally I've always been a little skeptical about this concept of intake air getting heated significantly. Think about it: if the engine is running at any decent rpm, you have a decent velocity of the intake air. The tube is short. That means the residence time of air in the intake duct is REALLY short.
Even if the intake tube is fairly hot, you're only going to get heat transfer into air that flows across the outside of the cross-sectional area, particularly under laminar flow conditions that aftermarket tubes claim (the situation is slightly different with turbulent flow). The outer edge air that gets heated slightly is a small fraction of the mass flow through a cross-sectional area, so you'll get minimal average heat increase of the total air once it gets fully mixed in the cylinder.
So to me the key criterion is where the air comes from. Sucking in cold air versus warm air will matter much more than the minimal heat increase during flow along the tube. Maybe I'm missing something but to me, basic engineering principles say focus far more on intake location than temp of intake duct.
That was one of arguments as well in the MB forum. However it still makes me wonder if this approach does not help to some degree with the heat soaked problem where the engine bay temps are high ...
If you trust the enthusiast tests on the "internets" one of the guys on the MB forum says that based on his tests the temps shown ware 10+F lower with the wrap than without it ...
Here is the quote:
"I wrapped my intake tubes about a month ago. I finally got a change to log the temps in the tubes. Results are very positive,
temp difference between the inside surface of the heat shielded and non heat shielded tubes was 13F. The test conditions were as follows - drove the car for about 15min in 93F ambient temp to get engine bay and engine up to operating temp, inserted temp probe from both ends of the tube, results very the same.
IMO worth $20. Even if this lower IAT's by a couple of F it is worth it."
