Results 1 to 30 of 30
    Established Member Two Rings nonchalant_Gee's Avatar
    Jan 12 2013
    B6 s4 black/black (current) 04 s4 Moro blue RIP. rear ended by a ricer lancer! :-(
    Bronx, NY
    hazard lights stay on when starting car
    hey guys. i searched the forums for my issues with my 04 s4 6mt
    i recently just got the car and heres the thing
    supposedly the battery was replaced before i got the car cause the old one wasnt holding charge
    a week later key stopped working/ unlocking and locking but would open the driver door manually
    and when i started the car it would start fine but the hazards would blink for about 3 -5 minutes even if i hit the hazard button it still stays on
    so i got the key working with the help of a buddy at his shop and his diagnostic tools. they speacialize in land rovers and range rovers
    he did say there was a code for the key but he cleared it and synced the key but he said he couldnt find anything for the hazards staying on.
    he told me to go home and disconnect the battery for a night and try it in the AM. well i did that and it didnt work. :-/ like i said ive searched the forums and all that comes up is threads about switch the hazard switch.
    another problem :( the climate controls dont work. the only way it turns on is by hitting the button for the windshield and then lower the temp or raising it
    do you think that will work? any suggestions?
    I don't know anyone with a vagcom cable might have to get one
    also a friends told me to disconnect the battery and connect the possitive terminal and the negative together to completly drain the power out the car . would this work or is it crazy talk ?
    Jan 12 2013
    Bronx, NY
    would of thought someone def would of helped with this in anyway damn, i really dont want to go to the stealership!
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    You need to get a complete fault code scan done using VCDS (Ross-Tech phased out the VagCom name years ago), without that you're just guessing what the problem(s) is/are.
    Jan 12 2013
    Bronx, NY
    I'll be posting up a log of vcds soon hopefully.
    Established Member Two Rings KWOOD's Avatar
    May 05 2012
    St. Louis
    There is probably some silly little connection that has come loose, but like above a scan would help out.
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Remove the hazard button and see if the problem goes away. If it does, there's probably a short in the switch.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Jan 12 2013
    Bronx, NY
    Quote Originally Posted by dparm View Post
    Gonna do a vcds scan tomorrow post up the log and try pulling the switch see if anything happens, wouldn't that stop my signal lights from working though ?
    Jan 12 2013
    Bronx, NY
    Removed the hazard button and nothing. Problems are still there. Still on the go to get a vcds cable. Might just have to order one cause everyone that I know that has one or has offered to give me a hand hasn't been able to come by and scan the car with vcds. I'm gonna make a quick video so you guys can see what exactly I'm talking about ill post up the link from YouTube.
    Jan 12 2013
    Bronx, NY
    Ok guys I made a video, http://youtu.be/DjeSagBM38g check it out
    Jan 12 2013
    Bronx, NY
    Thursday,15,August,2013,23:50:03:12686
    VCDS Version: Release 11.11.6 (x64)
    Data version: 20121223
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUPL68E04A117499 Mileage: 225480km/140106miles
    Address 01: Engine Labels: 079-910-560-BBK.lbl
    Part No SW: 8E0 910 560 A HW: 8E0 907 560
    Component: 4.2L V8/5V G 0020
    Coding: 0007711
    Shop #: WSC 08091 444 64599
    VCID: 234EE0C8E1E476001D9
    3 Faults Found:
    17985 - Right Engine Mount Solenoid Valve (N145)
    P1577 - 004 - Open Circuit - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - - Intermittent
    16685 - Cylinder 1
    P0301 - 001 - Misfire Detected - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 Q
    Component: ABS/ESP allrad 3033
    Coding: 04595
    Shop #: WSC 08159
    VCID: 3668299C1276F3A8CA7
    No fault code found.
    Address 08: Auto HVAC Labels: None
    Part No: 000 000 000 0
    Component: A4 Klimaautomat 1319
    Coding: 00000
    Shop #: WSC 00000
    VCID: E0C42FC46072AD18C0B
    2 Faults Found:
    00474 - Control Module for Immobilizer
    49-00 - No Communications
    27-10 - Implausible Signal - Intermittent
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 F
    Component: int. Lastmodul USA 0517
    Coding: 01013
    Shop #: WSC 00000
    VCID: 356A2E900F70F8B0C3D
    3 Faults Found:
    01504 - Bulb for License-Plate Light (X)
    57-00 - Electric Circuit Failure
    02104 - Light Detection Sensor (G399)
    29-10 - Short to Ground - Intermittent
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 K
    Component: Airbag 8.4EP 1001
    Coding: 0010607
    Shop #: WSC 08353 444 58704
    VCID: 3F864CB86D4C32E0191
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0611
    Coding: 02041
    Shop #: WSC 00000
    VCID: 3E7831BC3A463BE8127
    2 Faults Found:
    01304 - Radio
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 980 M
    Component: KOMBI+WEGFAHRS. RB4 D37
    Coding: 00250
    Shop #: WSC 00000
    Subsystem 1 - Part No: v
    Component: uZ6Z0C0281076
    vűuZ6Z0C0281076
    1 Fault Found:
    01304 - Radio
    Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
    Part No: 8E0 959 760
    Component: Sitzmemory R2 F 0305
    Coding: 00002
    Shop #: WSC 63351
    VCID: F1E25A80BB9814905F5
    1 Fault Found:
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BB
    Component: Komfortgerát T7B 1411
    Coding: 11900
    Shop #: WSC 05827
    VCID: 72E0D58C3E9EAF8826F
    Subsystem 1 - Part No: 8E1959801
    Component: Tőrsteuer.FS BRM 0003
    Subsystem 2 - Part No: 8E1959802E
    Component: Tőrsteuer.BF BRM 0003
    Subsystem 3 - Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0004
    Subsystem 4 - Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0004
    2 Faults Found:
    00955 - Key 1
    35-00 - -
    01561 - Left Rear Door
    59-10 - Can't Unlock - Intermittent
    Address 55: Xenon Range Labels: 4Z7-907-357.lbl
    Part No: 4Z7 907 357
    Component: dynamische LWR D09
    Coding: 00060
    Shop #: WSC 63351
    VCID: 040C8354142A9138043
    End ---------------------------------------------------------------------
    Jan 12 2013
    Bronx, NY
    So met up with a forum member last night he pulled a scan on my car and here's the log any suggestions guys
    Jan 12 2013
    Bronx, NY
    Disregard the engine fault codes. One of my 034 motors mount plugs was a little loose From dangling and got a check engine light after I degreased the engine bay and hosed it down caused a misfire cause my dumb ass turned the car off and didn't let the water evaporate while the car was still running turned the car off and back on again and check engine light went away pheww
    Apr 24 2009
    Frisco, TX
    A lot of strange electrical faults. I'd say you have electrical gremlins, possibly stemming from bad grounding or corroded wiring.
    Jan 12 2013
    Bronx, NY
    Wish I knew where to start looking. I'm scared of the cost if I take it to a shop I know I'm gonna get some bS like " oh it's too complicated, or take it to Audi." I'm just gonna have to bite the bullet if I can't resolve this on my own. I know someone of this forum must have some kind of knowledge on this or have had similar issues
    Established Member Two Rings andy.w's Avatar
    Aug 23 2012
    metric ass ton of kids toys and some tools
    cape carteret NC
    I bought my car in Aug 1 yr ago and when winter came around the battery would lose charge if I let it sit for more than 3 days. the battery was new as of july 2012. I took it to the stealership to be replaced under the battery warranty. they replaced the battery and to my surprise the drain was still present (another story) the battery was replaced in july at the same dealer so I asked them why it was replaced before. the symptoms were (hazards flashing and fans running. replaced battery, issued resolved) the paperwork said they did a power restore after battery was replaced. not really sure what that does for the car but might be worth looking into.
    Jan 12 2013
    Bronx, NY
    What kind of batteries r you guys running? My car came with some duralast crap not sure if its up to Audi specs but I haven't had any problems with it or starting my car.
    Veteran Member Four Rings Mistro's Avatar
    Jun 19 2011
    Did you do the scan with the car on or off? If it was off, try with it on. It'll filter out a bunch of the faults that come up when you scan with the car off.
    What condition is your battery in? This sounds very similar to what was happening to me when my battery was almost toast.
    Jan 12 2013
    Bronx, NY
    Yea the engine faults weren't there when I it was scanned with the car on that's abou it
    Jun 19 2011
    So the code about the immobilizer was still there? I wonder the issue has to do with you unlocking with the key itself. Not sure how it is with the B6's but with the newer ones you have to have the key turned in the ignition within a certain time of opening the doors with the key (or the alarm goes off).
    When I was having my battery issues, this happened to me when I didn't put my key in after unlocking it manually. It was like the alarm was going off but there was no beeping.
    My money is on your issue being caused some short, or a bad battery.
    Jan 12 2013
    Bronx, NY
    Yep immobilizer codes still there. If my immobilizer was bad then I figured the car wouldn't start or I would have a the fault saying "car start blocked by immobilizer" something along those lines. Or a fault saying something about the cluster since that's where the immobilizer is. And I've replaced the battery in the key too that didn't do anything
    Jan 12 2013
    Bronx, NY
    I can try to source a different battery. What battery are you using ? Oem one from dealer ?
    Aug 23 2012
    cape carteret NC
    Quote Originally Posted by nonchalant_Gee View Post
    OEM audi/vw
    Jun 19 2011
    Worth a shot. Here's how to reprogram your fob afterwards:
    http://www.audizine.com/forum/showth...i-flip-key-fob
    Jan 12 2013
    Bronx, NY
    So guys I have this battery now.
    Bosch 49-850B
    Group size 49.
    Also friend of mine told he I have to program the car for a new battery !? What is he talking about I've never heard of this ?
    Also after putting this battery in hazards still flashing. :-)
    Jan 12 2013
    Bronx, NY
    Trying to Keeping the thread alive..
    Has anyone had this fault code ?
    "00474 control module for immobilizer 00-49 no communication "
    If so what where your issues and what did you do to fix it?
    I'm going to check all the grounds to the car if I can find them lol come Monday
    Established Member Two Rings Omerta's Avatar
    Jun 12 2013
    GSXR750, 2005.5 Audi S4
    Check the relay, could be the contacts or solenoid... but if they turn off after 3-5 its definitely an alarm thing. My old A4 Jetta would do that when my door switch was faulty and I unlocked it manually. Except it would go full alarm (not locking out the immobilizer though).
    Is your keyless entry up and running yet?
    2005.5 B7 Audi S4
    6MT
    Jan 12 2013
    Bronx, NY
    No I've tried to reprogram my only key and haven't had luck after trying for about an hour I got frustrated and left it alone.
    Where exactly is the relay ?
    Also my alarm is really really low like you can barely hear it at all from a Distance but up close its clear but not loud enough how it's supposed to be
    Jun 12 2013
    I'm not sure of its exact location. But from the sounds of it, its not the relay. Relay issues would be alot more straightforward and just leave the hazards on whenever the car is on.
    I'd look into purchasing a new fob, having yours tested or looking into the receiver side. Electrical gremlins are never easy to troubleshoot, especially via internet. You'll have to work system by system that interacts with the alarm on startup.
    2005.5 B7 Audi S4
    6MT
    Jan 12 2013
    Bronx, NY
    If I'm not mistaken every module in the car interacts with each other.
    If I just unplug a unit/module ill still get a code or more codes? Why get a new key if I can't even resync my current one...
    I can turn the car on, I can unlock it manually, I inserted a new battery in the FOB
    I've had the key resynced with a technician it took him some time but it stopped working after a month or so.
    Got a new car battery that didn't do anything, thinking of getting a optima yellow top
    Only other place I haven't look is in the ECM box
    I've checked all my fuses and they checked out ok.
    Jan 12 2013
    Bronx, NY
    Seems like there’s a few people in 2021 with this same issue since I originally made a post about my flashing hazards on a previously owned b6 s4
    . I just replied to a user thru DM with this issue.
    Upon a quick search there are users with this same issues popping up
    Here and there and the info on how to solve this issues hasn’t been addressed.
    We live in a technological advanced world why the F can’t we as a community solve
    simple and dumb electrical headaches
    If you or anyone has had this “hazard” light issue please describe your issues and solution
    Hopefully there’s a general or standard way or figuring this culprit out.
    So far places to check are
    Grounding points.
    Fuses
    Relays
    Key fobs
    Central locking unit.
    Ecu
    A vcdm scan / vag tool to diagnose
    Battery and cables
    Aftermarket radios
