Results 1 to 20 of 20
    Active Member One Ring Jutt's Avatar
    Feb 07 2010
    Fuel Pump Control Module
    Has anyone had any issues with their fuel pump or the fuel pump control module?
    A week ago, I went to start my car in the morning and it turned and turned and wouldn't start up. Tried a few times, and it finally started up. Brought it to my local dealer, and they said there weren't any codes but they were going to order a fuel pump control module and replace it just as a preventative measure.
    Friday night I was getting on the highway, was going about 70 at 3500 rpm, and the power cut out completely. Rpm dropped to 700, and the car felt like it was going to stall. Everyone in the car asked if I did that on purpose, because it literally threw everyone forward. Power came back, but then the same thing happened again. Total power loss.
    Tonight I was leaving again, and the car kept turning and turning but the engine wouldn't fire up. I tried starting it 8 times before it finally fired up and started running. Luckily, my house was a mile away and I got home with no problem.
    Has anyone else had a similar issue? I'm supposed to have the module replaced on Wednesday, but I'm nervous to even drive around in the meantime thinking I might get stuck somewhere.
    Current: 2014 Audi S4 P+, Monsoon Gray, Black Alcantara, MMI Nav+, B&O, 19" Peelers, ADS, Carbon Atlas Inlays, Side Assist
    Past: 2014 Audi Q5 P+ 2.0T, 2011 Audi S4 P+, 2010 Audi A4 P+
    Senior Member Two Rings ccssid's Avatar
    Jul 03 2011
    michigan
    Had the exact same issue. And, it was the fuel pump control module. Do not drive until it is repaired. Happened last summer...the exact same symptoms. Have not had any issues since the dealer replaced module.
    btw: I have 2011 S4 prestige 6mt
    Senior Member Two Rings hanzy's Avatar
    Feb 19 2013
    NE
    Have been seeing some issues with these modules on the vw/audi's lately.
    Cause all sorts of weird drivability problems.
    Typically when your dealer elects to do something like that so quickly, they have been seeing a lot of failures.
    Aug 26 2010
    Tampa FL
    I am trying to find where this fuel pump control module is located. Everything points to the gas tank, but I am not seeing it there.
    Apr 05 2016
    Portland, OR
    Its in the fuel tank.
    – Unplug electrical connector -1- on flange.
    – If fitted, unplug electrical connector -2- for metering pump for auxiliary heater on flange.
    – Press release tab and disconnect fuel line -2- at flange.
    – Press release tab and disconnect fuel line -1- (if fitted) leading to metering pump for auxiliary heater at flange.
    The fuel tank must not be more than 1/4 full when removing the flange, otherwise a large amount of fuel will escape.
    – Unscrew union nut using union nut tool -T40068 A--arrow-. (A screw driver can also be used)
    – Cover opening of fuel tank with clean cardboard -1- to prevent dirt particles from falling into the tank.
    – Remove bolts -arrows-.
    – Guide out fuel pump control unit -J538--item 1- towards interior between fuel tank and underbody.
    – Unplug electrical connector and remove fuel pump control unit.
    When reinstalling the pump make sure the union nut is at the 7-o-clock position.
    Geoff
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Quote Originally Posted by Jutt View Post
    Any codes?
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    May 09 2012
    2013 s4, 2008 cbr1000rr
    United States
    Quote Originally Posted by Hofahome View Post
    Any codes?
    see bold text
    Apr 05 2016
    Portland, OR
    Hofa plz, post is 4 years old.
    Geoff
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    bumping this, I've been having continued fuel issues (G410) sensor issues that simply just pause a signal, and then it magically returns. I'm on my 4th G410 sensor, and I'm suspecting its my fuel pump control module that's failing (likely due to overdriving it at 75% PWM signal at wide-open, not what the controller was originally designed to do).
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Veteran Member Four Rings PeteRock's Avatar
    Mar 08 2017
    Chicago
    Quote Originally Posted by Loe View Post
    Time for one of these ;)
    Pete
    Aug 09 2015
    Sarasota, FL
    would love to, but I've been sticking to minimal mods since this car isn't a long-term car for me. $30 for a used on on ebay, can't go wrong lol
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Just ordered fuel control module from ECS, hopefully this my issue. I’ve encounter exactly what Loe is describing, I’ll post back.
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Aug 09 2015
    Sarasota, FL
    day 1, thus far so good. My shop said that they were battling something similar on an A6 3.0t (which BTW uses the same same Fuel Pump Control module, which in theory should be able to drive an S6/RS7 fuel pump....just saying...), all codes pointed towards a LPFP on ODIS (VAG group diagnostic tool), they replaced the LPFP, still the same issue, HPFP, same issue, once the controller was replaced, no issues.
    Hopefully this will work, my codes pop up after a week so I'll report back then. G410 #4 now. That 75% PWM signal life...
    Dec 29 2011
    The Bay
    Make sure you order the correct one, I ordered the incorrect part from ECS. They will exchange for correct part and they were prompt too, awesome customer service.
    OEM part # 4G0906093G (superseded now by letter J) currently on my car. I received 8K0906093E, it has a different pin connector and unit is much larger. You have to pull fuel filter out to gain access to module. Moral of the story, check the part before you order
    Aug 09 2015
    Sarasota, FL
    yeah, the bottom one is the pre-FL model that uses a brushed-style pump.
    So far so good on this new-to-me control module.
    Mar 08 2017
    Chicago
    Not sure that this is directly related but on the topic of fuel pressure I was curious if anyone has had or heard of a fuel pressure sensor going bad?
    Even before swapping my LPFP and adding the Torqbyte PM4 controller I was experiencing some rough starts, failed starts and occasionally had some weird fluctuations of the idling where it would idle really high and dip up and down....now I also saw a code for evap as well and these are supposedly all symptoms of the sensor failure
    Thoughts?
    Pete
    Dec 29 2011
    The Bay
    Replace your module, I doubt its the sensor.
    Mar 08 2017
    Chicago
    Quote Originally Posted by RWD2quattro View Post
    The Torqbyte PM4 actually replaces the OEM fuel pump control module so I doubt that this is the issue since it was happening prior to installing the PM4
    Pete
    Dec 29 2011
    The Bay
    OK, I misread your post. Sensor it is.
    Mar 08 2017
    Chicago
    No worries....I’m going to start with the sensor because it seems to be the most simple choice.....good news is that I’m still under warranty and my Audi dealer does a lot of my mods so it’s covered
    The more I read about these issues the more I see that it could be a lot of different things causing them....anything from clogged filters to failure of the sensors (LPFP and HPFP) and even the actual pumps themselves
    In my case I don’t think it’s the LPFP or Torqbyte controller as these are brand new and I don’t think it’s the HPFP since it was recently rebuilt with the Autotech piston and a new cam follower....one of the filters was pretty badly clogged but it was discarded when they installed the Hydramat so I’ll have to have them check the other one
    Pete
