Results 1 to 16 of 16
    Established Member Two Rings tjsingh's Avatar
    Feb 06 2010
    2020 S5 Sportback, 2019 AMG E53, 2019 Toyota Tacoma TRD
    Covington, WA
    Intake Manifold Runner Control Motor Warranty extension?
    I recently got a check engine light for IMRC.
    When I went to Audi and asked them about it they did not mention any warranty extension or recall when I asked if that was the case they told me they would have to do a diagnose it and then fix it.
    Has anyone else got theres replaced through the warranty because I searched and found this bulletin. I just feel like the dealership is trying to play dumb and get here $600.
    I searched and just found DIYs or other related posts nothing addressing the warranty other than VW forums.
    http://www.automd.com/tsb/bulletin_b332106/
    Nov 15 2011
    Montreal | I sell in USD
    Just had this done under warrante, 2006 2.0t with 140kkm here.
    *****I sell in USD*****
    Senior Member Two Rings DJ Carl's Avatar
    Apr 14 2007
    Peg Perego Gaucho
    Long Island
    Got mine done too. Went in for an oil change and asked about recalls/campaigns and had that all fixed. It's not a warranty item, but a recall/campaign. When they type in your VIN it should automatically come up. Although I just noticed you have a 2008 and I don't think that year is part of it.
    2007 A4 Avant 2.0T 6MT S-Line
    Titanium Package
    Quartz Gray
    Carbonio Intake
    Stasis Exhaust
    ER FMIC
    Clutchmasters FX350 and lightweight steel flywheel
    APR GT2871R
    Apr 14 2007
    Peg Perego Gaucho
    Long Island
    Titanium Package
    Quartz Gray
    Carbonio Intake
    Stasis Exhaust
    ER FMIC
    APR GT2871R
    Feb 06 2010
    Covington, WA
    Yeah! I called Audi earlier and they told me my Vin doesnt show it. Too unfair haha They want near $600 to do it and the local shop wants $350.
    I found the part for $90.00, probably gonna end up doing it my self not really in the mood to be robbed
    Veteran Member Three Rings Cherub's Avatar
    Jun 20 2010
    Golf-R
    FL-Global
    Good to know. Thanks
    MK7.5 R Daily
    B9 S4 (Pending Sale)
    2 B8.5 & B7 - Sold
    Tints & More..........
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Quote Originally Posted by tjsingh View Post
    That' very strange. I have a 2008 and they replaced everything under the warranty extension. This includes PCV, IMRC, Thrust Sensor, code updates, etc.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Nov 15 2011
    Weird I noticed that since I had this recall done the car struggles to start in the morning and wont boost peak at 12 psi like it used to on stock programation.
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Bump...
    Quote Originally Posted by Axis View Post
    Did you ever get this resolved Axis?
    Also, lucky me....I am now outside of the warranty period and am finally getting codes related to my intake flap motor I have heard though that you don't need to replace the whole unit...That the real root cause of the problem is "sticky" flaps and that can be resolved by opening everything up and cleaning up the dirt/oil/etc that has accumulated over the years. Is that true? Has anyone had luck doing that?
    Alternatively, you can just replace the flaps inside I heard and not the whole motor?
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Oct 09 2007
    Miele S7
    ^^The warranty is 10/120K. What's your mileage?
    Dec 19 2012
    Europe
    Quote Originally Posted by 80sGuy View Post
    Thanks 80sguy and I know, but I'm at 122k now
    Has anyone who has had issues with their intake manifold runner ever tried to open it up and clean it or replace just the flaps inside?
    That is the cost effective way to fix it versus just replacing the whole unit (unless of course Audi is paying for it).
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Quote Originally Posted by BenMTL View Post
    Talk to AoA sometimes they will consider the warranty work. Also technically your mileage starts at the in service date of the car so your mileage may less than what's displayed on the odometer.
    Dec 19 2012
    Europe
    Quote Originally Posted by Sanjman View Post
    Audi of Canada in my case but yes, already tried that and got refused
    As an update on this....the intake manifold runner is actually only an electrical solenoid or motor so nothing to "clean" inside of it but if I remove it apparently, I will have direct access to the intake manifold flaps and may have luck using using brake cleaner to clean them and prevent them from "sticking"....
    New OEM IMCR is like $250 up here So gonna try this cheap method first, even with no guarantee it will work....
    Nov 16 2006
    Skokie, IL
    Can't you just take the intake manifold off? It's not as hard as many think and you can do some valve cleaning while you're there. [Wrench]
    Dec 19 2012
    Europe
    I could take it off and do a valve cleaning but that would be unrelated to my IMRC error code.
    I probably will do it, but taking off the IMRC is considerably less work than the whole intake manifold. As I understand, the flaps should be directly under the IMRC attached to the outer portion of the intake manifold, correct?
    Also, brake cleaner may not be the best cleaning solution in the area because it is not combustible in case it gets into the combustion chambers...Maybe using carb spray would be safer? Not as good cleaning agent but safer....
    Dec 19 2012
    Europe
    Has nobody else on here ever personally replaced their own IMRC?!
