Results 1 to 8 of 8
    Feb 22 2009
    Ottawa
    Side view mirror glass replacement
    Anyone know where I can source a side view mirror glass replacement (driver side), and replacement instructions? I got some scratches on mine and I see that B7 and other similar glass is a pretty cheap part. I just can't find it for the B8, nor can I find any threads on replacing the glass.
    I guess I'd be looking for something like this:
    http://www.ebay.com/itm/PASSENGER-Ri...289a79&vxp=mtr
    By the way, I tried fixing the scratches using this method:
    http://www.ehow.com/how_5859271_repa...scratches.html
    1 Spray glass cleaner on the mirror and wipe it off with a soft cloth, especially cleaning around the area of the small scratch.
    2 Apply toothpaste to a cotton swab and rub the cotton swab in small circles the total length of the scratch so that it is completely covered with the toothpaste. Use regular toothpaste; don't use gel.
    3 Allow the toothpaste four hours to dry and crust.
    4 Wipe the toothpaste off the scratch with a soft cloth. The scratch should be gone.
    5 Repeat this process for other scratches.
    Yeah, the reason you can't see the scratches anymore after you use the toothpaste method is because your mirror is covered in crusty god damn toothpaste.
    Didn't work for me anyway...
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    if you want a cheap fix ebay has the glass available. otherwise just go to a windshield glass place and they can prob get you new ones
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    do you have memory mirrors? part #6 in the diagram
    http://genuineaudiparts.com/parts/20...agramCallOut=6
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Feb 22 2009
    Ottawa
    Quote Originally Posted by jlaudio View Post
    No, thank God...
    mirror glass w/memory Left: $253.07
    mirror glass w/o memory Left: $85.71
    I take it left is driver's side.
    The eBay ones are much cheaper, I guess I need to look around. Any idea how to replace? Do you just pop it?
    Feb 22 2009
    Ottawa
    Also, are these dimming or not?
    Veteran Member Four Rings audibmi's Avatar
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    Quote Originally Posted by belzebutt View Post
    I have a set from my 2013 S4, auto dimming and heated. I swapped them for the euro blind spot mirrors. Pm me if you need the driver side.
    Active Member One Ring sfali16's Avatar
    May 11 2013
    United States
    Did you ever figure out instructions on how to fit the new mirror in?
    No, thank God...
    No, thank God...
    Sent from my HTC U11 life using Audizine mobile app
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    its an easy swap, even a caveman can do it.
    trim remover will make the removal a breeze.
    is say it takes 2 mins
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
