I have a 07 a4 2.0t. I just did the ecs tuning timing belt kit with an underdrive pulley. I also replaced the cam follower, pcv, thermostat, plugs, and cleaned out the intercooler piping. Now im getting a p0234 overboost code. Goes into limp mode when creating boost otherwise slow throttle not creating boost it is fine. I put in a new map sensor and that didnt fix it. Checked voltage to it and it gets 4.9v. Right where i should be. Put the old pcv back in still same thing. Check for boost leaks between all the intercooler piping and none there. It was running perfectly fine before and now its not. I am at a lost. Please help. Any input??
