Results 1 to 8 of 8
    May 20 2010
    Another A8 Suspension Problem
    I apologize in advance--I'm sure that somewhere (through many searches) this info may be gleaned. But I did some rough searches, and did not find my answer.
    My buddy has a 2004 A8 w/ 82k. Recently, his rear suspension jacked itself up WAAAAY high and his front driver side is basically slammed. I read his codes (below) and tried to do a level adjust through VCDS to try to get it to level out. He said the green lowering light was continually blinking while doing this, and there is a solid light with ! for level control issues (same as an Allroad). At this point, I'm not exactly sure what to tell him aside from "it's either your module or your sensors".
    Please help. Thank you! (and yes, there are a lot of things amiss but he can't drive the car as it is).
    Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
    Part No SW: 4E0 910 730 G HW: 4E0 035 729
    Component: Interfacebox H43 1070
    Revision: 00000000 Serial number: 346CQ057520568
    Coding: 0000103
    Shop #: WSC 12300 444 00002
    VCID: 244DF9A6E7995F38654
    3 Faults Found:
    00658 - Control Head
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 113
    Mileage: 132400 km
    Time Indication: 0
    Date: 2013.04.09
    Time: 19:43:53
    01310 - Level Control System Control Module (J197)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 126
    Mileage: 132630 km
    Time Indication: 0
    Date: 2013.05.10
    Time: 21:39:13
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 7
    Fault Frequency: 81
    Reset counter: 126
    Mileage: 120005 km
    Time Indication: 0
    Date: 2012.03.07
    Time: 09:45:29
    Freeze Frame:
    Bin. Bits: 010
    Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
    Part No SW: 4E0 910 593 E HW: 4E0 035 593 A
    Component: SDAR
    Serial number: AUZ4Z7D3020721
    Shop #: WSC 00000 000 00000
    VCID: 2953E89280BB8250562
    1 Fault Found:
    02635 - Tuner Not Enabled/Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 95
    Mileage: 120005 km
    Time Indication: 0
    Freeze Frame:
    Raw, Form. N/A: 000 000 075
    Raw, Form. N/A: 000 000 000
    Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
    Part No SW: 4E0 910 950 G HW: 4E0 920 950 G
    Component: KOMBIINSTR. VDO H53 0210
    Revision: D05 Serial number: AUDID3E1003571
    Coding: 0016233
    Shop #: WSC 40901 444 58704
    VCID: 2855ED969BB1BB5849C
    1 Fault Found:
    00562 - Sensor for Oil Level/Temperature (G266)
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 4
    Reset counter: 110
    Mileage: 132398 km
    Time Indication: 0
    Date: 2013.03.14
    Time: 13:08:07
    Address 19: CAN Gateway Labels: 4E0-910-468.lbl
    Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
    Component: Gateway H10 0080
    Revision: 10 Serial number: 190030521600CC
    Coding: FCFE7BDD1B7904
    Shop #: WSC 02313 785 00200
    VCID: 2757EEAA96AFB420406
    2 Faults Found:
    01303 - Telephone Transceiver (R36)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 121
    Reset counter: 111
    Mileage: 120434 km
    Time Indication: 0
    Date: 2012.05.03
    Time: 10:23:01
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 126
    Mileage: 132630 km
    Time Indication: 0
    Date: 2013.05.10
    Time: 21:38:20
    Address 25: Immobilizer Labels: 4E0-910-131.lbl
    Part No SW: 4E0 910 131 HW: 4E0 909 131 D
    Component: FBS AUDID3 H04 0140
    Revision: 01404004 Serial number: AUX3Z0E1759951
    Coding: 0410624
    Shop #: WSC 02311 785 00200
    VCID: D8B51D566B514BD8B9C
    Part No: XXXXXXXXXXX
    Component: ELV XXXX
    XXXXXXXXXXX ELV XXXX
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 96
    Mileage: 132096 km
    Time Indication: 0
    Date: 2013.01.29
    Time: 21:23:02
    Address 34: Level Control Labels: 4E0-910-553.lbl
    Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
    Component: LUFTFDR.-CDC H06 4480
    Coding: 0016510
    8 Faults Found:
    01400 - Suspension Level Control
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 2
    Fault Frequency: 21
    Reset counter: 125
    Mileage: 132400 km
    Time Indication: 0
    Date: 2013.03.19
    Time: 12:46:18
    01780 - Sensor for Vehicle Leveling
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 3
    Fault Frequency: 14
    Reset counter: 126
    Mileage: 132432 km
    Time Indication: 0
    Date: 2013.04.10
    Time: 06:54:41
    00775 - Level Control System Sensor; Right Rear (G77)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 124
    Mileage: 132438 km
    Time Indication: 0
    Date: 2013.04.10
    Time: 06:57:51
    00774 - Level Control System Sensor; Left Rear (G76)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 119
    Mileage: 132439 km
    Time Indication: 0
    Date: 2013.04.10
    Time: 06:58:09
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 119
    Mileage: 132439 km
    Time Indication: 0
    Date: 2013.04.10
    Time: 06:58:09
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 21
    Reset counter: 125
    Mileage: 132400 km
    Time Indication: 0
    Date: 2013.03.19
    Time: 12:46:18
    01487 - System Function Test
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 126
    Mileage: 132630 km
    Time Indication: 0
    Date: 2013.05.10
    Time: 21:39:19
    01398 - Signal Conductor for Central Locking; Doors Open
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 126
    Mileage: 132630 km
    Time Indication: 0
    Date: 2013.05.10
    Time: 21:39:28
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 C HW: 4E0 919 887 C
    Component: MNS US H44 0960
    Revision: 00000000 Serial number: 378BS057517551
    VCID: 2E591B8EB955E568830
    1 Fault Found:
    02261 - Data Medium
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 7
    Fault Frequency: 9
    Reset counter: 98
    Mileage: 131572 km
    Time Indication: 0
    Date: 2012.12.31
    Time: 09:18:28
    Freeze Frame:
    Hex Value: 0x510F
    Hex Value: 0x7659
    Hex Value: 0xFA10
    Hex Value: 0xF000
    Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
    Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
    Component: Türsteuer.FS BRM002 0060
    Coding: 0028204
    VCID: 2045F5B6F381431801C
    3 Faults Found:
    00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 3
    Fault Frequency: 14
    Reset counter: 97
    Mileage: 130384 km
    Time Indication: 0
    Date: 2012.12.17
    Time: 17:39:50
    00913 - Window Regulator Switch; Front Right Driver (E81)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 8
    Reset counter: 126
    Mileage: 132400 km
    Time Indication: 0
    Date: 2013.03.19
    Time: 15:59:36
    02126 - Central Locking Button; Exterior Door Handle
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 0
    Reset counter: 126
    Mileage: 132608 km
    Time Indication: 0
    Date: 2013.04.21
    Time: 10:10:54
    Address 46: Central Conv. Labels: 4E0-910-289.lbl
    Part No SW: 4E0 910 289 A HW: 4E0 907 289
    Component: Komfortgeraet H04 0040
    Revision: 00400004 Serial number: W040502280270
    Coding: 0065086
    Component: HDSG keine Antwort
    Part No: 4E0 907 719
    Component: Neigungssensor H03 0020
    1 Fault Found:
    02107 - Trunk or Luggage Compartment Opening Motor (V254)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 86
    Mileage: 132630 km
    Time Indication: 0
    Date: 2013.05.10
    Time: 21:45:35
    Address 53: Parking Brake Labels: 4E0-910-801.clb
    Part No SW: 4E0 910 801 A HW: 4E0 907 801
    Component: EPB AV1C1010 H01 1010
    Revision: AV1C1010
    Coding: 0000532
    Shop #: WSC 07117 444 53517
    VCID: 1D3BCC42C4F36EF02AA
    1 Fault Found:
    02596 - Rear Brake Pads Worn
    Freeze Frame:
    Fault Status: 01111000
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 95
    Time Indication: 0
    Freeze Frame:
    Voltage: 10.35 V
    Count: 61
    Address 55: Xenon Range Labels: 4E0-910-357.lbl
    Part No SW: 4E0 910 357 HW: 4E0 907 357
    Component: Pre-AFS H01 0040
    Revision: 00000001 Serial number:
    Coding: 0000001
    VCID: E2C13FBE3D0D9108D78
    2 Faults Found:
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 86
    Mileage: 132440 km
    Time Indication: 0
    Date: 2013.04.10
    Time: 06:57:55
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 86
    Mileage: 132440 km
    Time Indication: 0
    Date: 2013.04.10
    Time: 06:57:55
    Address 61: Battery Regul. Labels: 4E0-910-181.lbl
    Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
    Component: ENERGIEMANAGER H12 0480
    Revision: 00000000 Serial number: 00000000002060
    Shop #: WSC 09222 444 52650
    Subsystem 1 - Part No: 4E0 915 105 A
    Component: von VA0 1502140437
    Coding: 344530393135313035412056413031353032313430343337
    Shop #: WSC 00000 128 00289
    5 Faults Found:
    02273 - Quiescent Current Stage 2
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 36
    Mileage: 122418 km
    Time Indication: 0
    Date: 2012.06.19
    Time: 09:10:22
    02276 - Quiescent Current Stage 5
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 26
    Mileage: 124928 km
    Time Indication: 0
    Date: 2012.08.21
    Time: 21:37:51
    02274 - Quiescent Current Stage 3
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 26
    Mileage: 124928 km
    Time Indication: 0
    Date: 2012.08.21
    Time: 21:38:02
    02277 - Quiescent Current Stage 6
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 26
    Mileage: 124928 km
    Time Indication: 0
    Date: 2012.08.21
    Time: 21:38:12
    00992 - Consumption Cut-Off Active
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 4
    Mileage: 131579 km
    Time Indication: 0
    Date: 2012.12.31
    Time: 19:04:10
    Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
    Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
    Component: Türsteuer.HL BRM002 0060
    Coding: 0028204
    VCID: 1E39CB4EC9F575E8330
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 0
    Reset counter: 107
    Mileage: 132320 km
    Time Indication: 0
    Date: 2013.02.06
    Time: 17:55:58
    Senior Member Two Rings DirtyJerzey's Avatar
    Feb 24 2008
    NJ-LA-TX
    Have you checked the ride height sensors? Have they been altered at all? Also have you changed any of the height parameters in the Vagcom before?
    May 20 2010
    Quote Originally Posted by DirtyJerzey View Post
    How do I check the ride height sensors? Do you mean physically or through VCDS? I did check the levels through VCDS, and it stated fronts were defaulted at 421 mm and rears at 398 mm. Which matches what VCDS says are defaults. There was another set of measuring blocks that gave me values, such as -112 mm, but it wasn't clear exactly how I should be reading those.
    I have changed ride height parameters on an Allroad with air suspension, but not an A8. I imagine they would be quite similar, but I could be wrong. I mean, the A8 is a technological marvel.
    And I don't think they have been altered at all; I don't think my buddy has done anything but I will double back with him to make sure.
    May 20 2010
    And my buddy says everything is completely stock, not worked on at all.
    Feb 24 2008
    NJ-LA-TX
    I would start with checking the physical sensors. They are only small pieces of plastic that can damage quiet easily. Across checking that the sensors are facing the correct direction.
    May 20 2010
    Are these independent sensors for each wheel? Or just one on each driver side wheel? In my A4, I have sensors for the adaptive lighting, which are on the front and rear drive side control arms (and like you said, easily are damaged). If they're independent, then what do they look like (i am assume I am looking for lever arms but I could be mistaken).
    And currently his adaptive lighting is having problems related to height adjustment.
    Feb 24 2008
    NJ-LA-TX
    Yes there are level sensors at every corner of the car. The rear linkage is much shorter and connects from the sensor to the lower control arm. The front linkage is longer and mounts from sensor to control arm.
    May 20 2010
    Thanks! Sounds similar to the other cars then (except all wheels). I'll have him check that out and hopefully be able to determine what it is (if they don't pop out like my A4's rear one did). Is there a specific resistance I should be reading as well?
