Results 1 to 29 of 29
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Squeaking noise from rear suspension
    Anyone have a clue what is causing this noise. I put a link to a video of the squeak below. It's coming from my rear driverside wheel well area. It only happens when the weather is warm. During the winter/rainning months it does not happen. I checked the e-brake cables already and they are not the culprit. I'm thinking it's the upper rear control arm bushings. I tried jacking up the car with the rear wheel off. And jacked the rear suspension up and down with my jack but, the squeaking noise did not come back. I put my wheel back and put the car back on the ground. Then I start pushing down on the trunk and the squeaking comes back. I think I need to go buy some ramps in order to inspect this squeak with the tire on. It's so annoying when I go into parking lots. It squeaks like an old bed frame. Driving on the freeway the squeak does not appear. Only on bumps in the road the squeak will appear. Anyone who has this issue and knows what it is. Please shed some info on this squeak. Thanks in advance.
    Video link to squeak:
    http://www.youtube.com/watch?v=YbMFZ...ature=youtu.be
    Mar 09 2013
    Ames, IA
    It could be a small crack in a spring that's what was the culprit for my A4.
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    When I had a cracked spring, it made a horrible squeaking noise. However, it was more of a grinding or metal on metal noise. I'd say jack up the back and take a look at both rear shocks. If the spring isn't rubbing on the shock, then it is something else that is causing the squeaking.
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Oct 26 2011
    CA
    Quote Originally Posted by adcannon View Post
    Checked my H&R coilover springs and shocks already. They are not damaged. Thanks for the cracked spring info.
    Feb 09 2013
    WNY
    Another thing to check would be the rear sway bushings.
    Oct 26 2011
    CA
    Quote Originally Posted by fR3ZNO View Post
    Just checked the sway bars and the bushings there are fine. Put some white lithium grease on them as well. And the squeak is still present.
    Feb 09 2013
    WNY
    The only other thing I could think of to be causing the squeak would be a control arm bushing like you mentioned.
    Feb 09 2013
    WNY
    You can buy a rear bushing kit for relatively cheap, they're just a PITA to install.
    Oct 26 2011
    CA
    I'm going to take the entire rear spring off to inspect the rear control arm this weekend. Hope it's nothing expensive to fix this annoying squeak. I give up for today.
    Dec 17 2008
    Kansas City
    I don't have the H&R's but on mine there was a design issue where the coil was binding when under compression. It would only happen when the car was on the ground, doesn't happen when jacked up. There wasn't anything wrong with the springs/shocks, just was a super annoying noise. The fix was the company replaced them with a newer design that solved the issue.
    Feb 09 2013
    WNY
    Quote Originally Posted by SRSslpr View Post
    Well if that was his problem, he could try spraying down the springs with some WD40 and if it goes away then he knows that is his problem.
    Established Member Two Rings b6scott's Avatar
    Sep 06 2010
    nj
    cracked spring
    2007 RS4 Unitronics tune, AWE down pipes and exhaust,body matched reflectors, tints, xenon interior bulbs, ported and polished intake manifold, K&N filter, De-Flapped, AC glove mod, ,JHM short throw ,JHM f/r rotors, JHM lightweight flywheel, JHM stage 4 clutch, JHM solid shift linkage, blackout headlight housing+CC mod, kmd catch can - gone
    2001 b5 s4 stage 3 minus - 12.61@108mph
    Senior Member Two Rings IgofastS4's Avatar
    Feb 23 2010
    2000 S4
    Earth
    Re: Squeaking noise from rear suspension
    All you need to do to inspect the bushings is jack it up on that side take the wheel off and then remove the bolt that connects the upper control arm to the upright and move it up and down as it was going over bumps. My wifes A4 did the same thing and it was the bushings it sounded as you stated like a old bed frame :eek:
    Senior Member Three Rings Delmed83's Avatar
    Feb 19 2013
    Spray ALL of the rear CA bushings with silicone spray, not white lithium grease. The rear guide link (rear tie rod) that controls the toe angle of the rear wheels also has a bushing. Disassemble the entire rear stabilizer bar system and grease the bar bushings and the link bushings. The OEM rear sway bar links suck. I replaced mine with Meyle links and they're way better. At 160k miles my rear links were extremely loose.
    I'm sorry I just got the video to work on my CPU and that DOES NOT sound like a bushing.
    You're best bet is to have someone do what you did in the video while you're under there. Put the rear up on ramps and jack up the front.
    Black 2013 B8.5 A4
    Previous rides:
    Silver 2001.5 B5 S4 - EPL Stage 3
    Black 2001 B5 A4 - Dahlback Stage 2
    Black 2006 B7 A4 S-Line APR Stage 2+
    Dolphin Gray B7 S4
    Feb 23 2010
    2000 S4
    Earth
    Quote Originally Posted by Delmed83 View Post
    I am just trying to help .We had the same issue with my wifes car doing the same thing and replacing the bushing solved the issue of the dreaded squeak.
    Feb 19 2013
    Quote Originally Posted by IgofastS4 View Post
    Really? Same sound?
    Almost sounds like a combination of bad bushing and something loose.
    Black 2013 B8.5 A4
    Previous rides:
    Dolphin Gray B7 S4
    Feb 23 2010
    2000 S4
    Earth
    Yes sir both sides CA bushings squeaked bad and this is what it looked like when I took them apart both sides just fell out as soon as I disassemble them. Any luck yet?
    Sent from my SPH-L900 using Tapatalk 2
    Oct 26 2011
    CA
    Great, thanks for the picture maybe mine might be the same thing. I was trying to remove my rear upper control arm. But ran into one issue, I could not get one of the four 17mm bolts off of the rear shock area. Because it is at a wierd angle. And I could not get any leverage to remove one of the 4 bolts. So, I just removed the long rear upper control arm bolt and added white lithium grease. The squeak is still there but not as loud. Going to get ramps and try to pinpoint the noise. Just been really busy with work.
    Feb 23 2010
    2000 S4
    Earth
    Only one of the four CA bushings were still on track. I dont like doing things twice so i have done all four at once. Silicone spray and white lithium grease will only last so long If it is the same issue you are having. The only way to fix that dreaded squeak is to replace it not to mask it will a lubricant. Hope this helps :)
    Oct 26 2011
    CA
    Finally found out where the squeak is coming from. It was the coil-over helper spring binding on the bigger spring. Somehow the helper spring was not aligned with the bigger spring.
    Feb 19 2013
    ^^ Good job!!!
    IgofastS4, how much did it run you to replace the rear CA bushings? I have a press so I can just press the old ones out and the new ones in, correct?
    Holy crap..... I hope you didn't use that BAH to put them back in as well?!!!!
    Black 2013 B8.5 A4
    Previous rides:
    Dolphin Gray B7 S4
    Oct 26 2011
    CA
    Cheapest I have found for the rear control arm bushings is at http://www.autohausaz.com/ for like $47.70 shipping not included yet. The parts numbers are listed below. The brand of the bushings are Meyle.
    Control Arm Bushing; Rear Suspension; Upper Inner Position part# 8D0505185A
    $14.41 each
    Control Arm Bushing; Rear Suspension; Upper Outer Position part# 8A0505172B
    $18.88 each
    Feb 19 2013
    Quote Originally Posted by xalents23 View Post
    $14.41 each
    $18.88 each
    Thanks!! Not bad!! I really like Meyle suspension parts so that's a win in my book. I'm def gonna scoop these up!
    Black 2013 B8.5 A4
    Previous rides:
    Dolphin Gray B7 S4
    Feb 23 2010
    2000 S4
    Earth
    Dreaded REAR SUSPENTION Squeak's
    That's Sweet you found it and the time, There is nothing more frustrating than having some sweet Audi Love and Having a Dreaded Squeak
    How does it feel to have it fixed Now?
    ^^ Good job!!!
    Yes Very Easy Fix as far as the pressing goes I still Cannot get over your funny Comment About the BAH
    Feb 23 2010
    2000 S4
    Earth
    Finished with new bushings And Coilovers
    Sent from my SPH-L900 using Tapatalk 4 Beta
    Oct 26 2011
    CA
    Nice, did you re-paint your control arms they look like new.
    After fixing the squeak I don't get weird looks from people while I'm driving in my apartment complex anymore. I'm like yeah I know my car is squeaking stop staring.
    Feb 19 2013
    Looks good. I'm assuming the bottom CA bushings can be done for a comparable price as well.
    Black 2013 B8.5 A4
    Previous rides:
    Dolphin Gray B7 S4
    Senior Member Three Rings RSLRS71's Avatar
    Mar 03 2017
    18' SQ5 and WK2 SRT8 Jeep
    Castle Rock, CO
    if not the bushings let me know...i think i know what the culprit is...had a similar issue on the RS and it was driving me crazy....found a structural piece rubbing against another piece that was causing the exact sound.
    2017 RSL RS7 (1 of 3 stateside)
    Mods:
    Current: APR Stage II w/ HF DPs and KW H.A.S kit , Rotiform 3 piece SPF 21x10.5 wheels, Tag Motorsports Side marker delete and Badge blackout, ...
    Next: looking to be the quickest RS7! ;)
    Dec 10 2013
    Borden, Ontario, Canada
    Lol necro bumps never get old
    Sent from my SM-G935W8 using Tapatalk
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
