Results 1 to 28 of 28
    Senior Member Two Rings 561audia4's Avatar
    Feb 02 2006
    2014 BMW M6 GranCoupe, 2010 VW GTI DSG Autobahn edition
    Ocala
    CREE LED reverse lights with RESISTOR and I STILL get a bulb out warning
    I purchased 4 CREE LED reverse lights (http://store.ijdmtoy.com/T15-912-921...t15_sku311.htm) for my 09 A5 and I bought 4 of these resistors (http://www.amazon.com/Resistors-Sign...ords=resistors) to go with each bulb. I wired in the resistor into the ground of each bulb and I still get a bulb out warning. I tried each one individually with the same success. I dont know much about this and was wondering if the resistor I purchased does not cover the load of the bulb. I kind of find that hard to believe since the bulb is only 2.5W?? Any advice is appreciated. Thanks in advance
    Carl-
    CURRENT 2014 BMW M6 GranCoupe | Competition Pkg | IND Cosmetic Pkg | Ceramic Coating | Hardwired Passport Escort 9500xi |
    SOLD 2009 A5 3.2 Quattro
    SOLD: 2002 B6 1.8T Quattro
    Aug 04 2010
    Queenz/Westchester
    Feb 02 2006
    Ocala
    This does not work. I tried it with two separate Ross vag coms. There is no way to literally change it into binary code and the decimal code given does not work. Thanks for the input though.
    Does anyone else know what else I could try? I'm thinking of changing out the resistors for different ones?
    Carl-
    Jan 15 2013
    2011 A5, 2012 Range Rover Evoque
    Coral Springs, FL USA
    How did you wire the resistor? It should be wired in parallel with the LED. If you wired it in series, it will decrease the load, not increase it.
    Veteran Member Three Rings awhk82's Avatar
    Jul 13 2007
    Hong Kong
    Quote Originally Posted by 561audia4 View Post
    You need to use your own decimal number in Adaption Channel 181 and convert to binary using some tools online (http://acc6.its.brooklyn.cuny.edu/~g.../nav2tool.html), change bit 10 and 11 to zero, then convert back to decimal.
    Or even easier method, since binary bit 10 and 11 represents 1024 and 2048, respectively in terms of decimal, you simply minus these two (3072) from your original decimal value.
    2012 RS4 Avant - Suzuka Grey
    Capristo Catback, HMS X-pipe
    Before...
    11 TTRS | 10 S5 SB | 08 A4 3.2 | 06 A4 2.0T | 05 A3 SB 2.0T | 04 S4 | 99 A4 2.8
    Aug 04 2010
    Queenz/Westchester
    I got it. I figured the coding would be different between the A/S4 and the A/S5, since we have four bulbs compared to their 2. Once I got the channel it was just a matter of figuring out which decimals coded for the reverse lights (or which 1's I had to change to 0's to turn off the reverse light sensors).
    Steps:
    1. Module 46 Central Convenience > Security Access 16 > 16017 (use this access code, not the one the ross-tech suggests)
    2. Adaption 10 > Channel 181 >Read
    The value you get is 65535 (at least that was mine). When you convert that to decimal it comes out to 1111111111111111. Bits 8,9,10,11 code for the reverse lights (1111RLRL11111111) so when you convert them it becomes 1111000011111111. Convert that back to binary and it becomes 61695
    3. Enter 61695, hit test then save. Done.
    No more reverse light error message. Thanks to awhk82 for showing me the path, couldn't have done it otherwise.
    I got the Cree ones also and they are nice and bright. What I don't like about them is they are off and in the housing, they shape and angle of the lens gives of a kind of yellowish tint, which you can see through the glass. I may have to find another brand that doesn't give off that yellowish tint, but for now it's ok.
    Edit: BTW I didn't need or use any resistors
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    Quote Originally Posted by shonseb View Post
    Steps:
    The value you get is 65535 (at least that was mine). When you convert that to decimal it comes out to 1111111111111111. Bits 5,6,7,8 code for the reverse lights (1111RLRL11111111) so when you convert them it becomes 1111000011111111. Convert that back to binary and it becomes 61695
    Just wondering should I buy one bulb or two bulbs for the car, and how much labor for the replacement of the bulb?
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Aug 04 2010
    Queenz/Westchester
    4 bulbs, you can do it on your own, you just need the vag com cable. took me all of 20 mins.
    Oct 17 2012
    NoCal
    Thanks a lot ! man ~
    I just placed an order ~
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Aug 04 2010
    Queenz/Westchester
    DIY
    Tools needed: flat head screwdriver, vag com cable
    Open the trunk and look on the inside edge of the back of the trunk (inside part of the trunk behind the license plate). You will see 2 flaps on either side. when you pull those away, you can see the back of the light housing. The housing is fixed in place by two black brackets that you can unscrew using the flat head screwdriver. After unscrewing and removing these brackets, you can disconnect the wiring and pull the light housing off the vehicle. Locate the reverse light bulb, unscrew the holder, remove and replace the bulbs with the new LEDs. Do not put it back yet, connect the wires back and let it stay there. Now repeat these steps for the other side.
    After changing those, you want to access the other lights. Access the cubby hole where the amplifier sits. You will see a black bracket piece about 2 inches long that comes strait out which holds the housing in place. Using the flat head screwdriver, unscrew the bracket by putting the screwdriver strait in. You will also see a water seal that the wires enter through (round and black) that you can pry off. Once the bracket is off, you can pull the light housing off the car, but there are 2 clips that still hold the light in place. To get the light off, you must GENTLY yet with a little bit of force, pull the housing away from the car, toward the rear, not side. Once the light housing is off, replace the bulbs with the new LEDs, and again don't put it back yet. Repeat for the other side by accessing the area behind the cubby hole on the right.
    Once all 4 bulbs are installed, pull the parking brake on and turn on the ignition. You do not have to turn on your car, just the ignition to ON position. Shift into R, at which point you will see the error message pop up on your speedometer. Go and check all the bulbs to make sure they are working. If they are not, that means the polarity is reversed. Take the bulb out, flip it around, replace and the light should now be working. Once all are working, turn the car off and put the lights back on the car using the reverse order. Then use the vag com and to get rid of the reverse light message.
    Oct 17 2012
    NoCal
    DIY
    Wow ! That's incredible instruction along with the Vag-Com part.
    Just wondering what would be a reasonable price for labor if I ask the dealer to replace the bulbs for me? (I will cover the Vag-Com part myself)
    Thank you
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Aug 04 2010
    Queenz/Westchester
    yeah, it's really strait forward, very easy to do. If you want your dealer to do it, expect to be charged anywhere from a 1/2 hour labor to 1 hour labor ($65-130). Honestly, you can do it on your own, no need to waste money.
    Oct 17 2012
    NoCal
    Thank you so much, man
    Honestly, I have the tools and vag com cable, but I'm just afraid of causing any damage to he car.
    I will ask them to install the coilovers and adjustable upper control arms anyway, hopefully can ask them to replace the bulbs for free.
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Oct 17 2012
    NoCal
    Oh, one more question for you, all I need to do are just these three, correct?
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Aug 04 2010
    Queenz/Westchester
    Re: CREE LED reverse lights with RESISTOR and I STILL get a bulb out warning
    Yup, that's it
    Sent from Tmobile MyTouch 4g
    Aug 04 2010
    Queenz/Westchester
    You know, now that I think about it, you have a b8.5, with new taillights. The coding may be different. Its likely still in channel 181, but may be a different binary.
    Oct 17 2012
    NoCal
    Steps:
    This is just excellent !!! It works for the 2013 models !!!
    I just put the LED bulbs for my reserve lights, put it in the reverse gear, then the warning indicator came on.
    After doing this coding, it went off !!! (BTW, I got 65535 as well)
    Thanks a lot, shonseb !!!
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Established Member Two Rings Roxxx&co's Avatar
    Dec 04 2012
    2012 A6 Prestige, 2013 Q5 P+
    NorCal
    I havent had good experience with the LEDs from ijdmtoy their LEDs blow out in 3-4 months. I got all my interiors from Lighting Tekniks and my LED lic plate ones are from ebay. Total plug and play on my 11. Not sure about the 13s.
    2011 S5: Philips 6K HIDs, 6K Fogs, interior LEDs, S-Tronic shift knob, 19x9.5 ESM LMs, V1, CF interior, Miltek exhaust, H&R sways, ST Coilovers, RS5 black grill, AWE CF intake, Unitronic software, OE CF interior
    2010 R8: white on black, Full Neidfaktor CF interior w/steering wheel, 20" RSV RS12S wheels, IPE Valvetronic exhaust, H&R springs, Stasis sways, German Motoring ECU/TCU, K&N, V1+Blinder jammer, PPI CF wing, panel, mirrors
    Active Member Two Rings East's Avatar
    Aug 08 2012
    Northern DE
    So when attempting the VAG COM to disable the reverse lights, I completely "bricked" my car......
    Just kidding!
    Actually, when coding this, I had bookmarked an A4/S4 writeup and put the channel 181 value in as 62463...and couldn't understand for the life of me why I was still getting a reverse bulb out warning...until trial and error led me to discover that I was NOT erroring for the inner bulbs, but for the outer ones...WOW...so I figured there HAD to be a code for A5/S5 with 4 reverse lights instead of the A4/S4's 2 lights.
    Shonseb you pulled my butt out of the fire twice in one mod! (reading comprehension problems aside)
    For your enjoyment...this mod is SO worth it
    2011 []S5 // 6MT // Sprint Blue Pearl // Premium Plus // Nav // B&O // Sport Rear Diff // VAG COM
    Aug 04 2010
    Queenz/Westchester
    Quote Originally Posted by xuandatou View Post
    Quote Originally Posted by East View Post
    Glad I could help guys, happy modding!
    Oct 17 2012
    NoCal
    Oh, Im just wondering how many led bulbs have you released for the reverse light?
    Should it be 4 instead of 2?
    My technician at the dealer just replaced 2!
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Aug 04 2010
    Queenz/Westchester
    I replaced 4, two outer, two inner
    Deactivated Three Rings
    Apr 22 2010
    Lots of spiders.
    Northeast US
    Just kidding!
    Nice mod, Governor.
    Happy to see your talents encompass more than politics.
    Oct 17 2012
    NoCal
    Thanks a lot ~ I'll check it out
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Oct 17 2012
    NoCal
    Maybe 13 model only comes with 2 bulbs for their reverse light.
    Thanks anyway !
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Aug 04 2010
    Queenz/Westchester
    Yeah I checked, only 2 on the face lift
    Junior Member Two Rings Jaymehaze's Avatar
    Jul 15 2013
    07 R1, 11 R1 11 S5 b8 , 07 335i e92 n54
    Ny garrison
    Worked great on my 2011 s5 as well .. Thanks for all the help !!
    Mar 30 2018
    europe
    Hello gents,
    Old post, but maybe someone could help how to find the byte and long bit coding in order to deactivate mirror blinker bulb check on a 2011 A5 CAB ???
