Page 1 of 8 123 ... LastLast
Results 1 to 40 of 298
    Account Terminated Four Rings
    Feb 26 2011
    las vegas
    Final Dyno SRM K24 before removing cats and 2.5" downpipes
    32psi - 604whp - 572wtq
    Iat's graph also placed below, Vegas is hot....
    I will also preface the IAT graph that this was the 2nd to last pull. The 3rd pull that yielded the dyno graph decided to stop logging at 6200 but was just as severe of a climb so just posting this one for reference.
    Needs more fuel in the middle and pulled a little timing there.
    Reminder of hardware, on e85:
    J-WOWW tune
    Billet RS6 hybrid turbos
    RPM rods
    Stock heads
    stock IM with Cobbled RS4 tb
    SSAC 2.5" downpipes with cats and double resonated 2.5" catback
    Cobbled inlets
    Cobbled y pipe
    Cobbled mandrel bent bi pipes
    Cobbled together intercoolers
    IE dual 044 surge tank fueling
    034 rails
    1000cc ev14
    The cobbled mess as it sits
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Lake Lanier, GA
    604whp with INSANE IATs with a bit of altitude.
    Whats that? 660whp+ on a dynojet?
    2.5inch downpipes and dual 2.5 inch exhaust and stock heads, lol. 3" downpipes and a bigger catback + cat delete should break 600wtq...
    Veteran Member Three Rings Blake2423's Avatar
    Sep 11 2010
    '04 Cayenne Turbo
    Atlanta, GA
    Oh sweet jesus, I just love these turbos
    01.5 S4 AVANT Brilliant Black - SRM SMIC, SRM K24 HYBRID, SRM 102MM INTAKE, 1000cc INJECTORS, GET WATKINS E85 TUNE, JHM STAGE 4 CLUTCH, JHM SYNCHROS, SRM 3INCH DOWNPIPES, AWE MID MUFFLER EXHAUST, JHM SHIFTER, BREMBO GT KIT FRONT AND REAR, H&R RSS CLUBSPORT COILOVERS, 034 swaybar and links, AWE DRIVETRAIN STABILIZER, STERN ENGINE/TRANS MOUNTS AND REAR DIFF BUSHINGS, ECS REAR DIFF MOUNT
    Veteran Member Three Rings uponone nogaro's Avatar
    Sep 13 2011
    01 Silver S4, 00 Noggy S4 Sport Package, B8.5 Dsg S4 Dual Pulley,240sx w/2j swap
    Bay Area CA.
    Nice good.numbers man
    Veteran Member Three Rings joe dub's Avatar
    Sep 01 2008
    Illinois
    deng
    silver - RIP
    black - TAILS
    Sep 18 2008
    lancaster,pa
    Nice!
    Frankenturbos, Stage 3 tuning by Jfonz Tuning.
    Veteran Member Three Rings z00lander's Avatar
    Apr 10 2010
    VW Atlas family mover
    everett, wa
    Very impressive
    My signature is a blank canvas of censorship
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by itguy View Post
    J-WOWW tune
    Lol, I give you credit just for that.
    Great numbers. These are the turbos selling for 2K? I mean, if they hold together why wouldn't one buy them?! Plans to hit the track? That's serious power.. And if they have a good powerband, could be really potent on the track.
    What does the boost onset look like?
    Jan 11 2007
    Salt Lake City, Utah
    What were the uncorrected numbers for your previous 550whp dyno? What differences were made to your setup between now and then?
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Feb 26 2011
    las vegas
    20psi @ 4k
    Track Friday night
    Quote Originally Posted by jibberjive View Post
    1st dyno run was 72lb injectors at 6.5bar. One of the injectors popped so replaced with 96's and lowered to 4bar. Boost tapered from 28-25psi as the mbc was leaking. Holds flat now.
    Correction looks roughly the same.
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    600 whp car right there.
    Congrats. Nice work.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    Wow, that's very impressive. You on E85?
    2005 Ferrari F430
    2007 RS4 Daytona Grey | 2008 RS4 Mugello w/Ti Package | 2007 RS4 Avus Silver (ex-Audi Corporate) | 2008 RS4 Avus Silver w/Exclusive Package
    B6 S4 Avant 6MT Dolphin Grey
    B5 S4 Avant 6MT Laser Red Stage 3+
    B5 S4 Sedan 6MT Silver Stage 1
    Sep 18 2012
    State College PA
    Very nice numbers.
    Would love to see what it does on 93 only though... E85 is a huge help for sure.
    Lots of smoothing on that dyno plot, what did a non smoothed one look like?
    30psi till redline?
    Feb 26 2011
    las vegas
    We have a ton of rough pulls on many other cars on this dyno. I didnt notice the operator added a filter up top... No idea what the un-smoothed curve looks like
    Sep 18 2012
    State College PA
    We have a ton of rough pulls on many other cars on this dyno. I didnt notice the operator added a filter up top... No idea what the un-smoothed curve looks like.
    Then that's still a very smooth power delivery, filtering is pretty standard on dynos.
    I'm gonna get a ride in this car when I come out right? :-)
    Jun 14 2007
    2000 S4
    Connecticut
    20psi @ 4k
    Track Friday night
    Tonight? Good luck!
    Feb 26 2011
    las vegas
    Ya, just need a clutch switch so anti lag works.
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    They can flow 32psi without overspeeding too much :p
    I would suggest if running an mbc, around 28psi OR spiking on n75 30-32 and tapering to high 20's by redline.
    When you say 32 psi, what exactly is that referring to? An initial spike or what is held?
    Jan 25 2006
    A4 2.0T
    MD
    The filter value is 80, you can see it on the graph.
    Jun 14 2007
    2000 S4
    Connecticut
    Nice man.. I'll take mine out and send it FedEx Custom Critical... Should be there ASAP, probably only run you 5k in shipping. lol.
    Random Vegas question - Is the Nurburgring copy still being considered to be built out there? Or did that thought go down with the rest of Vegas's economy in 2008?
    Feb 26 2011
    las vegas
    Ya that was dropped sadly.
    Oct 27 2011
    TOYS
    Philly Suburbs
    What clutch are you running again?
    Veteran Member Four Rings ggg20t's Avatar
    Sep 18 2008
    Pittsburgh, PA
    Feb 26 2011
    las vegas
    Clutch net 6 puck disc with rs4 pp
    Sep 14 2009
    s.e. mass
    itguy - congrats, those turbos are working!
    IG: @PB5S4
    Sep 18 2012
    State College PA
    Sounds like quite a test for the clutch... any sign of slip on the road or is it holding good?
    Post the FATS times for this bad boy
    Sep 18 2012
    State College PA
    Btw how much air will each of those turbos flow at a PR of ~2:1 / 2.5:1?
    Feb 26 2011
    las vegas
    Over 50 hard launches and no issues, hooks up every time. People dont understand that using these button clutches doesnt require as high clamping force. You can use a 4 button clutch with stock pp and hold over 600wtq.
    If you can find a reliable, up to date compressor map of a 2283 wheel then you can probably answer better than me.
    Veteran Member Three Rings zdriver's Avatar
    Jan 17 2010
    Boston, MA
    i like
    BMW E30 Holset hx35
    B5 S4 Brilliant Black
    B5 S4 Avant: Imola Yellow (retired)
    Sep 18 2012
    State College PA
    Looks like combined they flow close to what my one turbo will...
    Only mine won't quite run out of steam at 30psi... So it should be fun
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    Niiiiiiiice.
    Veteran Member Three Rings spd579's Avatar
    Jun 04 2012
    05 s2000, 2001 Mazda Miata with SR20deT(GT2871) swap, 1990 Mazda Miata(Tme attack(500whp))
    Charlotte, NC
    So based of what I see these turbos fall just below 770's and a good bit above 605's..........could everyone agree that's accurate?
    Or wait.....with ~25% drivetrain loss(AWD) these would texhnically almost identical 770's? (not seeeing how this is possible due to the 770 being larger in every way with a BB CHRA)
    Math:
    770/1.25= 616 whp
    604/.8= 755 chp
    .8 is derived from the percent change from 770 to 616 to keep things consistent
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by spd579 View Post
    If you could refer me to results from a built 605 engine with an E85 tune I'd be better able to give my 2 cents.
    Jan 25 2006
    A4 2.0T
    MD
    Math:
    770/1.25= 616 whp
    604/.8= 755 chp
    FYI, 770s have made over 700 awhp.
    Jul 28 2009
    Philadelphia PA
    Quote Originally Posted by Don Supreme View Post
    on e85 at 42 psi
    c8 a6 allroad
    Feb 06 2012
    Lake Lanier, GA
    on le dynojet! Also couldn't be attainable without some srm sawce!
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by rtl5009 View Post
    on e85 at 42 psi
    Quote Originally Posted by aysix View Post
    You are both referencing the same car, there have been others that broke 700awhp (i.e. other fuel type, non-dyno jet, etc).
    Regardless, this type of keyboard tuner comparison is a giant waste of time. However, I am sure we can both agree that the 770 is still probably capable of a bit more peak power. This still doesn't make it the best choice considering cost and other factors.
    Feb 06 2012
    Lake Lanier, GA
    I don't get it.
    don't think anyone would disagree with you there!
    Who?
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    <-- anxious to get a set of these compressors
    I rode in op's car @ 24psi... my senses were pleased
    Jan 25 2006
    A4 2.0T
    MD
    I don't get it.
    Who?
    I can think of 2 off the top of my head.
    The RSWorx car and one of those AMS cars.
