Results 1 to 28 of 28
    May 01 2012
    Will sport shocks work with non sport springs?
    All OEM for B6.
    Just curious if this will kill the shock prematurely. Thanks.
    Active Member Four Rings schmally's Avatar
    May 19 2009
    Nothing worth adding
    Alabama
    YES
    Gcc's blacksheep
    May 01 2012
    Quote Originally Posted by schmally View Post
    YES
    Yes to my first or second question?
    Account Terminated Four Rings
    Oct 26 2009
    Beaver Creek, CO
    Well I would assume they are used shocks, so prematurely shouldn't be your concern.
    What should be your concern is WHY would you do the work of replacing the shock, BUT keep the non-sport springs and drive around 3' off the ground? Find some sport springs while you're at it.
    May 01 2012
    Quote Originally Posted by Greedo View Post
    I don't want to lower the car so i prefer to be 3' off the ground.. The shocks are used but do not have lots of miles on them.. I would hate to throw these away though.
    Nov 11 2010
    Rochester, MN
    Agreed, putting sport shocks on non-sport springs is not going to give you an ideal ride. If they did, I would have done this long ago on my Avant!
    19" B8 S5 Peelers
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    I have a set of sport springs available. I'm going a different direction with my setup.
    RAI Test pipe / TT DP / S4 rear sway / Motoza stage 1 / SAI delete / IE Blockoff plate / S4 Front Recaros / B7 Center Console
    http://www.flickr.com/photos/27286038@N03/
    Veteran Member Four Rings Peacob's Avatar
    Jul 08 2009
    Bicycles
    Detroit MI
    Quote Originally Posted by AlS6 View Post
    You do realize sport spring ride height isnt low at all right? Hell i drove around in Michigan winters with no issues of rubbing on Eibach Pro kit springs before going lower on coils.
    -Brian
    B6 A4 USP OEM+
    B8.5 SQ5
    B8 A4 Avant S-Line Prestige
    Jun 27 2011
    I've only ever scraped my USP front once on a driveway with a large rain gutter leading up to it that I didn't see. Sport ride height is not low. And I only drive in the Seattle city area, nine of those luxurious Eastside/suburb roads.
    Why would you WANT that extra ride height? Just adds body roll...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    May 01 2012
    My car is non sport height and prefer to keep it that way and since i got these sport shocks I thought I'd throw them in there.. Would that also firm up the ride a bit?.. I want to keep the stock non sport ride height as I have a steep driveway... Either that or I could just fork up and get some Bils HD or Koni FSD but like I said these are low miles shocks and no leaks on them and I'd hate to dump them.
    Oct 26 2009
    Beaver Creek, CO
    They'll work, but will never preform as well as something aftermarket.
    Jul 08 2009
    Bicycles
    Detroit MI
    majority of bone stock sedans on this planet sit lower than your car... so i dont know why the hell you wont just buy some sport springs and do it the right way while removing the struts. I dont care how steep your driveway is, i guarantee you will be able to get in and out of it without a single issue.
    -Brian
    B6 A4 USP OEM+
    B8.5 SQ5
    Veteran Member Three Rings stelvio's Avatar
    Feb 13 2012
    If you want your car to have the off-roader status why did you buy an A4? No one's saying it should be slammed but this is like blasphemy on an Audi forum lol Just sayin' [and i've had oem 'sport' suspension and I couldn't scrape anything even if I tried].
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    The sport shocks are designed to work with sport springs, that are shorter than nonsport springs. Find some proper, nonsport shocks to run with your nonsport springs.
    2019 SQ5 Prestige
    Jun 27 2011
    I believe the sport shocks actaully have a shorter throw than the non-sport shocks, though I may be wrong. I'm not sure the shorter throw will actually work with the longer springs of the non-sport suspension...
    -CP
    2017 Q7 3.0t
    Jul 08 2009
    Bicycles
    Detroit MI
    You are correct. As for them working, yes they will, it just wont ride the way it was suppose to. Think of it like the exact opposite as using lowering springs on non-sport struts. Using a shorter spring on non-sport strut will essentially pre-load the strut further than it was meant to.
    -Brian
    B6 A4 USP OEM+
    B8.5 SQ5
    Jan 22 2013
    Bloomington, IN
    AIS6,
    I just put KONI Sport shocks on my stock non sport sprung 1.8 Avant with no issues. I did machine a new spring perch groove in the front shocks 5/8" lower than stock to give the car a little front rake. The ride is more firm than before, due most likely to the 170K miles on the stock shocks. I too didn't want to drop the car 1+" and have a harsher ride than what the stock springs offered. Besides my bike, this is my daily driver and commuter car and I like the ride.
    Feb 13 2012
    Do you guys think that installing lowering springs ruin the car's handling or something? I seriously don't understand this fear of lowering the car with aftermarket lowering springs. I just got Tein S springs on Sport Shocks and the car dropped ~1" and there is still more than enough comfort available; enough to take my mother in the car without her even noticing an unpleasant drive. It just takes away from the bodyroll and drops the car where it should have been from factory.
    Jun 27 2011
    Quote Originally Posted by stelvio View Post
    This. Though my old non-sport b7 WAS cushier, it rolled WAY more in the corners and I would deem its cornering abilities "unsafe" compared to my sport B6....
    -CP
    2017 Q7 3.0t
    Feb 13 2012
    x2!
    I was on the highway once and the guy in front slammed the brakes or something stupid and I had to swerve around him to avoid pancaking him and the insane amount of bodyroll at ~60mph terrified me a whole lot more than the lack of attention from the car in front.
    If you're worried about scraping stuff then maybe the Allroad is better for you with its adaptive suspension. You should climb driveways/parking lot entrances slowly and avoid pot-holes/etc. whether you're 2" off the ground or 6" in an effort to save your ball joints and other [expensive] steering/suspension components and alignment. Not trying to bash anyone here but the thought of favouring the non-sport suspension over a set-up with more rigidity is unfathomable in my mind, especially when comparing the benefits of a more sturdy vehicle. I guess just my $0.02 :)
    Apr 01 2007
    houston texas
    No there is not any fear that installing lowering springs will ruin the car's handling. My car has lowering springs installed (with matched shocks) and its handles very well IMO. The issue here is using mismatched shocks and springs. Will it make your car blow up? No. Is it ideal? Far from. Why not just get two components that work correctly in tandem?
    2019 SQ5 Prestige
    May 11 2008
    Columbus, OH
    Doesn't even have to be aftermarket. OEM sport springs are the ideal in between setups. He already has the shocks. I have a set of springs, get some b5 perches and be done! You will have an even fender gap and an OEM suspension complete. You bought sport shocks for a reason, fulfill the rest of the setup.
    Veteran Member Three Rings Murph's Avatar
    Sep 07 2008
    Seacoast NH
    OP: I put the OEM Sport Springs and dampers on my car and have never scraped. I know you're apprehensive about it but it's worth it. It's not slammed or really low but no longer has the big Gapina. Here's a couple of pics so you can see. I'm running 235/45/17 tires
    Now: 2007 B7 A4 3.2L Auto. It's stock and staying that way. Then: Sold to another enthusiast: 2005 Dolphin B6 TQ 6 speed. GTRS Eliminator, Bosch 550 injectors, REVO SW, FMIC, APR TIP, High Flow Cat, Milltek Cat Back, Custom Interior Mods, Short Shift Kit, Suspension Goodies, S4 Recaro Seats
    Jul 08 2009
    Bicycles
    Detroit MI
    Quote Originally Posted by Murph View Post
    OP: I put the OEM Sport Springs and dampers on my car and have never scraped. I know you're apprehensive about it but it's worth it. It's not slammed or really low but no longer has the big Gapina. Here's a couple of pics so you can see. I'm running 245/35/17 tires
    What murph said.
    And to other previous posts... the reason he wont put lowering springs on is not because of ride quality, but because he's afraid of scraping.... There are plenty more factory sedans that sit lower than a sport suspension b6 a4... Hell, i'm pretty sure the chevy Volt sits noticeably lower than any a4 with sport suspension, so i dont know what the hell his worry is.
    -Brian
    B6 A4 USP OEM+
    B8.5 SQ5
    Feb 13 2012
    Quote Originally Posted by Peacob View Post
    You're so straight forward haha. Considering people on here have pretty much every suspension combination possible, we're only vouching for what we have/have lived with so hopefully the OP will make an informed decision and at least get the Sport Springs on his B6; it would be a shame for his B6. I cringe every time I see a B6 with massive wheel gap and on the 16" rims.
    Sep 07 2008
    Seacoast NH
    Also, if you're concerned about ride comfort, the sport setup is a tad firmer but certainly not buckboard like. When I ran 16's in the winter it was just about as soft and comfy as the non sport setup so if you're really concerned about ride comfort you can run the 16's with the sport suspension and have the best of both worlds.
    Oct 26 2009
    Beaver Creek, CO
    My car doesn't scrape.
    Veteran Member Three Rings Sam091990's Avatar
    Dec 22 2011
    05 A4 1.8TQM
    Burbank, IL
    || Instagram @SAMM9690 ||
