Results 1 to 7 of 7
    Active Member Two Rings langer's Avatar
    Apr 19 2013
    Where can I find the pintle caps for our stock injectors?
    My local napas and the like are unable to find the white/brown spacer that holds the o-ring on. Anyone know where to find these? Mine have cracked and fallen into the valves
    It's the white part in this picture
    Established Member Three Rings Ricky Spanish's Avatar
    Apr 01 2013
    03 A4 1.8t, 02 jetta
    North Canton Ohio
    I would suggest trying to find a set of used injectors.... I just got some off ebay with 30000 miles on them for $12 shipped... Im really not sure if those even come off without breaking.... check with a dealership..
    Drive German or walk!!
    Jun 30 2008
    Erie, Pennsylvania
    JHM used to sell these, but I can't find them on their site anymore. They work good on 1.8T injectors as per this post:
    http://www.audizine.com/forum/showth...=1#post7554669
    Maybe give JHM a call?
    Looks like you can get them on ebay as well. Either the "universal" type that looks like what JHM was selling:
    http://www.ebay.com/itm/Bosch-Type-3...237efc&vxp=mtr
    Or the original "washer style" which came from the factory:
    http://www.ebay.com/itm/Bosch-Type-3...4c5db1&vxp=mtr
    Apr 19 2013
    Thanks Walky,
    I had seen mr. Injector, but I was unable to determine which 'type' of injector I had. This helps immensely!
    Veteran Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    Walky, you beat me to it. My JHM ones are still working like a champ.
    Apr 19 2013
    For anyone who finds this thread, I wound up buying an injector service kit from a guy on ebay called allzone. Price is good and international shipping was reasonable
    http://www.ebay.com/itm/Bosch-Type-3...51265304900%26
    Dec 25 2004
    Earth
    Its really only needed when removing the injectors from the manifold.
    You can use a scribe or pick to remove the o-rings if the come off the injectors and remains inside the intake manifold.
    Installing the injectors the o-ring is pushed onto the injector.
    IMO, not really needed....
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
