Results 1 to 16 of 16
    Senior Member Two Rings CharlesP2009's Avatar
    Sep 22 2012
    2009 Audi A4, 2009 BMW 335i Convertible
    The Copper State
    Question Anybody here put oil into the filter canister before reinstalling?
    I'm getting close to my second oil change and I have been thinking it might be better for the engine if I put some fresh oil into the filter assembly before reinstalling it and starting the car. I have no idea how long it takes for oil to travel from the bottom of the pan through the filter and to the topside but even a couple of seconds can be rough on an engine. Is it practical to reinstall the assembly with some oil in it or am I just asking to make a mess?
    Dec 05 2007
    You are always supposed to prime a filter before installing. When you fill the filter, the oil should be channeled to the outside portion of it, allowing you to turn it sideways without spillage. You will see when you add oil into the filter how the level will drop after a couple seconds.
    Sep 22 2012
    The Copper State
    The first time I did an oil change on der Audi I was following a DIY and it never mentioned priming the filter (in fact none of the DIYs I've read have primed a filter). I was kinda nervous on that first oil change since this car is so different compared to anything else I've ever serviced; what with removing a splash shield and draining the filter assembly. Upon reflection though I do consider priming to be important.
    Mar 31 2012
    Savannah. GA. USA. TO. ON. CAN
    I've been doing it since I owned my first car in HS. Pre-filling OFH with oil prevents a dry start-up and immediate oil supply to the valvetrain i.e. hydraulic lifters, camshaft etc.
    2.0 TFSI
    1.9 TDI
    2.0 TDI
    It's also important to pre-fill FF with fuel and pressurised the system since fuel components such as fuel injectors are lubricated with fuel not air.
    //S POWER
    Mar 31 2012
    Quote Originally Posted by CharlesP2009 View Post
    ......I was following a DIY and it never mentioned priming the filter (in fact none of the DIYs I've read have primed a filter).
    It's sad but it's true, they didn't know what they're doing
    //S POWER
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    I've been filling filters with as much oil I can get in without spilling it for 35 years. With the A4 it's a good way to make sure the valve at the bottom of housing is not leaking. So I fill the housing about half full and place the filter in. After a few minutes I turn the filter over to get the rest of it wet. Then I add enough more oil to the housing so that none spills out during the installation. A bit excessive perhaps but the engine oil pressure comes up instantly - no lag time where it's not getting lubrication on starting after an oil change.
    Sep 22 2012
    The Copper State
    Oooo I like the location of the oil filter on those TDI engines. Come on Audi! Give us moar diesels!
    Established Member Two Rings jjj751's Avatar
    Mar 15 2012
    Las Vegas NV
    Shit, I just changed my oil 5 mins ago for the first time and didn't prime it like you guys said. Won't screw anything up if it was just once right?
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Quote Originally Posted by jjj751 View Post
    Likely fine, there's still plenty of oil in the oil passages/channels through out the engine that don't really drain out during an oil change.
    Just remember for next time, I always fill up the filter too.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Re: Anybody here put oil into the filter canister before reinstalling?
    I've never primed my filter. Never even crossed my mind. Never had an issue. I'll probably do it next time, just because of this thread.
    Sent from my porcelain throne.
    2021 Audi S4, P34 Intake
    Veteran Member Four Rings GA42.0T's Avatar
    Jul 26 2010
    Atlanta, GA
    ^ that
    Jamie | 2008 2.0T FWD 6MT Brilliant Black S-like
    S-line Suspension+B5 Spring Perchs | RAI HFC | ER SMIC | 034 TIP | B8 18X8 Sport Wheels | Spacers: 10/12.5mm | RS4 Sway | "D" DV | De-badge | S4 Blackout Grill | Euro RNS-E | OEM Ecode Xenons | Clear Side Markers | Cupra Lip | S4 Mirror Caps | ECS Slotted/Drilled Front Rotors | Ceramic Pads | Poser S-line Door Badges | Podi | 034 Catch Can. Go: Still Stage Zero
    Veteran Member Four Rings B7Joe's Avatar
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    ^ same here. We have a pretty robust system, but I guess anything that prevents unnecessary wear is a good thing. I'll do that next time.
    Veteran Member Four Rings ericpaulyoung's Avatar
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Not once before, but will now.
    Eric
    Epy
    Jun 27 2011
    I actually knew about priming the filter, but I always forget. If you do that and are feeling paranoid, you can pull the cam sensor plug and crank it for 5 seconds a few times to get the oil moving around and through the filter.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jun 27 2011
    Quote Originally Posted by B7Joe View Post
    Robust? Yea the cam follower is an indestructible system...
    -CP
    2017 Q7 3.0t
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    I'm talking about the lubrication system, not the metal bits. But I agree that priming the filter can't be a bad idea. Maybe it was the use of the word robust. Lol!
