Results 1 to 8 of 8
    Senior Member Three Rings brady.'s Avatar
    Sep 25 2012
    green bay, wi
    exhaust manifold to catalytic converter stud snapped.
    So I have found what my ticking noise is coming from...
    _________________________________________
    My right bank exhaust is leaking. There are 3 bolts that secure the exhaust manifold to the catalytic converter. The top bolt and stud is not there. My question is, where do I go from there? I already have all the hardware: manifold to cat gasket, 3 new studs, 3 new bolts, new exhaust clamp
    Its such a tight squeeze in there with the bottom frame / subframe / support in the way. What is easiest but quickest way you guys would do this fix? I have a 5 - 8 hour window tomorrow where I can wrench on the car without any constraints. Hoping I can do the repair then
    Ideas?
    Apr 07 2011
    Are you sure you're talking about exhaust manifold to cat? The exhaust manifold is connected to the turbo on the 1.8T. Which engine do you have?
    Edit: Ahh from your avatar I can see the chrome trim so 3.0. I'm not too familiar with the 3.0 but if you think you have enough room in there you should be fine.
    Dec 25 2004
    Earth
    Quote Originally Posted by brady0630 View Post
    Ideas?
    Right bank? V6?
    Needs to be fixed....
    Hanson outs...left hand drill bits...drill and see if the broken stud will come out?
    Got some PB Blaster to soak it in?
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Nov 11 2010
    Rochester, MN
    Yes, brady has the 3.0.
    19" B8 S5 Peelers
    Sep 25 2012
    green bay, wi
    apologies, I thought my right bank comment was a big enough hint . 2002 A4 3.0 Quattro
    I have an idea on how to get the stud out. Just a bit more confused on the removal part. What parts to take off and where. Is it possible take exhaust manifold of without too much major wrenching, etc. I do not think I will get these answers though. Not many are familiar with the V6. Guess only thing now is to get my hands dirty and keep in mind I need the car put back together in 6 hours.
    thanks for the feedback everyone.
    Sep 25 2012
    green bay, wi
    I have no clue how I will torque this come time to piece this back together.
    '02 audi 3.0 quattro with 123,000 miles.
    Sep 25 2012
    green bay, wi
    any ideas on how to remove these bad boys?
    Sep 25 2012
    green bay, wi
    so unsure if anyone cares at this point , but either case for closure...
    I ended up having to drop the car off at a local exhaust shop. I ran out of time and have to go to the other jobby job soon. I laughed at the guy when he said "3.5 hours if nothing breaks." 3.5 hours is a joke but hey, my hands are tied. Pick the car up tomorrow, only hope to hear good things. wish me luck
